Hello,
There is a problem with the website I created for my client: sanacjaostrow.netlify.app.
I can’t provide Let’s Encrypt SSL certificate - I can see an error “DNS verification failed sanacjaostrow.pl doesn’t appear to be served by Netlify”.
The custom domain is registred externally, but we added CNAME record the way it is described here: Configure external DNS for a custom domain | Netlify Docs.
I can see that the website is now visible on www.sanacjaostrow.pl and sanacjaostrow.pl however it doesn’t display properly without the SSL certificate.
Additionally we would like to set www.sanacjaostrow.pl as the primary domain but I can see an error “We’re provisioning a certificate for your site, you cannot change custom domains until that process completes”.
Could you check it please?
Thank you in advance!
Dariusz
