Hugo based site not deploying
6:36:27 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
6:36:26 PM: Netlify Build
6:36:26 PM: ────────────────────────────────────────────────────────────────
6:36:26 PM: ​
6:36:26 PM: ❯ Version
6:36:26 PM: @netlify/build 29.18.0
6:36:26 PM: ​
6:36:26 PM: ❯ Flags
6:36:26 PM: baseRelDir: true
6:36:26 PM: buildId: 64d19c03e2c6c815780720c8
6:36:26 PM: deployId: 64d19c03e2c6c815780720ca
6:36:26 PM: ​
6:36:26 PM: ❯ Current directory
6:36:26 PM: /opt/build/repo
6:36:26 PM: ​
6:36:26 PM: ❯ Config file
6:36:26 PM: No config file was defined: using default values.
6:36:26 PM: ​
6:36:26 PM: ❯ Context
6:36:26 PM: production
6:36:26 PM: ​
6:36:26 PM: Build command from Netlify app
6:36:26 PM: ​
6:36:26 PM: $ cecil build
6:36:26 PM: bash: cecil: command not found
6:36:26 PM: ​
6:36:26 PM: build.command failed
6:36:26 PM: ​
6:36:26 PM: Error message
Site repeatedly failing on deployment,. Used Hugo to build site. Am I missing a line in my config file, netlify can’t read my config file, or something wrong with index.json?
6:36:26 PM: Command failed with exit code 127: cecil build (Search results for '"non-zero exit code: 127"' - Netlify Support Forums)
6:36:26 PM: ​
6:36:26 PM: Error location
6:36:26 PM: In Build command from Netlify app:
6:36:26 PM: cecil build
6:36:26 PM: ​
6:36:26 PM: Resolved config
6:36:26 PM: build:
6:36:26 PM: command: cecil build
6:36:26 PM: commandOrigin: ui
6:36:26 PM: publish: /opt/build/repo/_site
6:36:26 PM: publishOrigin: ui
6:36:27 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
6:36:27 PM: Failing build: Failed to build site
6:36:28 PM: Finished processing build request in 17.58s
Hi there, glad you found us :wave:t6: before we can help you, we need a little more information on the issues you are facing.
First, have you looked through this resource? It is a compilation of all of our build and deploy resources. This is a good starting point.
If you have worked through those guides and are still encountering issues please share the following information:
  • the name of your build instance: “example-jones.netlify.com
  • what you have already tried
  • any error messages you have received in your terminal window or in the developer console
thanks I will look into this
Hi, @Bobbi888. The error message is here:
You are running a command that doesn’t exist (the command cecil).
I’m not familiar with that command. I definitely is not a default program installed in our build system. What is that command?
It looks like it might be this:
If so, I don’t see anything in the logs you shared to show how you are installing that program at Netlify. What steps have you taken to install that command in the build system?
