I would like to give other users access to log in to netlifycms in admin mode.
How do I do this?
Hi @royonk85,
If you are using Git Gateway with Netlify Identity you can add the code below to your config.yml
file in the admin folder
config.yml file
backend:
accept_roles: #optional - accepts all users if left out
- admin
The above code means that only users with a role called admin can only login to the CMS.
Once you are done you can assign roles to users in your Netlify dashboard, and then limit which roles can access the CMS by defining the accept_roles
field in the config.yml
example above.
You can ready about how to add users in your Netlify dashboard UI at https://www.netlify.com/blog/2019/02/21/the-role-of-roles-and-how-to-set-them-in-netlify-identity/
Hope this helps
Thank you for your answer
