I followed these instructions to get npm modules available in edge functions: Support for npm modules in Edge Functions
Specfically: start by adding it to your project, for example npm install lodash
But I’m getting: Error: Cannot find module ‘html-minifier’"
Even though the package.json is located at my projects base directory.
Do you have a way for us to reproduce this issue?
You don’t seem to be using Edge Functions and the error seems to be coming from your Function. Your repo is private, so we can’t check much beyond this. If you can share your repo, that can reveal more insights.
Hey there hrishikesh, what github user can I share it with?
I’m unable to test this. At first, I got an error about a misising environment variable, but after adding that, locally, I’m getting an error:
error sending request for url (https://api.actransit.org/transit/actrealtime/prediction?stpid=55990&token=<redacted>): channel closed
That’s the error on the URL http://localhost:8888/ac-transit/stops/55990/soon/
