Sitename: practical-johnson-afe90e
Deploy logs:
3:19:46 AM: Build ready to start
3:19:48 AM: build-image version: 3031d4c9e432fd7016f6279fc9ad706f9205d845
3:19:48 AM: build-image tag: v3.3.17
3:19:48 AM: buildbot version: 1f35b3abd6e2bf5230d8edf68072840fdec1513f
3:19:48 AM: Fetching cached dependencies
3:19:48 AM: Failed to fetch cache, continuing with build
3:19:48 AM: Starting to prepare the repo for build
3:19:49 AM: No cached dependencies found. Cloning fresh repo
3:19:49 AM: git clone https://github.com/vlajke/gatsby-test
3:19:50 AM: Preparing Git Reference refs/heads/master
3:19:51 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'public' versus 'public/' in the Netlify UI
3:19:51 AM: Starting build script
3:19:52 AM: Installing dependencies
3:19:52 AM: Python version set to 2.7
3:19:53 AM: v12.18.0 is already installed.
3:19:54 AM: Now using node v12.18.0 (npm v6.14.4)
3:19:54 AM: Started restoring cached build plugins
3:19:54 AM: Finished restoring cached build plugins
3:19:54 AM: Attempting ruby version 2.7.1, read from environment
3:19:56 AM: Using ruby version 2.7.1
3:19:57 AM: Using PHP version 5.6
3:19:57 AM: 5.2 is already installed.
3:19:57 AM: Using Swift version 5.2
3:19:57 AM: Started restoring cached node modules
3:19:57 AM: Finished restoring cached node modules
3:19:57 AM: Installing NPM modules using NPM version 6.14.4
3:20:49 AM: > sharp@0.23.4 install /opt/build/repo/node_modules/sharp
3:20:49 AM: > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
3:20:49 AM: info sharp Downloading https://github.com/lovell/sharp-libvips/releases/download/v8.8.1/libvips-8.8.1-linux-x64.tar.gz
3:20:51 AM: > node-sass@4.13.1 install /opt/build/repo/node_modules/node-sass
3:20:51 AM: > node scripts/install.js
3:20:52 AM: Downloading binary from https://github.com/sass/node-sass/releases/download/v4.13.1/linux-x64-72_binding.node
3:20:53 AM: Download complete
3:20:53 AM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-72/binding.node
3:20:53 AM: Caching binary to /opt/buildhome/.npm/node-sass/4.13.1/linux-x64-72_binding.node
3:20:53 AM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
3:20:53 AM: > node -e "try{require('./postinstall')}catch(e){}"
3:20:54 AM: > gatsby-telemetry@1.1.51 postinstall /opt/build/repo/node_modules/gatsby-telemetry
3:20:54 AM: > node src/postinstall.js || true
3:20:54 AM: > cwebp-bin@5.1.0 postinstall /opt/build/repo/node_modules/cwebp-bin
3:20:54 AM: > node lib/install.js
3:20:55 AM: β cwebp pre-build test passed successfully
3:20:55 AM: > mozjpeg@6.0.1 postinstall /opt/build/repo/node_modules/mozjpeg
3:20:55 AM: > node lib/install.js
3:20:56 AM: β mozjpeg pre-build test passed successfully
3:20:56 AM: > pngquant-bin@5.0.2 postinstall /opt/build/repo/node_modules/pngquant-bin
3:20:56 AM: > node lib/install.js
3:20:56 AM: β pngquant pre-build test passed successfully
3:20:56 AM: > gatsby-cli@2.10.2 postinstall /opt/build/repo/node_modules/gatsby/node_modules/gatsby-cli
3:20:56 AM: > node scripts/postinstall.js
3:20:56 AM: > gatsby@2.19.32 postinstall /opt/build/repo/node_modules/gatsby
3:20:57 AM: > node-sass@4.13.1 postinstall /opt/build/repo/node_modules/node-sass
3:20:57 AM: > node scripts/build.js
3:20:57 AM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-72/binding.node
3:20:57 AM: Testing binary
3:20:57 AM: Binary is fine
3:21:00 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
3:21:00 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:21:00 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/chokidar/node_modules/fsevents):
3:21:00 AM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
3:21:00 AM: added 2157 packages from 960 contributors and audited 2235 packages in 62.002s
3:21:02 AM: 55 packages are looking for funding
3:21:02 AM: run `npm fund` for details
3:21:02 AM: found 92 vulnerabilities (79 low, 3 moderate, 10 high)
3:21:02 AM: run `npm audit fix` to fix them, or `npm audit` for details
3:21:02 AM: NPM modules installed
3:21:03 AM: Started restoring cached go cache
3:21:03 AM: Finished restoring cached go cache
3:21:03 AM: go version go1.14.4 linux/amd64
3:21:03 AM: Installing missing commands
3:21:03 AM: Verify run directory
3:21:04 AM: β
3:21:04 AM: βββββββββββββββββββββββββββββββ
3:21:04 AM: β Netlify Build β
3:21:04 AM: β
3:21:04 AM: β― Version
3:21:04 AM: @netlify/build 2.0.10
3:21:04 AM: β
3:21:04 AM: β― Flags
3:21:04 AM: deployId: 5ef2aa32842590021056f029
3:21:04 AM: mode: buildbot
3:21:04 AM: β
3:21:04 AM: β― Current directory
3:21:04 AM: /opt/build/repo
3:21:04 AM: β
3:21:04 AM: β― Config file
3:21:04 AM: No config file was defined: using default values.
