Site: anveshablog.netlify.app or www.anveshablog.com
I have a post which builds locally but not via Netlify. In fact, all other posts build except for this one and I do not see the problem. I have gone through the usual guides already, and they were not specifically helpful.
I downloaded the build also, and it looks like there is no index.html file, however I do have one when built locally using gatsby build in my Arch Linux.
If it helps, this is my first post after I added a custom domain, and I had not faced this before.
Deploy Log
11:02:32 PM: Build ready to start
11:02:34 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
11:02:34 PM: build-image tag: v3.4.1
11:02:34 PM: buildbot version: 4c73738fafb40608518be6837f4675455e8cfe64
11:02:34 PM: Fetching cached dependencies
11:02:35 PM: Starting to download cache of 355.2MB
11:02:38 PM: Finished downloading cache in 3.130757653s
11:02:38 PM: Starting to extract cache
11:02:49 PM: Finished extracting cache in 11.879892775s
11:02:50 PM: Finished fetching cache in 15.12284503s
11:02:50 PM: Starting to prepare the repo for build
11:02:50 PM: Preparing Git Reference refs/heads/master
11:02:51 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'blog/public' versus 'blog/public/' in the Netlify UI
11:02:51 PM: Starting build script
11:02:51 PM: Installing dependencies
11:02:51 PM: Python version set to 2.7
11:02:52 PM: Started restoring cached node version
11:02:55 PM: Finished restoring cached node version
11:02:55 PM: v12.18.0 is already installed.
11:02:56 PM: Now using node v12.18.0 (npm v6.14.4)
11:02:56 PM: Started restoring cached build plugins
11:02:56 PM: Finished restoring cached build plugins
11:02:56 PM: Attempting ruby version 2.7.1, read from environment
11:02:57 PM: Using ruby version 2.7.1
11:02:58 PM: Using PHP version 5.6
11:02:58 PM: 5.2 is already installed.
11:02:58 PM: Using Swift version 5.2
11:02:58 PM: Started restoring cached node modules
11:02:58 PM: Finished restoring cached node modules
11:02:58 PM: Started restoring cached yarn cache
11:02:58 PM: Finished restoring cached yarn cache
11:02:58 PM: Installing NPM modules using Yarn version 1.22.4
11:02:59 PM: yarn install v1.22.4
11:02:59 PM: [1/4] Resolving packages...
11:03:00 PM: [2/4] Fetching packages...
11:03:12 PM: warning url-loader@1.1.2: Invalid bin field for "url-loader".
11:03:30 PM: info fsevents@2.1.2: The platform "linux" is incompatible with this module.
11:03:30 PM: info "fsevents@2.1.2" is an optional dependency and failed compatibility check. Excluding it from installation.
11:03:30 PM: info fsevents@1.2.12: The platform "linux" is incompatible with this module.
11:03:30 PM: info "fsevents@1.2.12" is an optional dependency and failed compatibility check. Excluding it from installation.
11:03:30 PM: [3/4] Linking dependencies...
11:03:30 PM: warning " > workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa@0.0.1" has unmet peer dependency "gatsby@^2.15.7".
11:03:30 PM: warning " > workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa@0.0.1" has unmet peer dependency "react@^16.8.6".
11:03:30 PM: warning " > workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa@0.0.1" has unmet peer dependency "react-dom@^16.8.6".
11:03:30 PM: warning " > @narative/gatsby-theme-novela@0.13.1" has unmet peer dependency "gatsby@^2.15.7".
11:03:30 PM: warning " > @narative/gatsby-theme-novela@0.13.1" has unmet peer dependency "react@^16.8.6".
11:03:30 PM: warning " > @narative/gatsby-theme-novela@0.13.1" has unmet peer dependency "react-dom@^16.8.6".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-plugin-emotion@4.2.1" has unmet peer dependency "@babel/core@^7.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-plugin-theme-ui@0.3.0" has incorrect peer dependency "theme-ui@^0.2.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-remark-katex@3.2.1" has incorrect peer dependency "katex@^0.10.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-remark-prismjs@3.4.1" has unmet peer dependency "prismjs@^1.15.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > blog > gatsby-plugin-react-helmet@3.3.10" has unmet peer dependency "react-helmet@^5.1.3 || ^6.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > blog > gatsby-plugin-react-helmet-canonical-urls@1.4.0" has unmet peer dependency "react-helmet@*".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > blog > hyvor-talk-react@1.0.1" has unmet peer dependency "prop-types@^15.5.4".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby > react-hot-loader@4.12.20" has unmet peer dependency "@types/react@^15.0.0 || ^16.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-plugin-emotion > @emotion/babel-preset-css-prop@10.0.27" has unmet peer dependency "@babel/core@^7.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-remark-katex > remark-math@1.0.6" has unmet peer dependency "remark-parse@^3.0.0 || ^4.0.0 || ^5.0.0 || ^6.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > blog > react-pdf > pdfjs-dist@2.1.266" has unmet peer dependency "webpack@^3.0.0 || ^4.0.0-alpha.0 || ^4.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby > @typescript-eslint/eslint-plugin > tsutils@3.17.1" has unmet peer dependency "typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-plugin-emotion > @emotion/babel-preset-css-prop > @babel/plugin-transform-react-jsx@7.9.4" has unmet peer dependency "@babel/core@^7.0.0-0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > @narative/gatsby-theme-novela > gatsby-plugin-emotion > @emotion/babel-preset-css-prop > @emotion/babel-plugin-jsx-pragmatic@0.1.5" has unmet peer dependency "@babel/core@^7.0.0".
