So I have my domain registered elsewhere but nameservers managed by Netlify. Everything worked fine until I wanted to assign it to a different site on Netlify.
I first removed example.net as a custom domain for site-example-aaaaaa and then add the same custom domain for site-example-bbbbbb
I feel like the way I did this did not work correctly. I assumed Netlify dns management would no longer point example.net to site-example-aaaaaa.
Here is the issues:
My site listing shows site-example-bbbbbb as the site registered for example.net
However, under the main Netlify domain management UI it is reporting that example.net is linked to site-example-aaaaaa instead (via the special NETLIFY) record.
My actual site seems to be being served out of site-example-aaaaaa even though there is no custom domain set on that site.
I am also having Netlify Forms issues with not submitting on the domain (but does on preview of deploy using netlify domain) which I assume is caused by some mis match in which site is being used by the custom domain.
I made this change yesterday and I thought it might fix itself but I might have hit an edge case.
Thanks for all the assistance, just trying to help as well.
edit: I have attached a screenshot. I had to black out some details and put them all into one image (new users can only attach one per post!?).
