Hi everyone, hope you are doing well.
I’m having issues on my site, on the building part. My site is happy-mcnulty-e8f9df
The Github repo is the following: GitHub - Caweca105/portfolio (it’s public)
Below you’ll find the build log
thank you for your time
1:24:07 PM: Build ready to start
1:24:10 PM: build-image version: d2c6dbeac570350a387d832f64bc980dc964ad65 (focal)
1:24:10 PM: build-image tag: v4.8.0
1:24:10 PM: buildbot version: 5271e9715084f43bb9084ec0da517d4a5a908ada
1:24:10 PM: Fetching cached dependencies
1:24:10 PM: Failed to fetch cache, continuing with build
1:24:10 PM: Starting to prepare the repo for build
1:24:11 PM: No cached dependencies found. Cloning fresh repo
1:24:11 PM: git clone GitHub - Caweca105/portfolio
1:24:12 PM: Preparing Git Reference refs/heads/Main
1:24:12 PM: Parsing package.json dependencies
1:24:13 PM: Starting build script
1:24:13 PM: Installing dependencies
1:24:13 PM: Python version set to 2.7
1:24:14 PM: Downloading and installing node v16.15.0…
1:24:14 PM: Downloading https://nodejs.org/dist/v16.15.0/node-v16.15.0-linux-x64.tar.xz…
1:24:15 PM: Computing checksum with sha256sum
1:24:15 PM: Checksums matched!
1:24:18 PM: Now using node v16.15.0 (npm v8.5.5)
1:24:18 PM: Started restoring cached build plugins
1:24:18 PM: Finished restoring cached build plugins
1:24:19 PM: Attempting ruby version 2.7.2, read from environment
1:24:20 PM: Using ruby version 2.7.2
1:24:20 PM: Using PHP version 8.0
1:24:21 PM: No npm workspaces detected
1:24:21 PM: Started restoring cached node modules
1:24:21 PM: Finished restoring cached node modules
1:24:21 PM: Installing NPM modules using NPM version 8.5.5
1:24:28 PM: npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
1:24:33 PM: npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
1:24:40 PM: added 627 packages, and audited 628 packages in 19s
1:24:40 PM: 94 packages are looking for funding
1:24:40 PM: run npm fund for details
1:24:40 PM: 1 moderate severity vulnerability
1:24:40 PM: To address all issues (including breaking changes), run:
1:24:40 PM: npm audit fix --force
1:24:40 PM: Run npm audit for details.
1:24:40 PM: NPM modules installed
1:24:41 PM: Started restoring cached go cache
1:24:41 PM: Finished restoring cached go cache
1:24:41 PM: go version go1.16.5 linux/amd64
1:24:41 PM: Installing missing commands
1:24:41 PM: Verify run directory
1:24:43 PM:
1:24:43 PM: ────────────────────────────────────────────────────────────────
1:24:43 PM: Netlify Build
1:24:43 PM:
1:24:43 PM: ❯ Version
1:24:43 PM: @netlify/build 27.0.1
1:24:43 PM:
1:24:43 PM: ❯ Flags
1:24:43 PM: baseRelDir: true
1:24:43 PM: buildId: 626fcd670b43700009930139
1:24:43 PM: deployId: 626fcd670b4370000993013b
1:24:43 PM:
1:24:43 PM: ❯ Current directory
1:24:43 PM: /opt/build/repo
1:24:43 PM:
1:24:43 PM: ❯ Config file
1:24:43 PM: No config file was defined: using default values.
1:24:43 PM:
1:24:43 PM: ❯ Context
1:24:43 PM: production
1:24:43 PM:
1:24:43 PM: ❯ Installing plugins
1:24:43 PM: - @netlify/plugin-nextjs@4.6.0
1:24:57 PM:
1:24:57 PM: ❯ Loading plugins
1:24:57 PM: - @netlify/plugin-nextjs@4.6.0 from Netlify app
1:24:59 PM:
1:24:59 PM: ────────────────────────────────────────────────────────────────
1:24:59 PM: 1. @netlify/plugin-nextjs (onPreBuild event)
1:24:59 PM:
1:24:59 PM: No Next.js cache to restore.
1:24:59 PM: Netlify configuration property “build.environment.NEXT_PRIVATE_TARGET” value changed.
1:24:59 PM:
1:24:59 PM: (@netlify/plugin-nextjs onPreBuild completed in 22ms)
1:24:59 PM:
1:24:59 PM: 2. Build command from Netlify app
1:24:59 PM:
1:24:59 PM: $ CI=‘’ npm run build
1:25:00 PM: > portfolio@1.0.8 build
1:25:00 PM: > npm run dev
1:25:00 PM: > portfolio@1.0.8 dev
1:25:00 PM: > next dev -H 0.0.0.0
1:25:01 PM: ready - started server on 0.0.0.0:3000, url: http://localhost:3000
1:25:01 PM: info - Using webpack 5. Reason: Enabled by default webpack5 | Next.js
1:25:18 PM: event - compiled successfully
2:00:08 PM: wait - compiling…
2:00:08 PM: Build exceeded maximum allowed runtime
2:00:09 PM: event - compiled successfully
2:00:09 PM: wait - compiling…
2:00:09 PM: error - Module not found: Error: Can’t resolve ‘./node_modules/next/dist/client/dev/amp-dev’ in ‘/opt/build/repo’
wait - compiling…
2:00:09 PM: [webpack.cache.PackFileCacheStrategy] Caching failed for pack: Error: ENOENT: no such file or directory, stat ‘/opt/build/repo/.next/cache/webpack/client-development/0.pack’
2:00:09 PM: [webpack.cache.PackFileCacheStrategy] Caching failed for pack: Error: ENOENT: no such file or directory, stat ‘/opt/build/repo/.next/cache/webpack/server-development/0.pack’
