Running into an error when deploying a Gatsby v4 site that uses DSG. DSG works fine when running locally or when using netlify dev.
Sample site: https://suspicious-minsky-7de6ab.netlify.app/
Sample repo: Viet Le / Dsg Test · GitLab
Steps to reproduce (if not cloning the above sample repo)
- Create new Gatsby project using the official blog starter (
gatsby new dsg-test https://github.com/gatsbyjs/gatsby-starter-blog) - Follow Netlify’s instructions regarding Gatsby v4 and DSG here: GitHub - netlify/netlify-plugin-gatsby: A build plugin to integrate Gatsby seamlessly with Netlify
- In
gatsby-node.js, update the blog posts to use DSG (add:defer: trueto the options passed into createPage) - Deploy to Netlify
- Visit the home page and click into one of the blog entries.
You should see:
{“errorMessage”:“RequestId: 952d2102-13fe-4549-9f87-a10c0d2138ee Error: Runtime exited with error: exit status 7”,“errorType”:“Runtime.ExitError”}
Function log for __dsg:
6:35:59 PM: 2021-10-29T01:35:59.668Z undefined INFO directory already exists
6:36:02 PM: ERROR
6:36:02 PM: Uncaught Exception {“errorType”:“Error”,“errorMessage”:“Module did not
6:36:02 PM: self-register: ‘/var/task/.cache/query-engine/assets/prebuilds/linux-x64/node.ab
6:36:02 PM: i93.node’.”,“stack”:[“Error: Module did not self-register:
6:36:02 PM: ‘/var/task/.cache/query-engine/assets/prebuilds/linux-x64/node.abi93.node’.”,"
6:36:02 PM: at Object.Module._extensions…node (internal/modules/cjs/loader.js:1131:18)“,”
6:36:02 PM: at Module.load (internal/modules/cjs/loader.js:937:32)“,” at
6:36:02 PM: Function.Module._load (internal/modules/cjs/loader.js:778:12)“,” at
6:36:02 PM: Module.require (internal/modules/cjs/loader.js:961:19)“,” at require
6:36:02 PM: (internal/modules/cjs/helpers.js:92:18)“,” at Object.
6:36:02 PM: (/var/task/.cache/query-engine/index.js:194990:24)“,” at webpack_require
6:36:02 PM: (/var/task/.cache/query-engine/index.js:451717:42)“,” at Object.
6:36:02 PM: (/var/task/.cache/query-engine/index.js:194720:18)“,” at webpack_require
6:36:02 PM: /var/task/.cache/query-engine/index.js:451844:22"," at
6:36:02 PM: /var/task/.cache/query-engine/index.js:451984:3"," at Object.
6:36:02 PM: (/var/task/.cache/query-engine/index.js:451989:12)“,” at Module._compile
6:36:02 PM: (internal/modules/cjs/loader.js:1072:14)“,” at Object.Module._extensions…js
6:36:02 PM: (internal/modules/cjs/loader.js:1101:10)“,” at Module.load
6:36:02 PM: (internal/modules/cjs/loader.js:937:32)“,” at Function.Module._load
6:36:02 PM: (internal/modules/cjs/loader.js:778:12)“]}
6:36:02 PM: /var/task/.cache/query-engine/index.js:183402
6:36:02 PM: throw ex;
6:36:02 PM: ^
6:36:02 PM: Error: Module did not self-register: ‘/var/task/.cache/query-engine/assets/prebuilds/linux-x64/node.abi93.node’.
6:36:02 PM: at Function.Module._load (internal/modules/cjs/loader.js:778:12)
6:36:02 PM: at Module.require (internal/modules/cjs/loader.js:961:19)
6:36:02 PM: at require (internal/modules/cjs/helpers.js:92:18)
6:36:02 PM: at Object. (/var/task/.cache/query-engine/index.js:194990:24)
6:36:02 PM: at webpack_require (/var/task/.cache/query-engine/index.js:451717:42)
6:36:02 PM: at Object. (/var/task/.cache/query-engine/index.js:194720:18)
6:36:02 PM: at /var/task/.cache/query-engine/index.js:451844:22
6:36:02 PM: at /var/task/.cache/query-engine/index.js:451984:3
6:36:02 PM: at Object. (/var/task/.cache/query-engine/index.js:451989:12)
6:36:02 PM: at Module._compile (internal/modules/cjs/loader.js:1072:14)
6:36:02 PM: at Object.Module._extensions…js (internal/modules/cjs/loader.js:1101:10)
6:36:02 PM: 952d2102 Duration: 2736.95 ms Memory Usage: 155 MB 6:36:02 PM: RequestId: 952d2102-13fe-4549-9f87-a10c0d2138ee Error: Runtime exited with error: exit status 7
Runtime.ExitError
6:36:02 PM: 2021-10-29T01:36:02.428Z undefined INFO directory already exists
6:36:03 PM: ERROR
6:36:03 PM: Uncaught Exception {“errorType”:“Error”,“errorMessage”:“Module did not
6:36:03 PM: self-register: ‘/var/task/.cache/query-engine/assets/prebuilds/linux-x64/node.ab
6:36:03 PM: i93.node’.”,“stack”:[“Error: Module did not self-register:
6:36:03 PM: ‘/var/task/.cache/query-engine/assets/prebuilds/linux-x64/node.abi93.node’.”,”
6:36:03 PM: at Object.Module._extensions…node (internal/modules/cjs/loader.js:1131:18)“,”
6:36:03 PM: at Module.load (internal/modules/cjs/loader.js:937:32)“,” at
6:36:03 PM: Function.Module._load (internal/modules/cjs/loader.js:778:12)“,” at
6:36:03 PM: Module.require (internal/modules/cjs/loader.js:961:19)“,” at require
6:36:03 PM: (internal/modules/cjs/helpers.js:92:18)“,” at Object.
6:36:03 PM: (/var/task/.cache/query-engine/index.js:194990:24)“,” at webpack_require
6:36:03 PM: (/var/task/.cache/query-engine/index.js:451717:42)“,” at Object.
6:36:03 PM: (/var/task/.cache/query-engine/index.js:194720:18)“,” at webpack_require
6:36:03 PM: /var/task/.cache/query-engine/index.js:451844:22"," at
6:36:03 PM: /var/task/.cache/query-engine/index.js:451984:3"," at Object.
6:36:03 PM: (/var/task/.cache/query-engine/index.js:451989:12)“,” at Module._compile
6:36:03 PM: (internal/modules/cjs/loader.js:1072:14)“,” at Object.Module._extensions…js
6:36:03 PM: (internal/modules/cjs/loader.js:1101:10)“,” at Module.load
6:36:03 PM: (internal/modules/cjs/loader.js:937:32)“,” at Function.Module._load
6:36:03 PM: (internal/modules/cjs/loader.js:778:12)"]}
6:36:03 PM: /var/task/.cache/query-engine/index.js:183402
6:36:03 PM: throw ex;
6:36:03 PM: ^
6:36:03 PM: Error: Module did not self-register: ‘/var/task/.cache/query-engine/assets/prebuilds/linux-x64/node.abi93.node’.
6:36:03 PM: at Function.Module._load (internal/modules/cjs/loader.js:778:12)
6:36:03 PM: at Module.require (internal/modules/cjs/loader.js:961:19)
6:36:03 PM: at require (internal/modules/cjs/helpers.js:92:18)
6:36:03 PM: at Object. (/var/task/.cache/query-engine/index.js:194990:24)
6:36:03 PM: at webpack_require (/var/task/.cache/query-engine/index.js:451717:42)
6:36:03 PM: at Object. (/var/task/.cache/query-engine/index.js:194720:18)
6:36:03 PM: at /var/task/.cache/query-engine/index.js:451844:22
6:36:03 PM: at /var/task/.cache/query-engine/index.js:451984:3
6:36:03 PM: at Object. (/var/task/.cache/query-engine/index.js:451989:12)
6:36:03 PM: at Module._compile (internal/modules/cjs/loader.js:1072:14)
6:36:03 PM: at Object.Module._extensions…js (internal/modules/cjs/loader.js:1101:10)
