Please help with build settings for the following as loading page is blank. Have read other threads but still can’t work it out.
allcaregroup.netifly.app
Github Repository: https://github.com/levitenamu/allcare-portal
Current build settings:
@levitenamu Since your project is AI generated, have you asked the AI you used to generate it?
Note: The repository that you’ve linked is private.
Oh wow thank you that worked… much appreciated
