Hello,
For the site aerial-access-new.netlify.app I am having some building errors, I think it has to do something with the peer dependencies and that these are clashing with wrong versions, I couldn’t resolve it by my own.
1:59:32 PM: Build ready to start
1:59:34 PM: build-image version: 7b53c5fc4445e3ec99d3949e5d1174a8c5be4f16
1:59:34 PM: build-image tag: v3.7.2
1:59:34 PM: buildbot version: a8df6d1263bb5bcc16f7b4ebb8e9a6cb904cfa8a
1:59:34 PM: Fetching cached dependencies
1:59:35 PM: Starting to download cache of 227.2MB
1:59:36 PM: Finished downloading cache in 1.838585209s
1:59:36 PM: Starting to extract cache
1:59:44 PM: Finished extracting cache in 8.040246365s
1:59:44 PM: Finished fetching cache in 9.929391711s
1:59:44 PM: Starting to prepare the repo for build
1:59:45 PM: Preparing Git Reference refs/heads/main
1:59:47 PM: Parsing package.json dependencies
1:59:48 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'public' versus 'public/' in the Netlify UI
1:59:48 PM: Starting build script
1:59:48 PM: Installing dependencies
1:59:48 PM: Python version set to 2.7
1:59:49 PM: Started restoring cached node version
1:59:51 PM: Finished restoring cached node version
1:59:52 PM: v12.18.0 is already installed.
1:59:53 PM: Now using node v12.18.0 (npm v6.14.4)
1:59:53 PM: Started restoring cached build plugins
1:59:53 PM: Finished restoring cached build plugins
1:59:53 PM: Attempting ruby version 2.7.1, read from environment
1:59:54 PM: Using ruby version 2.7.1
1:59:55 PM: Using PHP version 5.6
1:59:55 PM: Started restoring cached node modules
1:59:55 PM: Finished restoring cached node modules
1:59:55 PM: Installing NPM modules using NPM version 6.14.4
2:00:27 PM: npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
npm WARN rm not removing /opt/build/repo/node_modules/.bin/detect as it wasn't installed by /opt/build/repo/node_modules/detect-port-alt
npm WARN rm not removing /opt/build/repo/node_modules/.bin/detect-port as it wasn't installed by /opt/build/repo/node_modules/detect-port-alt
2:00:27 PM: > sharp@0.28.1 install /opt/build/repo/node_modules/gatsby-plugin-sharp/node_modules/sharp
2:00:27 PM: > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
2:00:29 PM: sharp: Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.10.6/libvips-8.10.6-linux-x64.tar.br
2:00:30 PM: > sharp@0.28.1 install /opt/build/repo/node_modules/gatsby-remark-images-contentful/node_modules/sharp
2:00:30 PM: > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
2:00:31 PM: sharp: Using cached /opt/buildhome/.npm/_libvips/libvips-8.10.6-linux-x64.tar.br
2:00:32 PM: > core-js@3.11.0 postinstall /opt/build/repo/node_modules/core-js
2:00:32 PM: > node -e "try{require('./postinstall')}catch(e){}"
2:00:33 PM: > gatsby-telemetry@2.3.0 postinstall /opt/build/repo/node_modules/gatsby-telemetry
2:00:33 PM: > node src/postinstall.js || true
2:00:33 PM: > gatsby-cli@3.3.0 postinstall /opt/build/repo/node_modules/gatsby-cli
2:00:33 PM: > node scripts/postinstall.js
2:00:33 PM: > gatsby@3.3.1 postinstall /opt/build/repo/node_modules/gatsby
2:00:35 PM: npm WARN express-graphql@0.9.0 requires a peer of graphql@^14.4.1 but none is installed. You must install peer dependencies yourself.
2:00:35 PM: npm WARN gatsby-plugin-sass@3.1.0 requires a peer of gatsby@^2.0.0 but none is installed. You must install peer dependencies yourself.
2:00:35 PM: npm WARN gatsby-source-filesystem@2.11.1 requires a peer of gatsby@^2.2.0 but none is installed. You must install peer dependencies yourself.
2:00:35 PM: npm WARN gatsby-transformer-sharp@2.12.1 requires a peer of gatsby@^2.12.1 but none is installed. You must install peer dependencies yourself.
2:00:35 PM: npm WARN gatsby-transformer-sharp@2.12.1 requires a peer of gatsby-plugin-sharp@^2.0.0-beta.3 but none is installed. You must install peer dependencies yourself.
2:00:35 PM: npm WARN ts-node@9.1.1 requires a peer of typescript@>=2.7 but none is installed. You must install peer dependencies yourself.
