site name: neon-liger-2de8e6
url : mathcommunications.com
Build Log:
2:07:33 PM: build-image version: 2a79f2b6b97edab3f858983ec4cea00280a2836a (focal)
2:07:33 PM: buildbot version: 7dd8429028e6fffe1e65d79b0c01bd3eb285899c
2:07:33 PM: Fetching cached dependencies
2:07:33 PM: Failed to fetch cache, continuing with build
2:07:33 PM: Starting to prepare the repo for build
2:07:34 PM: No cached dependencies found. Cloning fresh repo
2:07:34 PM: git clone --filter=blob:none https://github.com/susansilver/suzza-astroship
2:07:34 PM: Preparing Git Reference refs/heads/main
2:07:37 PM: Starting to install dependencies
2:07:37 PM: Python version set to 3.8
2:07:37 PM: Attempting Ruby version 2.7.2, read from environment
2:07:38 PM: Using Ruby version 2.7.2
2:07:38 PM: Started restoring cached go cache
2:07:38 PM: Finished restoring cached go cache
2:07:38 PM: go version go1.19.13 linux/amd64
2:07:39 PM: Using PHP version 8.0
2:07:39 PM: Downloading and installing node v18.18.2…
2:07:40 PM: Downloading https://nodejs.org/dist/v18.18.2/node-v18.18.2-linux-x64.tar.xz…
2:07:40 PM: Computing checksum with sha256sum
2:07:40 PM: Checksums matched!
2:07:42 PM: Now using node v18.18.2 (npm v9.8.1)
2:07:42 PM: Enabling Node.js Corepack
2:07:42 PM: Started restoring cached build plugins
2:07:42 PM: Finished restoring cached build plugins
2:07:42 PM: Started restoring cached corepack dependencies
2:07:42 PM: Finished restoring cached corepack dependencies
2:07:42 PM: No npm workspaces detected
2:07:42 PM: Started restoring cached node modules
2:07:42 PM: Finished restoring cached node modules
2:07:42 PM: Installing npm packages using npm version 9.8.1
2:07:44 PM: npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
2:07:48 PM: Failed during stage “Install dependencies”: dependency_installation script returned non-zero exit code: 1
2:07:48 PM: npm ERR! code E404
2:07:48 PM: npm ERR! 404 Not Found - GET https://registry.npmjs.org/files-pipe/-/files-pipe-0.0.8.tgz - Not found
2:07:48 PM: npm ERR! 404 “files-pipe@https://registry.npmjs.org/files-pipe/-/files-pipe-0.0.8.tgz” is not in this registry.
2:07:48 PM: npm ERR! 404 Note that you can also install from a
2:07:48 PM: npm ERR! 404 tarball, folder, http url, or git url.
2:07:48 PM: npm ERR! A complete log of this run can be found in: /opt/buildhome/.npm/_logs/2023-10-17T21_07_42_946Z-debug-0.log
2:07:48 PM: Error during npm install
2:07:48 PM: Build was terminated: dependency_installation script returned non-zero exit code: 1
2:07:48 PM: Failing build: Failed to install dependencies
https://registry.npmjs.org/files-pipe/-/files-pipe-0.0.8.tgz says not found
Works in dev and build no problems.
Tried to install files-pipe from npm and got this error
npm install -D -E files-pipe
npm ERR! code ETARGET
npm ERR! notarget No matching version found for files-pipe@0.0.8.
npm ERR! notarget In most cases you or one of your dependencies are requesting
npm ERR! notarget a package version that doesn’t exist.
I’ve tried deleting node modules and installing again and it didn’t work
