Help Needed: Broken Links & Missing CMS Content After Deploying Webflow/Udesly Site to Netlify
Hi everyone,
I built my site in Webflow using CMS collections and then exported all. To get the CMS functionality working on, I ran it through Udesly. The automatic GitHub upload didn’t work for me, so I manually committed everything to my GitHub repo. After that, I connected the repo to Netlify and triggered a deploy.
When I visit the live site, I see that some of my images and svg links are broken—even though the files are definitely in my repo and the paths look correct. On top of that, some of the CMS-driven text or DIVs aren’t appear. For example, I created a filterable search using Finsweet: the search still returns results, but some projects are duplicated, and the filters that rely on my CMS fields (like the city label on each project) no longer work because those elements never render.
Has anyone dealt with missing CMS content or asset link failures when deploying a Webflow + Udesly project to Netlify? Are there particular Netlify settings or environment variables I need to set for Udesly to inject the CMS data properly?
Thanks so much in advance—any advice or pointers would really help!
@Erick1 If the output that you’ve created is a static site, try hosting it locally to check it for issues.
You could use npx serve for example.
https://www.npmjs.com/package/serve
Doing so should help you to immediately isolate which side the problem is on.
If you would like a community member to take a look you’ll have to provide a link to a public repository.
