the problems: I have a problem connecting my domains with absence, I am always trying to put my ads code inside tags of my website but I find that AdSense doesn’t accept it, and answering me to put the same can I have some help
thanks a lot of
@nathanmartin hi friends, thanks for your answer, I’m trying to insert my code AdSense script “” and I mean by “AdSense doesn’t accept it” that always when I apply to Monetization, absence doesn’t accept me, and when I read the detail I find the same message to put my ads code inside , but I’m already doing
hi @nathanmartin@hrishikesh
Hi friends thanks for your answer the problem is not from Adsense because they don’t find my code inside my website as I will show you inside the picture, for example in pics 1 the reply is from absence, pics 2 is my code inside netlify, can I have help thanks
Hey @maroc.yes.1993 , in the second screenshot you provided it looks like you’ve misspelled “AdSense” as “Adsence”. This could be why it’s not working correctly when you deploy your site.
Can you try fixing the spelling and see if that helps?