3:21:04 AM: β
3:21:04 AM: β― Context
3:21:04 AM: production
3:21:04 AM: β
3:21:04 AM: ββββββββββββββββββββββββββββββββββ
3:21:04 AM: β 1. Build command from settings β
3:21:04 AM: β
3:21:04 AM: $ gatsby build
3:21:07 AM: success open and validate gatsby-configs - 0.034s
3:21:08 AM: success load plugins - 1.044s
3:21:08 AM: success onPreInit - 0.013s
3:21:08 AM: success delete html and css files from previous builds - 0.014s
3:21:08 AM: success initialize cache - 0.010s
3:21:08 AM: success copy gatsby files - 0.042s
3:21:08 AM: success onPreBootstrap - 0.006s
3:21:08 AM: success createSchemaCustomization - 0.013s
3:21:10 AM: -> wordpress__acf_options fetched : 1
3:21:11 AM: -> wordpress__acf_posts fetched : 1
3:21:13 AM: -> wordpress__acf_pages fetched : 24
3:21:16 AM: -> wordpress__acf_media fetched : 94
3:21:16 AM: -> wordpress__acf_blocks fetched : 0
3:21:17 AM: -> wordpress__acf_events_post_type fetched : 3
3:21:17 AM: -> wordpress__acf_resources_post_type fetched : 1
3:21:18 AM: -> wordpress__acf_categories fetched : 1
3:21:18 AM: -> wordpress__acf_tags fetched : 0
3:21:19 AM: -> wordpress__acf_comments fetched : 0
3:21:19 AM: -> wordpress__acf_users fetched : 1
3:21:20 AM:
3:21:20 AM: Path: /wp-json/yoast/v1/indexation/posts?per_page=100&page=1
3:21:20 AM: The server response was "404 Not Found"
3:21:20 AM: Inner exception message: "No route was found matching the URL and request method"
3:21:21 AM: -> wordpress__wp_api_menus_menus_items fetched : 1
3:21:21 AM: -> wordpress__wp_api_menus_menus fetched : 2
3:21:22 AM: -> wordpress__wp_api_menus_menu_locations fetched : 1
3:21:22 AM: -> wordpress__POST fetched : 1
3:21:24 AM: -> wordpress__PAGE fetched : 24
3:21:30 AM: -> wordpress__wp_media fetched : 863
3:21:31 AM: -> wordpress__wp_events_post_type fetched : 3
3:21:31 AM: -> wordpress__wp_resources_post_type fetched : 1
3:21:32 AM: -> wordpress__CATEGORY fetched : 30
3:21:34 AM: error (node:1435) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
3:21:52 AM: success source and transform nodes - 44.078s
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_resources_post_type.yoast_meta.content` - [`content`, `content___NODE`]. Gatsby will use `content___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_resources_post_type.yoast_json_ld.wordpress__graph.url` - [`url`, `url___NODE`]. Gatsby will use `url___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_events_post_type.yoast_meta.content` - [`content`, `content___NODE`]. Gatsby will use `content___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_events_post_type.yoast_json_ld.wordpress__graph.url` - [`url`, `url___NODE`]. Gatsby will use `url___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_media.yoast_meta.content` - [`content`, `content___NODE`]. Gatsby will use `content___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_media.yoast_json_ld.wordpress__graph.url` - [`url`, `url___NODE`]. Gatsby will use `url___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__wp_media.guid` - [`guid___NODE`, `guid`]. Gatsby will use `guid___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__PAGE.yoast_meta.content` - [`content`, `content___NODE`]. Gatsby will use `content___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__PAGE.yoast_json_ld.wordpress__graph.url` - [`url`, `url___NODE`]. Gatsby will use `url___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__POST.yoast_meta.content` - [`content`, `content___NODE`]. Gatsby will use `content___NODE`.
