Website:https://fantastic-alfajores-d2e8e1.netlify.app/
As you can see, there is not image in the background on the hero section.
The form has no style, and requires an image.
Please help -
Please help -
@Danfraga33 Can’t see anything there, the entire site shows a 404
Have you renamed/removed it, or do you not have an index.html
file deployed?
Sorry, I did remove it
Ive edited the post,
here is the link: https://fantastic-alfajores-d2e8e1.netlify.app/
@Danfraga33 Some of your site assets are returning as 404's
because they aren’t where you’ve referenced them.
For example the css file that you’ve got linked as /Freelance/Portfolio/Spectral/assets/css/form.css
Is actually here:
Likewise the background image you have linked as /Freelance/Portfolio/Spectral/images/BG.jpg
Is here:
/images/BG.jpg
Your form.js
I can’t advise on, but it’s probably a similar issue, just check your references and perform you build locally and check what is in your Publish directory
to make sure everything is where it should be.
Be careful with case sensitivity too, which I only say because I can see you using intermittent uppercase characters, and those may trip you up too. The easiest way to do it is stick to lowercase if you can.