11:03:30 PM: warning "workspace-aggregator-b5d517d0-1a0a-4229-984d-ba18948daaaa > blog > react-pdf > pdfjs-dist > worker-loader@2.0.0" has unmet peer dependency "webpack@^3.0.0 || ^4.0.0-alpha.0 || ^4.0.0".
11:03:53 PM: [4/4] Building fresh packages...
11:04:04 PM: Done in 65.16s.
11:04:04 PM: NPM modules installed using Yarn
11:04:04 PM: Started restoring cached go cache
11:04:04 PM: Finished restoring cached go cache
11:04:04 PM: go version go1.14.4 linux/amd64
11:04:04 PM: Installing missing commands
11:04:04 PM: Verify run directory
11:04:05 PM: β
11:04:05 PM: βββββββββββββββββββββββββββββββ
11:04:05 PM: β Netlify Build β
11:04:05 PM: β
11:04:05 PM: β― Version
11:04:05 PM: @netlify/build 3.1.5
11:04:05 PM: β
11:04:05 PM: β― Flags
11:04:05 PM: deployId: 5f2c3eb064df3600074ebab8
11:04:05 PM: mode: buildbot
11:04:05 PM: timersFile: /tmp/substage_times.txt
11:04:05 PM: β
11:04:05 PM: β― Current directory
11:04:05 PM: /opt/build/repo
11:04:05 PM: β
11:04:05 PM: β― Config file
11:04:05 PM: /opt/build/repo/netlify.toml
11:04:05 PM: β
11:04:05 PM: β― Context
11:04:05 PM: production
11:04:05 PM: β
11:04:05 PM: β― Loading plugins
11:04:05 PM: - netlify-plugin-image-optim@0.3.0 from Netlify app
11:04:05 PM: - netlify-plugin-gatsby-cache@0.3.0 from Netlify app
11:04:06 PM: β
11:04:06 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
11:04:06 PM: β 1. onPreBuild command from netlify-plugin-gatsby-cache β
11:04:06 PM: β
11:04:07 PM: Found a Gatsby cache. Weβre about to go FAST. β‘οΈ
11:04:07 PM: β
11:04:07 PM: (netlify-plugin-gatsby-cache onPreBuild completed in 1.3s)
11:04:07 PM: β
11:04:07 PM: βββββββββββββββββββββββββββββββββββββ
11:04:07 PM: β 2. Build command from Netlify app β
11:04:07 PM: β
11:04:07 PM: $ yarn build
11:04:07 PM: yarn run v1.22.4
11:04:07 PM: $ yarn workspace blog build
11:04:08 PM: $ gatsby build && cp -R _redirects public/
11:04:10 PM: success open and validate gatsby-configs - 0.078s
11:04:11 PM: success load plugins - 1.372s
11:04:11 PM: success onPreInit - 0.009s
11:04:11 PM: success delete html and css files from previous builds - 0.029s
11:04:11 PM: info One or more of your plugins have changed since the last time you ran Gatsby. As
11:04:11 PM: a precaution, we're deleting your site's cache to ensure there's no stale data.success initialize cache - 0.023s
11:04:11 PM: success copy gatsby files - 0.034s
11:04:12 PM: success onPreBootstrap - 0.022s
11:04:12 PM: success createSchemaCustomization - 0.006s
11:04:15 PM: success source and transform nodes - 3.445s
11:04:15 PM: success building schema - 0.489s
11:04:15 PM: { local: true, contentful: false }
11:04:15 PM:
11:04:15 PM: Config rootPath /
11:04:15 PM:
11:04:15 PM: Config basePath /
11:04:15 PM:
11:04:15 PM: Config authorsPath /authors
11:04:15 PM:
11:04:15 PM: Querying Authors & Articles source: Local
11:04:25 PM:
11:04:25 PM: Creating articles page
11:04:25 PM:
11:04:25 PM: Creating article posts
11:04:25 PM:
11:04:25 PM: Creating authors page
11:04:25 PM:
11:04:25 PM: Creating tag pages
11:04:26 PM: success createPages - 10.084s
11:04:26 PM: success createPagesStatefully - 0.137s
11:04:26 PM: success onPreExtractQueries - 0.000s
11:04:26 PM: success update schema - 0.301s
11:04:26 PM: success extract queries from components - 0.496s
11:04:26 PM: success write out requires - 0.004s
11:04:26 PM: success write out redirect data - 0.001s
11:04:26 PM: warning The icon(src/assets/favicon.png) you provided to 'gatsby-plugin-manifest' is not square.
