3:03:16 PM: Build ready to start
3:03:22 PM: build-image version: 72a309a113b53ef075815b129953617827965e48 (focal)
3:03:22 PM: build-image tag: v4.8.2
3:03:22 PM: buildbot version: 515e5c33287d8b909c004fcf2e460e8645e8c1c6
3:03:22 PM: Fetching cached dependencies
3:03:22 PM: Failed to fetch cache, continuing with build
3:03:22 PM: Starting to prepare the repo for build
3:03:22 PM: No cached dependencies found. Cloning fresh repo
3:03:22 PM: git clone GitHub - Ghafar2021/Crypto-Researcher
3:03:23 PM: Preparing Git Reference refs/heads/master
3:03:23 PM: Parsing package.json dependencies
3:03:24 PM: Starting build script
3:03:24 PM: Installing dependencies
3:03:24 PM: Python version set to 2.7
3:03:25 PM: v16.15.1 is already installed.
3:03:25 PM: Now using node v16.15.1 (npm v8.11.0)
3:03:25 PM: Started restoring cached build plugins
3:03:25 PM: Finished restoring cached build plugins
3:03:25 PM: Attempting ruby version 2.7.2, read from environment
3:03:26 PM: Using ruby version 2.7.2
3:03:26 PM: Using PHP version 8.0
3:03:27 PM: No npm workspaces detected
3:03:27 PM: Started restoring cached node modules
3:03:27 PM: Finished restoring cached node modules
3:03:27 PM: Installing NPM modules using NPM version 8.11.0
3:03:27 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
3:03:27 PM: npm WARN config location in the cache, and they are managed by
3:03:27 PM: npm WARN config cacache.
3:03:28 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
3:03:28 PM: npm WARN config location in the cache, and they are managed by
3:03:28 PM: npm WARN config cacache.
3:03:29 PM: npm ERR! code ERESOLVE
3:03:29 PM: npm ERR! ERESOLVE could not resolve
3:03:29 PM: npm ERR! While resolving: @material-ui/core@4.12.4
3:03:29 PM: npm ERR! Found: react@18.1.0
3:03:29 PM: npm ERR! node_modules/react
3:03:29 PM: npm ERR! react@“^18.1.0” from the root project
3:03:29 PM: npm ERR! peer react@“>=16.8.0” from @emotion/react@11.9.0
3:03:29 PM: npm ERR! node_modules/@emotion/react
3:03:29 PM: npm ERR! @emotion/react@“^11.9.0” from the root project
3:03:29 PM: npm ERR! peer @emotion/react@“^11.0.0-rc.0” from @emotion/styled@11.8.1
3:03:29 PM: npm ERR! node_modules/@emotion/styled
3:03:29 PM: npm ERR! @emotion/styled@“^11.8.1” from the root project
3:03:29 PM: npm ERR! 3 more (@mui/material, @mui/styled-engine, @mui/system)
3:03:29 PM: npm ERR! 17 more (@emotion/styled, @mui/base, @mui/lab, @mui/material, …)
3:03:29 PM: npm ERR! Could not resolve dependency:
3:03:29 PM: npm ERR! peer react@“^16.8.0 || ^17.0.0” from @material-ui/core@4.12.4
3:03:29 PM: npm ERR! node_modules/@material-ui/core
3:03:29 PM: npm ERR! @material-ui/core@“^4.12.4” from the root project
3:03:29 PM: npm ERR! peer @material-ui/core@“^4.12.1” from @material-ui/lab@4.0.0-alpha.61
3:03:29 PM: npm ERR! node_modules/@material-ui/lab
3:03:29 PM: npm ERR! @material-ui/lab@“^4.0.0-alpha.61” from the root project
3:03:29 PM: npm ERR! Conflicting peer dependency: react@17.0.2
3:03:29 PM: npm ERR! Fix the upstream dependency conflict, or retry
3:03:29 PM: npm ERR! this command with --force, or --legacy-peer-deps
3:03:29 PM: npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
3:03:29 PM: npm ERR! See /opt/buildhome/.npm/eresolve-report.txt for a full report.
3:03:29 PM: npm ERR! A complete log of this run can be found in:
3:03:29 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-06-29T13_03_28_171Z-debug-0.log
3:03:29 PM: Error during NPM install
3:03:29 PM: Build was terminated: Build script returned non-zero exit code: 1
3:03:29 PM: Creating deploy upload records
3:03:29 PM: Failing build: Failed to build site
3:03:29 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1 (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
3:03:29 PM: Finished processing build request in 7.317656754s
See the answer here:
