- We need to know your netlify site name. Example:
gifted-antelope-58b104.netlify.app - DNS issues? Tell us the custom domain, tell us the error message! We can’t help if we don’t know your domain.
- Build problems? Link or paste the FULL build log & build settings screenshot
- Did you try Ask Netlify, our generative AI chatbot, before posting? It pulls info from Support Guides and recent solved forums posts.
Site name: https://test-doppler.netlify.app/
Build Problem:
12:35:54 PM: > legacy-core@0.0.0 build /opt/build/repo/apps/legacy-core
12:35:54 PM: > npm-run-all -s ‘build:plugin’ ‘build:site’
12:35:55 PM: > legacy-core@0.0.0 build:plugin /opt/build/repo/apps/legacy-core
12:35:55 PM: > pnpm --filter @repo/gatsby-source-rehabpath run build
12:35:55 PM: > @repo/gatsby-source-rehabpath@0.1.0 build /opt/build/repo/packages/gatsby-source-rehabpath
12:35:55 PM: > tsc
12:35:57 PM: > legacy-core@0.0.0 build:site /opt/build/repo/apps/legacy-core
12:35:57 PM: > pnpm run build:plugin && gatsby build
12:35:58 PM: > legacy-core@0.0.0 build:plugin /opt/build/repo/apps/legacy-core
12:35:58 PM: > pnpm --filter @repo/gatsby-source-rehabpath run build
12:35:58 PM: > @repo/gatsby-source-rehabpath@0.1.0 build /opt/build/repo/packages/gatsby-source-rehabpath
12:35:58 PM: > tsc
12:36:03 PM: |======================|
12:36:03 PM: | GETTING ZYPPY TITLES |
12:36:03 PM: success compile gatsby files - 1.980s
12:36:03 PM: [dotenv@17.2.1] injecting env (0) from .env – tip:
specify custom .env file path with { path: ‘/custom/path/.env’ }
12:36:03 PM: success load gatsby config - 0.037s
12:36:03 PM: info Using gatsby-adapter-netlify adapter
12:36:04 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
12:36:04 PM: error Error in “/opt/build/repo/node_modules/.pnpm/gatsby-transformer-sharp@5.14.0_gatsby-plugin-sharp@5.14.0_gatsby@5.14.6_babel-eslint@1_66f09934705ffd736b9b6dafaedeb133/node_modules/gatsby-transformer-sharp/gatsby-node”:
12:36:04 PM: Something went wrong installing the “sharp” module
12:36:04 PM: Cannot find module ‘../build/Release/sharp-linux-x64.node’
12:36:04 PM: Require stack:
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/sharp@0.32.6/node_modules/sharp/lib/sharp.js
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/sharp@0.32.6/node_modules/sharp/lib/constructor.js
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/sharp@0.32.6/node_modules/sharp/lib/index.js
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/gatsby-plugin-sharp@5.14.0_gatsby@5.14.6_babel-eslint@10.1.0_eslint@8.57.1__encoding@0._02daaa07591772fdedd7505837604269/node_modules/gatsby-plugin-sharp/safe-sharp.js
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/gatsby-plugin-sharp@5.14.0_gatsby@5.14.6_babel-eslint@10.1.0_eslint@8.57.1__encoding@0._02daaa07591772fdedd7505837604269/node_modules/gatsby-plugin-sharp/index.js
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/gatsby-transformer-sharp@5.14.0_gatsby-plugin-sharp@5.14.0_gatsby@5.14.6_babel-eslint@1_66f09934705ffd736b9b6dafaedeb133/node_modules/gatsby-transformer-sharp/customize-schema.js
12:36:04 PM: - /opt/build/repo/node_modules/.pnpm/gatsby-transformer-sharp@5.14.0_gatsby-plugin-sharp@5.14.0_gatsby@5.14.6_babel-eslint@1_66f09934705ffd736b9b6dafaedeb133/node_modules/gatsby-transformer-sharp/gatsby-node.js
12:36:04 PM: Possible solutions:
12:36:04 PM: - Install with verbose logging and look for errors: “npm install --ignore-scripts=false --foreground-scripts --verbose sharp”
12:36:04 PM: - Install for the current linux-x64 runtime: “npm install --platform=linux --arch=x64 sharp”
12:36:04 PM: - Consult the installation documentation: https://sharp.pixelplumbing.com/install
