$ netlify dev
◈ Netlify Dev ◈
{ JSONHTTPError: Not Found
at NetlifyAPI.getSite (/usr/local/lib/node_modules/netlify-cli/node_modules/netlify/src/open-api/index.js:162:15)
at processTicksAndRejections (internal/process/next_tick.js:81:5)
status: 404,
json: { code: 404, message: ‘Not Found’ } }
◈ Error retrieving site data for site 9ab7…snip…b1b5fa. Double-check your login status with ‘netlify status’ or contact support with details of your error.
(netlify status returns valid info)
It appears that I have screwed this up at some point in the past; most likely when I deleted the project on netlify.com and started over. The site referenced in the error message is not the site ID for the current incarnation of the project on netlify.com. I do not consider this a bug but it does pose the problem: “how to recover and start over” with Netlify Dev.
I am successfully using Netlify Dev on other projects.
