I have a Hugo menu setup like this in config.toml
[menu]
[[menu.main]]
identifier = "home"
name = "Home"
url = "/"
weight = 1
And in my Netlify CMS config.yml
, I have this:
collections:
- label: "Config"
files:
- label: "Config"
file: "config.toml"
fields:
- {label: "Title", name: title, widget: string}
- label: "Menu"
widget: object
fields:
- {label: "Identifier", name: identifier, widget: string}
- {label: "Name", name: name, widget: string}
- {label: "URL", name: url, widget: string}
- {label: "Order", name: weight, widget: number}
However, it seems that Netlify CMS writes to [menu]
instead of [[menu.main]]
. How do I map the field to a nested array of tables?
Almost there! Try nesting the fields in another object called main
Thanks for the quick response—that worked almost! Only thing is the fields are not parsed as expected…
Config updated to:
- label: "Settings"
files:
- label: "Config"
file: "config.toml"
fields:
- label: "Menu"
widget: object
fields:
- label: "Main"
widget: object
fields:
Screenshot of fields in the UI:
I wasn’t looking closely enough. Converted to yaml, your data looks like this:
menu:
main:
- identifier: home
url: /
weight: 1
main
is actually an array and you should therefore use a list widget, not an object. The list map values in the field inputs gave it away.
Success! Thank you @tomrutgers!
Side note: Hugo orders menu items by the weight
property but the list widget has drag and drop sorting which doesn’t affect the weight
. It would be great if drag and drop could be disabled. Or if drag and drop could update weight.
You can open a feature request over at GitHub
