development environment
System:
OS: macOS 10.15.6
CPU: (16) x64 Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 1.19 GB / 16.00 GB
Shell: 5.7.1 - /bin/zsh
Binaries:
Node: 12.18.0 - ~/.nvm/versions/node/v12.18.0/bin/node
Yarn: 1.22.4 - ~/projects/test/node_modules/.bin/yarn
npm: 6.14.4 - ~/.nvm/versions/node/v12.18.0/bin/npm
monorepo/package.json
"name": "workspace",
"private": true,
"version": "1.0.0",
"workspaces": {
"packages": [
"packages/*"
"scripts": {
"start": "lerna run start --stream"
"devDependencies": {
"lerna": "^3.22.1"
monorepo/packages/app/package.json
"name": "app",
"version": "0.0.1",
"private": true,
"dependencies": {
"netlify-cli": "^2.59.0",
"react": "^16.12.0",
"react-scripts": "3.4.0"
"scripts": {
"start": "netlify dev -c 'yarn dev'",
"dev": "react-scripts start"
"eslintConfig": {
"extends": [
"react-app"
"browserslist": {
"production": [
">0.2%",
"not dead",
"not op_mini all"
"development": [
"last 1 chrome version",
"last 1 firefox version",
"last 1 safari version"
running yarn start from root
results in:
yarn start
yarn run v1.22.4
$ lerna run start --stream
lerna notice cli v3.22.1
lerna info versioning independent
lerna info Executing command in 1 package: "yarn run start"
app: $ netlify dev -c 'yarn dev'
app: ◈ Netlify Dev ◈
app: ◈ Overriding command with setting derived from netlify.toml [dev] block: yarn dev
app: ◈ Starting Netlify Dev with create-react-app
app: ◈ Functions server is listening on 65353
app: /Users/mortond/projects/monorepo/node_modules/netlify-redirector/lib/redirects.js:116
app: throw ex;
app: ^
app: TypeError: dest.end is not a function
app: at ReadStream.onend (_stream_readable.js:682:10)
app: at Object.onceWrapper (events.js:421:28)
app: at ReadStream.emit (events.js:327:22)
app: at endReadableNT (_stream_readable.js:1221:12)
app: at processTicksAndRejections (internal/process/task_queues.js:84:21)
app: error Command failed with exit code 7.
app: info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
lerna ERR! yarn run start exited 7 in 'app'
if I cd packages/app and run yarn start it works fine.
Hmm it seems to be related to the --stream option of lerna, removing it allows everything to work, but with no console output.
"start": "lerna run start"
