Help with .well-known/assetlinks.json file for PWA
Hi! i am facing an issue where i have to hard refresh (shift + refresh) so netlify serve the assetlink.json file instead of the homepage.
https://visionlatinapanama.com/.well-known/assetlinks.json
I already have a netlify.toml deployed
[[redirects]]
  from = "/.well-known/assetlinks.json"
  to = "/well-known/assetlinks.json"
  status = 200
 [redirects.headers]
    cache-control = "no-store"
[[headers]]
  for = "/well-known/assetlinks.json"
  [headers.values]
    Content-Type = "application/manifest+json"
[[redirects]]
  from = "/*"
  to = "/index.html"
  status = 200
[[headers]]
  for = "/manifest.webmanifest"
  [headers.values]
[[headers]]
  for = "/assets/*"
  [headers.values]
    cache-control = '''
    max-age=31536000,
    immutable
type or paste code here
i took ideas from varius already existing threads and as i said. It kinda works but only if i enter to that route and shift refresh, only then the file will be served correctly
----- other details
is a PWA created with Vue3 and vite. i already bubble wrapped it and test it with lighthouse
I directly entered the URL into a browser and the JSON file loaded.
The TOML is correct in terms of redicts format/order. Likely the issue is to do with a local caching (computer/network.) You can test this by directly entering the URL into a private/incognito window to see if it loads correctly.
You are right! Have been some hours tho and still i cannot see them outside of incognito. but if it works there sure playstore should work to! thanks for corroborating
