Site name: xr-h.netlify.app
Deploy log
I am having build problems, deploy log:
11:47:24 AM: build-image version: a2d22d22e4555d1ef0a972ed14a0a4b366ad20c4 (focal)
11:47:24 AM: build-image tag: v4.16.3
11:47:24 AM: buildbot version: 4033cea21a3d9a6b51a0c8660e8b7502a7f7abfe
11:47:24 AM: Fetching cached dependencies
11:47:24 AM: Failed to fetch cache, continuing with build
11:47:24 AM: Starting to prepare the repo for build
11:47:24 AM: No cached dependencies found. Cloning fresh repo
11:47:24 AM: git clone --filter=blob:none https://github.com/LovesPictures/Xr-H
11:47:25 AM: Preparing Git Reference refs/heads/main
11:47:25 AM: Parsing package.json dependencies
11:47:27 AM: Starting build script
11:47:27 AM: Installing dependencies
11:47:27 AM: Python version set to 2.7
11:47:27 AM: v16.19.0 is already installed.
11:47:27 AM: Now using node v16.19.0 (npm v8.19.3)
11:47:28 AM: Enabling Node.js Corepack
11:47:28 AM: Started restoring cached build plugins
11:47:28 AM: Finished restoring cached build plugins
11:47:28 AM: Attempting Ruby version 2.7.2, read from environment
11:47:28 AM: Using Ruby version 2.7.2
11:47:28 AM: Using PHP version 8.0
11:47:28 AM: Started restoring cached corepack dependencies
11:47:28 AM: mv: cannot move ‘/opt/build/cache/.node/corepack’ to ‘/opt/buildhome/.node/corepack’: No such file or directory
11:47:28 AM: Finished restoring cached corepack dependencies
11:47:28 AM: No npm workspaces detected
11:47:28 AM: Started restoring cached node modules
11:47:28 AM: Finished restoring cached node modules
11:47:28 AM: Bypassing sha validation. Running pre & post install scripts
11:47:29 AM: Installing npm packages using npm version 8.19.3
11:47:30 AM: npm WARN old lockfile
11:47:30 AM: npm WARN old lockfile The package-lock.json file was created with an old version of npm,
11:47:30 AM: npm WARN old lockfile so supplemental metadata must be fetched from the registry.
11:47:30 AM: npm WARN old lockfile This is a one-time fix-up, please be patient…
11:47:38 AM: npm ERR! code ETARGET
11:47:38 AM: npm ERR! notarget No matching version found for react-leaflet@^1.9.3.
11:47:38 AM: npm ERR! notarget In most cases you or one of your dependencies are requesting
11:47:38 AM: npm ERR! notarget a package version that doesn’t exist.
11:47:38 AM: npm ERR! A complete log of this run can be found in:
11:47:38 AM: npm ERR! /opt/buildhome/.npm/_logs/2023-01-14T11_47_29_373Z-debug-0.log
11:47:38 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1 (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
11:47:38 AM: Error during npm install
11:47:38 AM: Build was terminated: Build script returned non-zero exit code: 1
11:47:38 AM: Failing build: Failed to build site
11:47:38 AM: Finished processing build request in 14.407720355s