3:21:53 AM: warning Multiple node fields resolve to the same GraphQL field `wordpress__POST.yoast_json_ld.wordpress__graph.url` - [`url`, `url___NODE`]. Gatsby will use `url___NODE`.
3:21:56 AM: warning There are conflicting field types in your data.
3:21:56 AM: If you have explicitly defined a type for those fields, you can safely ignore this warning message.
3:21:56 AM: Otherwise, Gatsby will omit those fields from the GraphQL schema.
3:21:56 AM: If you know all field types in advance, the best strategy is to explicitly define them with the `createTypes` action, and skip inference with the `@dontInfer` directive.
3:21:56 AM: See https://www.gatsbyjs.org/docs/actions/#createTypes
3:21:56 AM: wordpress__wp_resources_post_type.yoast_json_ld.wordpress_@graph.potentialAction.target:
3:21:56 AM: - type: array
3:21:56 AM: value: [ ..., 'https://werockthespectrumcincinnati.wrtsfranchise.com/resource/agnesa-papazyan-psyd/', ... ]
3:21:56 AM: - type: string
3:21:56 AM: value: 'https://werockthespectrumcincinnati.wrtsfranchise.com/?s={search_term_string}'
3:21:56 AM: wordpress__wp_events_post_type.yoast_json_ld.wordpress_@graph.potentialAction.target:
3:21:56 AM: value: [ ..., 'https://werockthespectrumcincinnati.wrtsfranchise.com/event/we-rock-the-spectrums-2019-rockin-resource-fair/', ... ]
3:21:56 AM: wordpress__wp_media.yoast_json_ld.wordpress_@graph.potentialAction.target:
3:21:56 AM: value: [ ..., 'https://werockthespectrumcincinnati.wrtsfranchise.com/wp-content/uploads/2020/06/Gym-Logo-Transparent.png', ... ]
3:21:56 AM: wordpress__wp_media.media_details.image_meta.orientation:
3:21:56 AM: - type: number
3:21:56 AM: value: 1
3:21:56 AM: value: '0'
3:21:56 AM: wordpress__PAGE.yoast_json_ld.wordpress_@graph.potentialAction.target:
3:21:56 AM: value: [ ..., 'https://werockthespectrumcincinnati.wrtsfranchise.com/rock-shop/', ... ]
3:21:56 AM: wordpress__POST.yoast_json_ld.wordpress_@graph.wordpress_@type:
3:21:56 AM: value: [ ..., 'Person', ... ]
3:21:56 AM: value: 'WebSite'
3:21:56 AM: wordpress__POST.yoast_json_ld.wordpress_@graph.potentialAction.target:
3:21:56 AM: value: [ ..., 'https://werockthespectrumcincinnati.wrtsfranchise.com/coming-soon/', ... ]
3:21:56 AM: success building schema - 3.594s
3:21:56 AM: success createPages - 0.243s
3:21:56 AM: success createPagesStatefully - 0.100s
3:21:56 AM: success onPreExtractQueries - 0.001s
3:21:56 AM: success update schema - 0.073s
3:21:57 AM: success extract queries from components - 1.002s
3:21:57 AM: warning The GraphQL query in the non-page component "/opt/build/repo/src/templates/nonprofit.js" will not be run.
3:21:57 AM: Exported queries are only executed for Page components. It's possible you're
3:21:57 AM: trying to create pages in your gatsby-node.js and that's failing for somereason.
3:21:57 AM: If the failing component(s) is a regular component and not intended to be a page
3:21:57 AM: component, you generally want to use a <StaticQuery> (https://gatsbyjs.org/docs/static-query)
3:21:57 AM: instead of exporting a page query.
3:21:57 AM: If you're more experienced with GraphQL, you can also export GraphQLfragments from components and compose the fragments in the Page component
3:21:57 AM: query and pass data down into the child component β http://graphql.org/learn/queries/#fragments
3:21:57 AM: success write out requires - 0.006s
3:21:57 AM: success write out redirect data - 0.001s
3:21:57 AM: success Build manifest and related icons - 0.128s
3:21:57 AM: success onPostBootstrap - 0.130s
3:21:57 AM: β
3:21:57 AM: info bootstrap finished - 53.081 s
3:21:57 AM: β
3:21:58 AM: warning
3:21:58 AM: The requested width "400px" for a resolutions field for
3:21:58 AM: the file /opt/build/repo/.cache/gatsby-source-filesystem/96274bfab1abf3a9de26d43e98fb0a5c/Gym-Logo-Transparent.png
3:21:58 AM: was larger than the actual image width of 360px!
3:21:58 AM: If possible, replace the current image with a larger one.