11:04:26 PM: The icons we generate will be square and for the best results we recommend you provide a square icon.
11:04:27 PM: success Build manifest and related icons - 0.598s
11:04:27 PM: success onPostBootstrap - 0.600s
11:04:27 PM: β
11:04:27 PM: info bootstrap finished - 19.333 s
11:04:27 PM: β
11:05:18 PM: success Building production JavaScript and CSS bundles - 50.691s
11:05:18 PM: success Rewriting compilation hashes - 0.001s
11:05:19 PM: success run queries - 51.747s - 53/53 1.02/s
11:05:29 PM: success Building static HTML for pages - 10.385s - 48/48 4.62/s
11:05:29 PM: success onPostBuild - 0.016s
11:05:29 PM: info Done building in 81.522993868 sec
11:05:30 PM: Done in 82.43s.
11:05:30 PM: β
11:05:30 PM: (build.command completed in 1m 22.6s)
11:05:30 PM: β
11:05:30 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
11:05:30 PM: β 3. onPostBuild command from netlify-plugin-image-optim β
11:05:30 PM: β
11:06:29 PM: β File β Before β After β Reduction β
11:06:29 PM: βββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββΌβββββββββββββΌβββββββββββββΌββββββββββββ€
11:06:29 PM: β /404.png β 119.56 KB β 41.88 KB β 77.68 KB β
11:06:29 PM: β /code_stats.png β 9 KB β 6.29 KB β 2.71 KB β
11:06:29 PM: β /corona.png β 326.8 KB β 106.18 KB β 220.62 KB β
11:06:29 PM: β /icons/icon-144x144.png β 6.08 KB β 4.65 KB β 1.43 KB β
11:06:29 PM: β /icons/icon-192x192.png β 8.99 KB β 6.35 KB β 2.63 KB β
11:06:29 PM: β /icons/icon-256x256.png β 12.76 KB β 8.51 KB β 4.25 KB β
11:06:29 PM: β /icons/icon-384x384.png β 21.46 KB β 13.23 KB β 8.23 KB β
11:06:29 PM: β /icons/icon-48x48.png β 1.48 KB β 1.48 KB β 0 B β
11:06:29 PM: β /icons/icon-512x512.png β 30.7 KB β 18.12 KB β 12.58 KB β
11:06:29 PM: β /icons/icon-72x72.png β 2.45 KB β 2.34 KB β 118 B β
11:06:29 PM: β /icons/icon-96x96.png β 3.54 KB β 3.08 KB β 472 B β
11:06:29 PM: β Images optimized - 331.96 KB saved β
11:06:29 PM: β
11:06:29 PM: (netlify-plugin-image-optim onPostBuild completed in 59.3s)
11:06:29 PM: β
11:06:29 PM: β 4. onPostBuild command from netlify-plugin-gatsby-cache β
11:06:29 PM: β
11:06:30 PM: Stored the Gatsby cache to speed up future builds.
11:06:30 PM: β
11:06:30 PM: (netlify-plugin-gatsby-cache onPostBuild completed in 1.5s)
11:06:31 PM: β
11:06:31 PM: βββββββββββββββββββββββββββββββ
11:06:31 PM: β Netlify Build Complete β
11:06:31 PM: β
11:06:31 PM: (Netlify Build completed in 2m 25.4s)
11:06:31 PM: Caching artifacts
11:06:31 PM: Started saving node modules
11:06:31 PM: Finished saving node modules
11:06:31 PM: Started saving build plugins
11:06:31 PM: Finished saving build plugins
11:06:31 PM: Started saving yarn cache
11:06:31 PM: Finished saving yarn cache
11:06:31 PM: Started saving pip cache
11:06:31 PM: Finished saving pip cache
11:06:31 PM: Started saving emacs cask dependencies
11:06:31 PM: Finished saving emacs cask dependencies
11:06:31 PM: Started saving maven dependencies
11:06:31 PM: Finished saving maven dependencies
11:06:31 PM: Started saving boot dependencies
11:06:31 PM: Finished saving boot dependencies
11:06:31 PM: Started saving go dependencies
11:06:31 PM: Finished saving go dependencies
11:06:31 PM: Build script success
11:06:31 PM: Starting to deploy site from 'blog/public'
11:06:31 PM: Creating deploy tree asynchronously
11:06:33 PM: 1 new files to upload
11:06:33 PM: 0 new functions to upload
11:06:41 PM: Starting post processing
11:06:42 PM: Post processing - HTML
11:06:48 PM: Post processing - redirect rules
11:06:48 PM: Post processing - header rules
11:06:48 PM: Post processing done
11:06:48 PM: Site is live
11:07:17 PM: Finished processing build request in 4m42.639942336s
