Help Request Regarding my domain
  • We need to know your netlify site name. Example: influmart.netlify.app
  • DNS issues? influmart.in or one of its subdomains is already managed by Netlify DNS on another team.
  • Did you try Ask Netlify, our generative AI chatbot, before posting? yes but I doesn’t get proper answer. I am using squarespace domain for my domain name.
please help me to get back my domain.
@influmart.social You need to follow this support guide:
The value that you would use is: https://answers.netlify.com/t/help-request-regarding-my-domain/124013
I doesn’t get it. i am using squarespace. can you please tell me how to procced.
@influmart.social The important part of the guide is this bit:
To do this, you’ll have to create a DNS record that we then check:
  1. Go to do your domain host (Bluehost, Gandi, Google, etc.)
  2. Add a TXT record with the following characteristics:
  • Name: verified-for-netlify (some DNS hosts will want the dot at the end, so try creating the record both with and without it if the first attempt doesn’t work)
  • TTL: default
  • Text/Value: link to your public post or case number if we’re helping you in our helpdesk
If Squarespace is who you have your domain through, then that’s where you would do it.
Squarespace’s documentation seems to be here:
https://support.squarespace.com/hc/en-us/articles/360002101888-Adding-custom-DNS-records-to-your-Squarespace-managed-domain
You are looking for the section with the title TXT records
