8:05:28 AM: build-image version: 3ffff9df3d5419545acc1b673a54de348174406d (focal)
8:05:28 AM: buildbot version: 5e61a99f29958b8aa3fd441571eb23975d453146
8:05:28 AM: Building without cache
8:05:28 AM: Starting to prepare the repo for build
8:05:28 AM: No cached dependencies found. Cloning fresh repo
8:05:28 AM: git clone --filter=blob:none GitHub - WebDev-Insider/blog-website-with-nextjs-taileind-css
8:05:28 AM: Preparing Git Reference refs/heads/origin
8:05:30 AM: Starting to install dependencies
8:05:30 AM: Python version set to 3.8
8:05:30 AM: Attempting Ruby version 2.7.2, read from environment
8:05:31 AM: Using Ruby version 2.7.2
8:05:31 AM: Started restoring cached go cache
8:05:31 AM: Finished restoring cached go cache
8:05:33 AM: go version go1.19.13 linux/amd64
8:05:33 AM: Using PHP version 8.0
8:05:34 AM: v18.18.2 is already installed.
8:05:34 AM: Now using node v18.18.2 (npm v9.8.1)
8:05:34 AM: Enabling Node.js Corepack
8:05:35 AM: Started restoring cached build plugins
8:05:35 AM: Finished restoring cached build plugins
8:05:35 AM: Started restoring cached corepack dependencies
8:05:35 AM: Finished restoring cached corepack dependencies
8:05:35 AM: No npm workspaces detected
8:05:35 AM: Started restoring cached node modules
8:05:35 AM: Finished restoring cached node modules
8:05:35 AM: Installing npm packages using npm version 9.8.1
8:05:40 AM: added 113 packages, and audited 114 packages in 5s
8:05:40 AM: 21 packages are looking for funding
8:05:40 AM: run npm fund for details
8:05:40 AM: found 0 vulnerabilities
8:05:40 AM: npm packages installed
8:05:41 AM: Successfully installed dependencies
8:05:41 AM: Starting build script
8:05:41 AM: Detected 1 framework(s)
8:05:41 AM: “next” at version “14.0.2”
8:05:41 AM: Section completed: initializing
8:05:43 AM:
8:05:43 AM: Netlify Build
8:05:43 AM: ────────────────────────────────────────────────────────────────
8:05:43 AM:
8:05:43 AM: ❯ Version
8:05:43 AM: @netlify/build 29.26.4
8:05:43 AM:
8:05:43 AM: ❯ Flags
8:05:43 AM: baseRelDir: true
8:05:43 AM: buildId: 655badf62589632366479c12
8:05:43 AM: deployId: 655badf62589632366479c14
8:05:43 AM:
8:05:43 AM: ❯ Current directory
8:05:43 AM: /opt/build/repo
8:05:43 AM:
8:05:43 AM: ❯ Config file
8:05:43 AM: No config file was defined: using default values.
8:05:43 AM:
8:05:43 AM: ❯ Context
8:05:43 AM: production
8:05:43 AM:
8:05:43 AM: ❯ Installing plugins
8:05:43 AM: - @netlify/plugin-nextjs@4.41.2
8:05:53 AM:
8:05:53 AM: ❯ Using Next.js Runtime - v4.41.2
8:05:54 AM:
8:05:54 AM: @netlify/plugin-nextjs (onPreBuild event)
8:05:54 AM: ────────────────────────────────────────────────────────────────
8:05:54 AM:
8:05:54 AM: No Next.js cache to restore.
8:05:54 AM: Netlify configuration property “build.environment.NEXT_PRIVATE_TARGET” value changed.
8:05:54 AM:
8:05:54 AM: (@netlify/plugin-nextjs onPreBuild completed in 52ms)
8:05:54 AM:
8:05:54 AM: Build command from Netlify app
8:05:54 AM:
8:05:54 AM: $ npm run build
8:05:54 AM: > blog@0.1.0 build
8:05:54 AM: > next build
8:05:54 AM:
No build cache found. Please configure build caching for faster rebuilds. Read more: No Cache Detected | Next.js
8:05:54 AM: Linting and checking validity of types …
8:05:54 AM: ▲ Next.js 14.0.2
8:05:54 AM: Creating an optimized production build …
8:05:57 AM:
Compiled with warnings
8:05:57 AM: ./components/section1.js
8:05:57 AM: Attempted import error: “Autoplay” is not exported from “swiper” (imported as “Autoplay”).
8:05:57 AM: Import trace for requested module:
8:05:57 AM: Collecting page data …
8:05:58 AM: TypeError: fetch failed
8:05:58 AM: at Object.fetch (node:internal/deps/undici/undici:11372:11)
8:05:58 AM: at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
8:05:58 AM: at async a (/opt/build/repo/.next/server/pages/posts/[postId].js:1:7076)
8:05:58 AM: at async x (/opt/build/repo/.next/server/pages/posts/[postId].js:1:59173)
8:05:58 AM: at async buildStaticPaths (/opt/build/repo/node_modules/next/dist/build/utils.js:758:33)
8:05:58 AM: at async /opt/build/repo/node_modules/next/dist/build/utils.js:1174:110
8:05:58 AM: at async Span.traceAsyncFn (/opt/build/repo/node_modules/next/dist/trace/trace.js:140:20) {
8:05:58 AM: cause: Error: connect ECONNREFUSED ::1:3000
8:05:58 AM: at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16) {
8:05:58 AM: errno: -111,
8:05:58 AM: code: “ECONNREFUSED”,
8:05:58 AM: syscall: “connect”,
8:05:58 AM: address: “::1”,
8:05:58 AM: port: 3000
8:05:58 AM: }
8:05:58 AM: }
8:05:58 AM: > Build error occurred
8:05:58 AM: Error: Failed to collect page data for /posts/[postId]
8:05:58 AM: at /opt/build/repo/node_modules/next/dist/build/utils.js:1217:15
8:05:58 AM: at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
8:05:58 AM: type: “Error”
8:05:58 AM: }
8:05:58 AM:
8:05:58 AM: “build.command” failed
8:05:58 AM: ────────────────────────────────────────────────────────────────
8:05:58 AM:
8:05:58 AM: Error message
8:05:58 AM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
8:05:58 AM:
8:05:58 AM: Error location
8:05:58 AM: In Build command from Netlify app:
8:05:58 AM: npm run build
8:05:58 AM:
8:05:58 AM: Resolved config
8:05:58 AM: build:
8:05:58 AM: command: npm run build
8:05:58 AM: commandOrigin: ui
8:05:58 AM: environment:
8:05:58 AM: - CI
8:05:58 AM: - NEXT_PRIVATE_TARGET
8:05:58 AM: publish: /opt/build/repo/.next
8:05:58 AM: publishOrigin: ui
8:05:58 AM: plugins:
8:05:58 AM: - inputs: {}
8:05:58 AM: origin: ui
8:05:58 AM: package: “@netlify/plugin-nextjs”
8:05:59 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:05:59 AM: Failing build: Failed to build site
8:05:59 AM: Finished processing build request in 31.312s
8:05:59 AM: Failed during stage “building site”: Build script returned non-zero exit code: 2
Hiya, sorry you are having trouble with your build.
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem
Additionally, this Support Guide houses all of our resources for debugging build and deploy issues.
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
If you are still having problems, please provide as much information as you can on what you have already tried, what your build settings are, your package.json, etc. Thanks!
i just need you to guide me through on how i can resolve this issues please i beg you
2 things: Next.s 14 is not completey supported on Netlify right now (but that’s not causing this issue)
The issue is caused by this:
You’re connecting to localhost for whatever reason. You need to fix that.
