The issue is, myapp /home.html is different than wizardly-williams / home.html. They have the same code but myapp / home.html doesn’t access the database and the old link does.
Is this related to domain transfer or do I need to look through all my code again?
hey there, yes we do need the actual domains so we can best offer support
I pulled up both sites and they look identical at first glance - can you explain a bit more what you mean by “access the database”?
As the site is clearly loading under the domain name genderev.com, that can’t be an issue - we’d see different behaviour if that was the case. Can you explain a bit more what you think the problem is?
