Trying to deploy a react app and keep getting this error
- we need to know your netlify site name. Example:
gregarious-klepon-c083b4
11:21:17 AM: Build ready to start
11:21:20 AM: build-image version: d2c6dbeac570350a387d832f64bc980dc964ad65 (focal)
11:21:20 AM: build-image tag: v4.8.0
11:21:20 AM: buildbot version: e552b142336b2b1222a93a4fd4cbed0019c77b46
11:21:20 AM: Fetching cached dependencies
11:21:20 AM: Failed to fetch cache, continuing with build
11:21:20 AM: Starting to prepare the repo for build
11:21:20 AM: No cached dependencies found. Cloning fresh repo
11:21:20 AM: git clone https://github.com/raboomar/tekcamp
11:21:22 AM: Preparing Git Reference refs/heads/develop
11:21:23 AM: Parsing package.json dependencies
11:21:23 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: ‘ecommercewebsite/build’ versus ‘build’ in the Netlify UI
11:21:24 AM: Starting build script
11:21:24 AM: Installing dependencies
11:21:24 AM: Python version set to 2.7
11:21:25 AM: v16.14.2 is already installed.
11:21:26 AM: Now using node v16.14.2 (npm v8.5.0)
11:21:26 AM: Started restoring cached build plugins
11:21:26 AM: Finished restoring cached build plugins
11:21:26 AM: Attempting ruby version 2.7.2, read from environment
11:21:28 AM: Using ruby version 2.7.2
11:21:28 AM: Using PHP version 8.0
11:21:29 AM: No npm workspaces detected
11:21:29 AM: Started restoring cached node modules
11:21:29 AM: Finished restoring cached node modules
11:21:29 AM: Installing NPM modules using NPM version 8.5.0
11:21:42 AM: npm WARN deprecated source-map-url@0.4.1: See GitHub - lydell/source-map-url: [DEPRECATED] Tools for working with sourceMappingURL comments.
11:21:45 AM: npm WARN deprecated source-map-resolve@0.6.0: See GitHub - lydell/source-map-resolve: [DEPRECATED] Resolve the source map and/or sources for a generated file.
11:21:56 AM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
11:22:05 AM: added 1453 packages, and audited 1454 packages in 36s
11:22:05 AM: 177 packages are looking for funding
11:22:05 AM: run npm fund for details
11:22:05 AM: 8 vulnerabilities (6 moderate, 1 high, 1 critical)
11:22:05 AM: To address issues that do not require attention, run:
11:22:05 AM: npm audit fix
11:22:05 AM: To address all issues (including breaking changes), run:
11:22:05 AM: npm audit fix --force
11:22:05 AM: Run npm audit for details.
11:22:05 AM: NPM modules installed
11:22:06 AM: Started restoring cached go cache
11:22:06 AM: Finished restoring cached go cache
11:22:06 AM: go version go1.16.5 linux/amd64
11:22:06 AM: Installing missing commands
11:22:06 AM: Verify run directory
11:22:08 AM:
11:22:08 AM: ────────────────────────────────────────────────────────────────
11:22:08 AM: Netlify Build
11:22:08 AM:
11:22:08 AM: ❯ Version
11:22:08 AM: @netlify/build 26.5.2
11:22:08 AM:
11:22:08 AM: ❯ Flags
11:22:08 AM: baseRelDir: true
11:22:08 AM: buildId: 625598ed13846a0009d20bd1
11:22:08 AM: deployId: 625598ed13846a0009d20bd3
11:22:08 AM:
11:22:08 AM: ❯ Current directory
11:22:08 AM: /opt/build/repo/ecommercewebsite
11:22:08 AM:
11:22:08 AM: ❯ Config file
11:22:08 AM: No config file was defined: using default values.
11:22:08 AM:
11:22:08 AM: ❯ Context
11:22:08 AM: production
11:22:08 AM:
11:22:08 AM: 1. Build command from Netlify app
11:22:08 AM:
11:22:08 AM: $ npm run build
11:22:08 AM: > ecommercewebsite@0.1.0 build
11:22:08 AM: > react-scripts build
11:22:10 AM: Creating an optimized production build…
11:22:45 AM:
11:22:45 AM: Treating warnings as errors because process.env.CI = true.
11:22:45 AM: Most CI servers set it automatically.
11:22:45 AM:
11:22:45 AM: Failed to compile.
11:22:45 AM:
11:22:45 AM: src/App.js
11:22:45 AM: Line 16:16: ‘setData’ is assigned a value but never used no-unused-vars
11:22:45 AM: Line 17:16: ‘setCart’ is assigned a value but never used no-unused-vars
11:22:45 AM: src/CartItemView.jsx
11:22:45 AM: Line 10:17: ‘setitems’ is assigned a value but never used no-unused-vars
11:22:45 AM: Line 11:15: ‘settotal’ is assigned a value but never used no-unused-vars
11:22:45 AM: src/Filter.jsx
11:22:45 AM: Line 13:37: Array.prototype.filter() expects a value to be returned at the end of arrow function array-callback-return
11:22:45 AM:
11:22:45 AM: ────────────────────────────────────────────────────────────────
11:22:45 AM: “build.command” failed
11:22:45 AM:
11:22:45 AM: Error message
11:22:45 AM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
11:22:45 AM:
11:22:45 AM: Error location
11:22:45 AM: In Build command from Netlify app:
11:22:45 AM: npm run build
11:22:45 AM:
11:22:45 AM: Resolved config
11:22:45 AM: build:
11:22:45 AM: base: /opt/build/repo/ecommercewebsite
11:22:45 AM: command: npm run build
11:22:45 AM: commandOrigin: ui
11:22:45 AM: publish: /opt/build/repo/ecommercewebsite/build
11:22:45 AM: publishOrigin: ui
11:22:46 AM: Caching artifacts
11:22:46 AM: Started saving node modules
11:22:46 AM: Finished saving node modules
11:22:46 AM: Started saving build plugins
11:22:46 AM: Finished saving build plugins
11:22:46 AM: Started saving pip cache
11:22:46 AM: Finished saving pip cache
11:22:46 AM: Started saving emacs cask dependencies
11:22:46 AM: Finished saving emacs cask dependencies
11:22:46 AM: Started saving maven dependencies
11:22:46 AM: Finished saving maven dependencies
11:22:46 AM: Started saving boot dependencies
11:22:46 AM: Finished saving boot dependencies
11:22:46 AM: Started saving rust rustup cache
11:22:46 AM: Finished saving rust rustup cache
11:22:46 AM: Started saving go dependencies
11:22:46 AM: Finished saving go dependencies
11:22:47 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
11:22:48 AM: Creating deploy upload records
11:22:48 AM: Failing build: Failed to build site
11:22:48 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
11:22:48 AM: Finished processing build request in 1m28.357263017s
