I am having problems with my website in relation to the authentication services I have added on top.
The website, https://insights-with-ellis.netlify.app, works well and load the login box from the authentication services, set up with FrontEgg.
However, when I try the activate account url or the reset password url (in the format Ellis plus a dynamically generated userId from FrontEgg), I get the “Page Not Found: Looks like you’ve followed a broken link or entered a URL that doesn’t exist on this site” error.
How can I make these pages exist or be found when a new user needs to activate their account or reset a password?
Yeah, I’m using a React framework. I have tried both with the _redirects file and with adding the redirection config to the netlify.toml file. None seems to work, and I’m still getting the “Page Not Found” error.
When doing it in the netlify.toml, I wrote this configuration:
[[redirects]]
from = "/*"
to = "/index.html"
status = 200
force = true
query = {path = ":path"}
Is that correct? If so, any other possibilities to configure the redirection and/or solve this issue?
I’ve eliminated the password protection, in case you need to check the site.
I tried visiting https://insights-with-ellis.netlify.app/account directly and received “Page Not Found”. This suggested the redirect isn’t correctly configured. On the latest deploy, is there an indication the redirect rule (or rules if you have multiple) were processed during deploy?