2:00:35 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/webpack-dev-server/node_modules/fsevents):
2:00:35 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
2:00:35 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
2:00:35 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
2:00:35 PM: added 618 packages from 231 contributors, removed 378 packages, updated 271 packages and audited 2769 packages in 39.479s
2:00:37 PM: 278 packages are looking for funding
2:00:37 PM: run `npm fund` for details
2:00:37 PM: found 0 vulnerabilities
2:00:37 PM: NPM modules installed
2:00:38 PM: Started restoring cached go cache
2:00:38 PM: Finished restoring cached go cache
2:00:38 PM: go version go1.14.4 linux/amd64
2:00:38 PM: Installing missing commands
2:00:38 PM: Verify run directory
2:00:39 PM:
2:00:39 PM: ────────────────────────────────────────────────────────────────
2:00:39 PM: Netlify Build
2:00:39 PM:
2:00:39 PM: ❯ Version
2:00:39 PM: @netlify/build 11.3.2
2:00:39 PM:
2:00:39 PM: ❯ Flags
2:00:39 PM: deployId: 608a9fa4eaa0850007d4c310
2:00:39 PM:
2:00:39 PM: ❯ Current directory
2:00:39 PM: /opt/build/repo
2:00:39 PM:
2:00:39 PM: ❯ Config file
2:00:39 PM: No config file was defined: using default values.
2:00:39 PM:
2:00:39 PM: ❯ Context
2:00:39 PM: production
2:00:39 PM:
2:00:39 PM: 1. Build command from Netlify app
2:00:39 PM:
2:00:39 PM: $ gatsby build
2:00:43 PM: success open and validate gatsby-configs - 0.047s
2:00:43 PM: warning Plugin gatsby-plugin-sass is not compatible with your gatsby version 3.3.1 - It requires gatsby@^2.0.0
2:00:43 PM: warning Plugin gatsby-transformer-sharp is not compatible with your gatsby version 3.3.1 - It requires gatsby@^2.12.1
2:00:43 PM: warning Plugin gatsby-source-filesystem is not compatible with your gatsby version 3.3.1 - It requires gatsby@^2.2.0
2:00:44 PM: warning Warning: there are unknown plugin options for "gatsby-source-filesystem": prettier, eslint, typekit
2:00:44 PM: Please open an issue at ghub.io/gatsby-source-filesystem if you believe this option is valid.
2:00:44 PM: warning Plugin gatsby-plugin-sass is not compatible with your gatsby version 3.3.1 - It requires gatsby@^2.0.0
2:00:44 PM: warning Plugin gatsby-transformer-sharp is not compatible with your gatsby version 3.3.1 - It requires gatsby@^2.12.1
2:00:44 PM: warning Plugin gatsby-source-filesystem is not compatible with your gatsby version 3.3.1 - It requires gatsby@^2.2.0
2:00:44 PM: success load plugins - 1.194s
2:00:44 PM: success onPreInit - 0.048s
2:00:44 PM: success initialize cache - 0.006s
2:00:44 PM: success copy gatsby files - 0.070s
2:00:44 PM: success onPreBootstrap - 0.020s
2:00:44 PM: success createSchemaCustomization - 0.132s
2:00:45 PM: success Contentful: Sync all items - 0.061s - 42/1000 16407.98/s
2:00:45 PM: success Contentful: Fetch data (8cxl6mpst1xl-master) - 0.241s
2:00:45 PM: info Updated entries 15
2:00:45 PM: info Deleted entries 0
2:00:45 PM: info Updated assets 27
2:00:45 PM: info Deleted assets 0
2:00:45 PM: success Contentful: Process data (8cxl6mpst1xl-master) - 0.035s
2:00:45 PM: info Creating 4 Contentful Project nodes
2:00:45 PM: info Creating 4 Contentful ProductCategory nodes
2:00:45 PM: info Creating 7 Contentful Product nodes
2:00:45 PM: info Creating 27 Contentful asset nodes
2:00:45 PM: success Contentful: Create nodes (8cxl6mpst1xl-master) - 0.049s
2:00:45 PM: success Checking for changed pages - 0.000s
2:00:45 PM: success source and transform nodes - 1.002s
2:00:46 PM: error "gatsby-source-contentful" threw an error while running the setFieldsOnGraphQLNodeType lifecycle:
2:00:46 PM: Cannot find module 'gatsby-plugin-image/graphql-utils'
2:00:46 PM: Require stack:
2:00:46 PM: - /opt/build/repo/node_modules/gatsby-source-contentful/extend-node-type.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby-source-contentful/gatsby-node.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/bootstrap/load-plugins/validate.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/bootstrap/load-plugins/load.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/bootstrap/load-plugins/index.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/services/initialize.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/services/index.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/bootstrap/index.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/commands/build.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby-cli/lib/create-cli.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby-cli/lib/index.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/dist/bin/gatsby.js
