I need help as I encounter error when trying to deploy github repository to Netlify :
1:24:15 PM: Failed to compile.
1:24:15 PM:
1:24:15 PM: ./src/views/about-us.js
1:24:15 PM: Line 3:10: ‘Hero’ is defined but never used no-unused-vars
1:24:15 PM: Line 3:16: ‘Content’ is defined but never used no-unused-vars
1:24:15 PM: ./src/views/external-api.js
1:24:15 PM: Line 6:19: ‘setMessage’ is assigned a value but never used no-unused-vars
1:24:15 PM:
1:24:15 PM: ────────────────────────────────────────────────────────────────
1:24:15 PM: “build.command” failed
1:24:15 PM:
1:24:15 PM: Error message
1:24:15 PM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
1:24:15 PM:
1:24:15 PM: Error location
1:24:15 PM: In Build command from Netlify app:
1:24:15 PM: npm run build
1:24:15 PM:
1:24:15 PM: Resolved config
1:24:15 PM: build:
1:24:15 PM: command: npm run build
1:24:15 PM: commandOrigin: ui
1:24:15 PM: publish: /opt/build/repo/build
1:24:15 PM: publishOrigin: ui
1:24:16 PM: Caching artifacts
1:24:16 PM: Started saving node modules
1:24:16 PM: Finished saving node modules
1:24:16 PM: Started saving build plugins
1:24:16 PM: Finished saving build plugins
1:24:16 PM: Started saving pip cache
1:24:16 PM: Finished saving pip cache
1:24:16 PM: Started saving emacs cask dependencies
1:24:16 PM: Finished saving emacs cask dependencies
1:24:16 PM: Started saving maven dependencies
1:24:16 PM: Finished saving maven dependencies
1:24:16 PM: Started saving boot dependencies
1:24:16 PM: Finished saving boot dependencies
1:24:16 PM: Started saving rust rustup cache
1:24:16 PM: Finished saving rust rustup cache
1:24:16 PM: Started saving go dependencies
1:24:16 PM: Finished saving go dependencies
1:24:17 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
1:24:17 PM: Creating deploy upload records
1:24:18 PM: Failing build: Failed to build site
1:24:18 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
1:24:18 PM: Finished processing build request in 1m29.379196186s
