[HELP] - Build is not working anymore - glib: XML parse error
Site ID: 69ec1922-edd0-47b4-bd0e-36c2d7115dfe
Type: Gatsby website
Build is failing with:
error Input buffer has corrupt header: glib: XML parse error: Error domain 1 code 77 on line 151 column 1 of data: Premature end of data in tag meta line 4
1:45:22 PM:
1:45:22 PM:
1:45:22 PM: Error: Input buffer has corrupt header: glib: XML parse error: Error domain 1 code 77 on line 151 column 1 of data: Premature end of data in tag meta line 4
1:45:22 PM: error Input buffer has corrupt header: glib: XML parse error: Error domain 1 code 77 on line 151 column 1 of data: Premature end of data in tag meta line 4
1:45:22 PM: glib: XML parse error: Error domain 1 code 77 on line 151 column 1 of data: Premature end of data in tag meta line 4
1:45:22 PM:
1:45:22 PM:
1:45:22 PM: Error: Input buffer has corrupt header: glib: XML parse error: Error domain 1 code 77 on line 151 column 1 of data: Premature end of data in tag meta line 4 glib: XML parse error: Error domain 1 code 77 on line 151 column 1 of data: Pr emature end of data in tag meta line 4
1:45:22 PM:
1:45:22 PM: error An error occurred during parallel query running.
1:45:22 PM: Go here for troubleshooting tips: Parallel Query Running · gatsbyjs/gatsby · Discussion #32389 · GitHub
1:45:22 PM:
1:45:22 PM:
1:45:22 PM: Error: Worker exited before finishing task
Local build works (rpm start and rpm run build), we haven’t really changed much, just added an image.
We have to deploy something due to stock relevancy, so this is super hurtful right now. Any help appreciated!
Hi @flobauer,
Thanks for reaching out! Sorry to hear about the issue.
I do see the error here:
It’s not an error I’m familiar with but I found this Netlify Forum post that had a solution:
Could you give that a read and see if it help you resolve this issue?
If the issue persists, we recommend beginning with the following our Support Guide on troubleshooting builds:
As I can build locally with exactly the same datasources, that doesn’t really help… Git revert doesn’t work either, I dont know how to solve this issue…
I removed the repo, did a fresh git clone, use npm 18 for build, all works locally.
