Hi, @cpenned, I’m not sure why you are running netlify lm:setup.
I’m showing this site already has Large Media configured for it. Are you trying to push your content to Large Media? If so what happens when you run this command?
git lfs push --all origin
Is that command successful? If not, please send us the output of the following as a private message (PM):
GIT_TRACE=true GIT_CURL_VERBOSE=true git lfs push --all origin
I’m assuming below that Netlify CLI (the npm package netlify-cli) is installed globally.
I would recommend running the following commands to make sure the dependencies are in place for this to work.
First, let’s sure the latest Netlify CLI tool is installed with this:
npm install netlify-cli -g
Next, check that the Large Media the plugin is installed for Netlify CLI itself:
netlify plugins:install netlify-lm-plugin
netlify lm:install
If all that is successful, please try this again:
netlify lm:setup
If this allows pushing to the site, please let us know.
However, if it still doesn’t work, then please run these two command:
cat .netlify/state.json
netlify lm:info
Then would you please private message (PM) me a copy/paste of the output of all of these commands above from the terminal/shell (every command in this reply)? I’ve confirmed PMs are enabled for you account.
If there are questions about any of this, please let us know.
