Netlify sitename: ottawa-custom-furniture.netlify.app
My builds have been continually failing during deployment of a Gatsby site, and there doesn’t seem to be a particular reason why. From researching the issue it could be memory-related, but that doesn’t make much sense here considering this site is extremely small - it’s a one-pager and the few assets that exist have been optimized. Any suggestions would be appreciated! There is very little info about this anywhere.
DEPLOY LOG:
2:12:36 PM: Build ready to start
2:12:38 PM: build-image version: ac716c5be7f79fe384a0f3759e8ef612cb821a37 (xenial)
2:12:38 PM: build-image tag: v3.13.0
2:12:38 PM: buildbot version: e58b6be665675c0f99b33132a8c1eec1f775eba1
2:12:38 PM: Fetching cached dependencies
2:12:38 PM: Starting to download cache of 398.6MB
2:12:42 PM: Finished downloading cache in 4.352037639s
2:12:42 PM: Starting to extract cache
2:12:54 PM: Finished extracting cache in 11.934722933s
2:12:54 PM: Finished fetching cache in 16.340267033s
2:12:54 PM: Starting to prepare the repo for build
2:12:55 PM: Preparing Git Reference refs/heads/production
2:13:00 PM: Parsing package.json dependencies
2:13:01 PM: Starting build script
2:13:01 PM: Installing dependencies
2:13:01 PM: Python version set to 2.7
2:13:02 PM: Started restoring cached node version
2:13:04 PM: Finished restoring cached node version
2:13:05 PM: v12.18.0 is already installed.
2:13:05 PM: Now using node v12.18.0 (npm v6.14.4)
2:13:05 PM: Started restoring cached build plugins
2:13:05 PM: Finished restoring cached build plugins
2:13:06 PM: Attempting ruby version 2.7.1, read from environment
2:13:06 PM: Started restoring cached ruby version
2:13:06 PM: Finished restoring cached ruby version
2:13:08 PM: Using ruby version 2.7.1
2:13:08 PM: Using PHP version 5.6
2:13:09 PM: No npm workspaces detected
2:13:09 PM: Started restoring cached node modules
2:13:09 PM: Finished restoring cached node modules
2:13:09 PM: Started restoring cached go cache
2:13:09 PM: Finished restoring cached go cache
2:13:09 PM: go version go1.14.4 linux/amd64
2:13:09 PM: Installing missing commands
2:13:09 PM: Verify run directory
2:13:11 PM:
2:13:11 PM: ────────────────────────────────────────────────────────────────
2:13:11 PM: Netlify Build
2:13:11 PM:
2:13:11 PM: ❯ Version
2:13:11 PM: @netlify/build 27.0.1
2:13:11 PM:
2:13:11 PM: ❯ Flags
2:13:11 PM: baseRelDir: true
2:13:11 PM: buildId: 62670ec49a759900091dd350
2:13:11 PM: deployId: 62670ec49a759900091dd352
2:13:11 PM:
2:13:11 PM: ❯ Current directory
2:13:11 PM: /opt/build/repo
2:13:11 PM:
2:13:11 PM: ❯ Config file
2:13:11 PM: No config file was defined: using default values.
2:13:11 PM:
2:13:11 PM: ❯ Context
2:13:11 PM: production
2:13:11 PM:
2:13:11 PM: 1. Build command from Netlify app
2:13:11 PM:
2:13:11 PM: $ npm run build
2:13:12 PM: > gatsby-starter-default@0.1.0 build /opt/build/repo
2:13:12 PM: > gatsby build
2:13:16 PM: success open and validate gatsby-configs - 0.080s
2:13:16 PM: warning Plugin gatsby-plugin-google-gtag is not compatible with your gatsby version 3.4.1 - It requires gatsby@^4.0.0-next
2:13:16 PM: warning Plugin gatsby-source-contentful is not compatible with your gatsby version 3.4.1 - It requires gatsby@^4.0.0-next
2:13:16 PM: warning Plugin gatsby-plugin-sitemap is not compatible with your gatsby version 3.4.1 - It requires gatsby@^4.0.0-next
2:13:17 PM: warning Plugin gatsby-plugin-google-gtag is not compatible with your gatsby version 3.4.1 - It requires gatsby@^4.0.0-next
2:13:17 PM: warning Plugin gatsby-source-contentful is not compatible with your gatsby version 3.4.1 - It requires gatsby@^4.0.0-next
2:13:17 PM: warning Plugin gatsby-plugin-sitemap is not compatible with your gatsby version 3.4.1 - It requires gatsby@^4.0.0-next
2:13:17 PM: success load plugins - 1.540s
2:13:17 PM: success onPreInit - 0.046s
2:13:17 PM: success initialize cache - 0.005s
2:13:17 PM: success copy gatsby files - 0.055s
2:13:17 PM: success onPreBootstrap - 0.012s
2:13:17 PM: success createSchemaCustomization - 0.179s
