jspdf-autoTable Library only does not work in deployment
I have a problem importing the jspdf-autoTable library, when working from localhost it works correctly but when uploading the page it tells me react_devtools_backend_compact.js:2367 The data should be an object or array, is: undefined.
My site name is: https://cerimonial-pr.netlify.app/
Hi @kamiladicordeiro, thanks for the post and welcome.
Can you try to import the jspdf-autotable package using the below?
import jsPDF from 'jspdf'
import 'jspdf-autotable'
const doc = new jsPDF()
// Sample code to convert table to pdf.
doc.autoTable({ html: '#my-table' })
doc.save('table.pdf')
Once you make the changes redeploy again to see if it works.
Thanks.
