I don’t know what happens but every time I try to deploy my site on Netlify through github, it fails.
This is the repository I am deploying from: github.com/egg899/FCC-random-quote-machine
This would be the URL:
stellular-semolina-5c78d1.netlify.app
This is what I get:
12:14:21 AM: Netlify Build
12:14:21 AM: ────────────────────────────────────────────────────────────────
12:14:21 AM:
12:14:21 AM: ❯ Version
12:14:21 AM: @netlify/build 29.20.12
12:14:21 AM:
12:14:21 AM: ❯ Flags
12:14:21 AM: baseRelDir: true
12:14:21 AM: buildId: 64fd3480db4b094d1aa184b2
12:14:21 AM: deployId: 64fd3480db4b094d1aa184b4
12:14:21 AM:
12:14:21 AM: ❯ Current directory
12:14:21 AM: /opt/build/repo
12:14:21 AM:
12:14:21 AM: ❯ Config file
12:14:21 AM: No config file was defined: using default values.
12:14:21 AM:
12:14:21 AM: ❯ Context
12:14:21 AM: production
12:14:21 AM:
12:14:21 AM: Build command from Netlify app
12:14:21 AM:
12:14:21 AM: $ npm run build
12:14:21 AM: > random-quote-machine@0.0.0 build
12:14:21 AM: > tsc && vite build
12:14:22 AM: src/App.tsx(3,1): error TS6133: ‘Button’ is declared but its value is never read.
12:14:22 AM: src/App.tsx(3,20): error TS7016: Could not find a declaration file for module ‘./assets/Button.jsx’. ‘/opt/build/repo/src/assets/Button.jsx’ implicitly has an ‘any’ type.
12:14:22 AM: src/App.tsx(40,11): error TS6133: ‘result’ is declared but its value is never read.
12:14:22 AM: src/App.tsx(81,17): error TS2339: Property ‘content’ does not exist on type ‘never’.
12:14:22 AM: src/App.tsx(85,31): error TS2339: Property ‘author’ does not exist on type ‘never’.
12:14:22 AM: src/App.tsx(91,100): error TS2339: Property ‘content’ does not exist on type ‘never’.
12:14:22 AM: src/App.tsx(91,116): error TS2339: Property ‘author’ does not exist on type ‘never’.
12:14:22 AM:
12:14:22 AM: build.command failed
12:14:22 AM: ────────────────────────────────────────────────────────────────
12:14:22 AM:
12:14:22 AM: Error message
12:14:22 AM: Command failed with exit code 2: npm run build (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
12:14:22 AM:
12:14:22 AM: Error location
12:14:22 AM: In Build command from Netlify app:
12:14:22 AM: npm run build
12:14:22 AM:
12:14:22 AM: Resolved config
12:14:22 AM: build:
12:14:22 AM: command: npm run build
12:14:22 AM: commandOrigin: ui
12:14:22 AM: environment:
12:14:22 AM: - CI
12:14:22 AM: - DEPRECATED
12:14:22 AM: publish: /opt/build/repo/dist
12:14:22 AM: publishOrigin: ui
12:14:23 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
12:14:23 AM: Failing build: Failed to build site
12:14:24 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
12:14:24 AM: Finished processing build request in 13.679s
12:14:25 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