3:21:58 AM: warning
3:21:58 AM: the file /opt/build/repo/.cache/gatsby-source-filesystem/3f8615699e8df41fba81a14f28b562e7/logomap-1.png
3:21:58 AM: was larger than the actual image width of 140px!
3:21:58 AM: warning
3:21:58 AM: the file /opt/build/repo/.cache/gatsby-source-filesystem/91bf758254433fcdc1dda25bf1a770b4/1_23.jpg
3:21:58 AM: was larger than the actual image width of 230px!
3:21:58 AM: warning
3:21:58 AM: the file /opt/build/repo/.cache/gatsby-source-filesystem/c1b873cf615a700351b4d60cfab2d0c8/1_25.jpg
3:22:00 AM: failed Building production JavaScript and CSS bundles - 1.893s
3:22:00 AM: error Generating JavaScript bundles failed
3:22:00 AM: [BABEL] /opt/build/repo/.cache/production-app.js: Cannot find module '@babel/compat-data/corejs3-shipped-proposals'
3:22:00 AM: Require stack:
3:22:00 AM: - /opt/build/repo/node_modules/@babel/preset-env/lib/polyfills/corejs3/usage-plugin.js
3:22:00 AM: - /opt/build/repo/node_modules/@babel/preset-env/lib/index.js
3:22:00 AM: - /opt/build/repo/node_modules/@babel/core/lib/config/files/plugins.js
3:22:00 AM: - /opt/build/repo/node_modules/@babel/core/lib/config/files/index.js
3:22:00 AM: - /opt/build/repo/node_modules/@babel/core/lib/index.js
3:22:00 AM: - /opt/build/repo/node_modules/babel-loader/lib/index.js
3:22:00 AM: - /opt/build/repo/node_modules/gatsby/dist/utils/babel-loader.js
3:22:00 AM: - /opt/build/repo/node_modules/loader-runner/lib/loadLoader.js
3:22:00 AM: - /opt/build/repo/node_modules/loader-runner/lib/LoaderRunner.js
3:22:00 AM: - /opt/build/repo/node_modules/webpack/lib/NormalModule.js
3:22:00 AM: - /opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js
3:22:00 AM: - /opt/build/repo/node_modules/webpack/lib/Compiler.js
3:22:00 AM: - /opt/build/repo/node_modules/webpack/lib/webpack.js
3:22:00 AM: - /opt/build/repo/node_modules/gatsby/dist/commands/build-html.js
3:22:00 AM: - /opt/build/repo/node_modules/gatsby/dist/commands/build.js
3:22:00 AM: - /opt/build/repo/node_modules/gatsby/node_modules/gatsby-cli/lib/create-cli.js
3:22:00 AM: - /opt/build/repo/node_modules/gatsby/node_modules/gatsby-cli/lib/index.js
3:22:00 AM: - /opt/build/repo/node_modules/gatsby/dist/bin/gatsby.js
3:22:00 AM: not finished run queries - 3.230s
3:22:00 AM: not finished Generating image thumbnails - 3.193s
3:22:01 AM: β
3:22:01 AM: βββββββββββββββββββββββββββββββ
3:22:01 AM: β "build.command" failed β
3:22:01 AM: β
3:22:01 AM: Error message
3:22:01 AM: Command failed with exit code 1: gatsby build
3:22:01 AM: β
3:22:01 AM: Error location
3:22:01 AM: In Build command from settings:
3:22:01 AM: gatsby build
3:22:01 AM: β
3:22:01 AM: Resolved config
3:22:01 AM: build:
3:22:01 AM: command: gatsby build
3:22:01 AM: publish: /opt/build/repo/public
3:22:01 AM: Caching artifacts
3:22:01 AM: Started saving node modules
3:22:01 AM: Finished saving node modules
3:22:01 AM: Started saving build plugins
3:22:01 AM: Finished saving build plugins
3:22:01 AM: Started saving pip cache
3:22:08 AM: Finished saving pip cache
3:22:08 AM: Started saving emacs cask dependencies
3:22:08 AM: Finished saving emacs cask dependencies
3:22:08 AM: Started saving maven dependencies
3:22:08 AM: Finished saving maven dependencies
3:22:08 AM: Started saving boot dependencies
3:22:08 AM: Finished saving boot dependencies
3:22:08 AM: Started saving go dependencies
3:22:08 AM: Finished saving go dependencies
3:22:11 AM: Error running command: Build script returned non-zero exit code: 1
3:22:11 AM: Failing build: Failed to build site
3:22:11 AM: Failed during stage 'building site': Build script returned non-zero exit code: 1
3:22:11 AM: Finished processing build request in 2m23.031492714s
What is really weird is that we have the exact same structure on a different site and it works just fine. If we clone and add a new one, this happens. I canβt get it to work ever since.
