Hi,
My site at Netlify App has Netlify Identity being enabled.
It has also a function identity-signup.js being defined.
When running the site locally with ntl dev, I run the following scenario:
- from http://localhost:8888, I launch the Netlify Signup widget and register a name, a unique email & a password
- upon receiving the confirmation email, I paste the URL in my browser and change the scheme + host + port to http://localhost:8888
Excepted:
- the
identity-signup.jsfunction is called - the identity is created in Netlify
Actual:
- the
identity-signup.jsfunction is NOT called (confirmed through debug run, logs, console.log) - the identity is created in Netlify
Do you know if something has changed because it used (at least in January) to work like a charm.
Thanks for any help,
Damien