2:00:46 PM: - /opt/build/repo/node_modules/gatsby/cli.js
2:00:46 PM:
2:00:46 PM:
2:00:46 PM: Error: Cannot find module 'gatsby-plugin-image/graphql-utils'
2:00:46 PM:
2:00:46 PM: - loader.js:966 Function.Module._resolveFilename
2:00:46 PM: internal/modules/cjs/loader.js:966:15
2:00:46 PM:
2:00:46 PM: - loader.js:842 Function.Module._load
2:00:46 PM: internal/modules/cjs/loader.js:842:27
2:00:46 PM:
2:00:46 PM: - loader.js:1026 Module.require
2:00:46 PM: internal/modules/cjs/loader.js:1026:19
2:00:46 PM:
2:00:46 PM: - v8-compile-cache.js:159 require
2:00:46 PM: [repo]/[v8-compile-cache]/v8-compile-cache.js:159:20
2:00:46 PM:
2:00:46 PM: - extend-node-type.js:817 getGatsbyImageData
2:00:46 PM: [repo]/[gatsby-source-contentful]/extend-node-type.js:817:9
2:00:46 PM:
2:00:46 PM: - extend-node-type.js:873 Object.exports.extendNodeType [as setFieldsOnGraphQL NodeType]
2:00:46 PM: [repo]/[gatsby-source-contentful]/extend-node-type.js:873:22
2:00:46 PM:
2:00:46 PM: - api-runner-node.js:434 runAPI
2:00:46 PM: [repo]/[gatsby]/src/utils/api-runner-node.js:434:22
2:00:46 PM:
2:00:46 PM: - api-runner-node.js:585 Promise.catch.decorateEvent.pluginName
2:00:46 PM: [repo]/[gatsby]/src/utils/api-runner-node.js:585:13
2:00:46 PM:
2:00:46 PM: - debuggability.js:384 Promise._execute
2:00:46 PM: [repo]/[bluebird]/js/release/debuggability.js:384:9
2:00:46 PM:
2:00:46 PM: - promise.js:518 Promise._resolveFromExecutor
2:00:46 PM: [repo]/[bluebird]/js/release/promise.js:518:18
2:00:46 PM:
2:00:46 PM: - promise.js:103 new Promise
2:00:46 PM: [repo]/[bluebird]/js/release/promise.js:103:10
2:00:46 PM:
2:00:46 PM: - api-runner-node.js:583
2:00:46 PM: [repo]/[gatsby]/src/utils/api-runner-node.js:583:16
2:00:46 PM:
2:00:46 PM: - util.js:16 tryCatcher
2:00:46 PM: [repo]/[bluebird]/js/release/util.js:16:23
2:00:46 PM:
2:00:46 PM: - reduce.js:166 Object.gotValue
2:00:46 PM: [repo]/[bluebird]/js/release/reduce.js:166:18
2:00:46 PM:
2:00:46 PM: - reduce.js:155 Object.gotAccum
2:00:46 PM: [repo]/[bluebird]/js/release/reduce.js:155:25
2:00:46 PM:
2:00:46 PM: - util.js:16 Object.tryCatcher
2:00:46 PM:
2:00:46 PM:
2:00:46 PM: not finished building schema - 0.449s
2:00:46 PM:
2:00:46 PM: ────────────────────────────────────────────────────────────────
2:00:46 PM: "build.command" failed
2:00:46 PM:
2:00:46 PM: Error message
2:00:46 PM: Command failed with exit code 1: gatsby build
2:00:46 PM:
2:00:46 PM: Error location
2:00:46 PM: In Build command from Netlify app:
2:00:46 PM: gatsby build
2:00:46 PM:
2:00:46 PM: Resolved config
2:00:46 PM: build:
2:00:46 PM: command: gatsby build
2:00:46 PM: commandOrigin: ui
2:00:46 PM: environment:
2:00:46 PM: - CONTACT_EMAIL
2:00:46 PM: - GATSBY_CONTENTFUL_ACCESS_TOKEN
2:00:46 PM: - GATSBY_CONTENTFUL_SPACE_ID
2:00:46 PM: publish: /opt/build/repo/public
2:00:46 PM: functionsDirectory: /opt/build/repo/netlify/functions
2:00:46 PM: Caching artifacts
2:00:46 PM: Started saving node modules
2:00:46 PM: Finished saving node modules
2:00:46 PM: Started saving build plugins
2:00:46 PM: Finished saving build plugins
2:00:46 PM: Started saving pip cache
2:00:47 PM: Finished saving pip cache
2:00:47 PM: Started saving emacs cask dependencies
2:00:47 PM: Finished saving emacs cask dependencies
2:00:47 PM: Started saving maven dependencies
2:00:47 PM: Finished saving maven dependencies
2:00:47 PM: Started saving boot dependencies
2:00:47 PM: Finished saving boot dependencies
2:00:47 PM: Started saving rust rustup cache
2:00:47 PM: Finished saving rust rustup cache
2:00:47 PM: Started saving go dependencies
2:00:47 PM: Finished saving go dependencies
2:00:47 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
2:00:47 PM: Creating deploy upload records
2:00:47 PM: Failing build: Failed to build site
2:00:47 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
2:00:47 PM: Finished processing build request in 1m12.713797094s
I hope you guys could help me out with this, appreciate it. Thanks in advance!
What are the steps to resolve this build bug?