2:13:18 PM: success Contentful: Sync all items - 0.174s - 8/8 46.09/s
2:13:18 PM: info Contentful: 7 new/updated entries
2:13:18 PM: info Contentful: 0 deleted entries
2:13:18 PM: info Contentful: 0 cached entries
2:13:18 PM: info Contentful: 1 new/updated assets
2:13:18 PM: info Contentful: 0 cached assets
2:13:18 PM: info Contentful: 0 deleted assets
2:13:18 PM: success Contentful: Fetch data (yz3pi6anpbei-master) - 0.453s
2:13:18 PM: info Creating 1 Contentful Home nodes
2:13:18 PM: info Creating 1 Contentful Work nodes
2:13:18 PM: info Creating 1 Contentful About nodes
2:13:18 PM: info Creating 1 Contentful FAQ Box One nodes
2:13:18 PM: info Creating 1 Contentful Faq Box Two nodes
2:13:18 PM: info Creating 1 Contentful Get a Quote nodes
2:13:18 PM: info Creating 1 Contentful Quote Success Page nodes
2:13:18 PM: info Creating 1 Contentful asset nodes
2:13:18 PM: success Contentful: Create nodes (yz3pi6anpbei-master) - 0.027s
2:13:18 PM: success Contentful: Process data (yz3pi6anpbei-master) - 0.033s
2:13:18 PM: success Checking for changed pages - 0.000s
2:13:18 PM: success source and transform nodes - 0.792s
2:13:20 PM: success building schema - 1.423s
2:13:20 PM: success createPages - 0.006s
2:13:20 PM: success createPagesStatefully - 0.118s
2:13:20 PM: info Total nodes: 112, SitePage nodes: 6 (use --verbose for breakdown)
2:13:20 PM: success Checking for changed pages - 0.004s
2:13:20 PM: success update schema - 0.250s
2:13:20 PM: success onPreExtractQueries - 0.002s
2:13:37 PM: success extract queries from components - 16.833s
2:14:18 PM: Killed
2:14:18 PM: /opt/build-bin/build: line 93: 1462 Killed FORCE_COLOR=1 “$netlify_build_node_bin” “$netlify_build_bin” --cwd="$repository_root" --repositoryRoot="$repository_root" --branch="$branch" --siteId="$site_id" --defaultConfig="$default_config" --baseRelDir="$base_rel_dir" --context="$context" --node-path="$user_node_path" --cachedConfigPath="$cached_netlify_build_config_file" --api-host="$netlify_endpoint" --token="$netlify_token" --build-id="$BUILD_ID" --deploy-id="$DEPLOY_ID" --mode=“buildbot” --telemetry="$build_telemetry" --send-status --save-config --statsd.host="$DATADOG_HOST" --statsd.port="$STATSD_PORT" --functions-dist-dir="$functions_dist_dir" --edge-functions-dist-dir="$edge_functions_dist_dir" --cache-dir="$cache_dir" --buildbot-server-socket="$buildbot_server_socket" --framework="$framework" --feature-flags="$feature_flags" --testOpts.silentLingeringProcesses="$SILENT_LINGERING_PROCESSES"
2:14:18 PM: Caching artifacts
2:14:18 PM: Started saving node modules
2:14:18 PM: Finished saving node modules
2:14:18 PM: Started saving build plugins
2:14:18 PM: npm ERR! code ELIFECYCLE
2:14:18 PM: npmFinished saving build plugins
2:14:18 PM: ERR! errno 137
2:14:18 PM: Started saving pip cache
2:14:18 PM: npm ERR! gatsby-starter-default@0.1.0 build: gatsby build
2:14:18 PM: Creating deploy upload records
2:14:18 PM: npm ERR! Exit status 137
2:14:18 PM: npm ERR! Failed at the gatsby-starter-default@0.1.0 build script.
2:14:18 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2:14:18 PM: npm ERR! A complete log of this run can be found in:
2:14:18 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-04-25T21_14_18_676Z-debug.log
2:14:19 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 137 (Search results for '"non-zero exit code: 137"' - Netlify Support Forums)
2:14:18 PM: Finished saving pip cache
2:14:18 PM: Started saving emacs cask dependencies
2:14:18 PM: Finished saving emacs cask dependencies
2:14:18 PM: Started saving maven dependencies
2:14:18 PM: Finished saving maven dependencies
2:14:18 PM: Started saving boot dependencies
2:14:18 PM: Finished saving boot dependencies
2:14:18 PM: Started saving rust rustup cache
2:14:18 PM: Finished saving rust rustup cache
2:14:18 PM: Started saving go dependencies
2:14:18 PM: Finished saving go dependencies
2:14:18 PM: Error running command: Build script returned non-zero exit code: 137
2:14:19 PM: Failing build: Failed to build site
2:14:19 PM: Finished processing build request in 1m41.080491596s
