I’m doing a website for myself using lovable.dev. and the first time I upload the website do Netlify everything went smooth, I did a few changes on the website using lovable and the website updated automatically, no problems, yesterday I tried doing a new update, but it didn’t went thru, so unliked Netlify from the git repo and linked again, but I can’t either understand the error I get and nor understand the solution, I’m a first time sailor in the world so im seeking help my lovable website link is: clicksugar.netlify.app
and here are som screenshots of what I was able to see about the error
ERROR:
11:15:32 AM: Netlify Build
11:15:32 AM: ────────────────────────────────────────────────────────────────
11:15:32 AM:
11:15:32 AM: ❯ Version
11:15:32 AM: @netlify/build 29.59.1
11:15:32 AM:
11:15:32 AM: ❯ Flags
11:15:32 AM: accountId: 67b76823eb8ae40096adc3e4
11:15:32 AM: baseRelDir: true
11:15:32 AM: buildId: 67bf21b5d9cf788178c154a3
11:15:32 AM: deployId: 67bf21b5d9cf788178c154a5
11:15:32 AM:
11:15:32 AM: ❯ Current directory
11:15:32 AM: /opt/build/repo
11:15:32 AM:
11:15:32 AM: ❯ Config file
11:15:32 AM: No config file was defined: using default values.
11:15:32 AM:
11:15:32 AM: ❯ Context
11:15:32 AM: production
11:15:32 AM:
11:15:32 AM: Build command from Netlify app
11:15:32 AM:
11:15:32 AM: $ bun run
11:15:32 AM: mise ERROR Tool not installed for shim: bun
11:15:32 AM: Missing tool version: core:bun@1.2.3
11:15:32 AM: Install all missing tools with: mise install
11:15:32 AM: mise ERROR Run with --verbose or MISE_VERBOSE=1 for more information
11:15:32 AM:
11:15:32 AM: “build.command” failed
11:15:32 AM:
11:15:32 AM: Error message
11:15:32 AM: Command failed with exit code 1: bun run (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
11:15:32 AM:
11:15:32 AM: Error location
11:15:32 AM: In Build command from Netlify app:
11:15:32 AM: bun run
11:15:32 AM:
11:15:32 AM: Resolved config
11:15:32 AM: build:
11:15:32 AM: command: bun run
11:15:32 AM: commandOrigin: ui
11:15:32 AM: publish: /opt/build/repo/dist
11:15:32 AM: publishOrigin: ui
11:15:33 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
11:15:33 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
11:15:33 AM: Failing build: Failed to build site
11:15:33 AM: Finished processing build request in 1m10.235s
ASK NETLFY ASNWER:
Diagnosis: The build failure seems to be caused by missing dependencies.
Solution:
- Verify that all the required packages are listed in the
package.jsonfile or have been committed to the repository. - If the packages are missing, add them to the
package.jsonfile. - Make sure all necessary files are committed to the repository before attempting the build again.
