According to the docs at Edge Functions declarations | Netlify Docs path can be an array of strings. When trying this out (say `[ “/one/", "/two/” ]), the deploy fails with the following message:
8:20:21 PM: Edge Functions bundling
8:20:21 PM: ────────────────────────────────────────────────────────────────
8:20:21 PM:
8:20:21 PM: Packaging Edge Functions from .netlify/edge-functions directory:
8:20:21 PM: - server
8:20:25 PM:
8:20:25 PM: Bundling of edge function failed
8:20:25 PM: ────────────────────────────────────────────────────────────────
8:20:25 PM:
8:20:25 PM: Error message
8:20:25 PM: Validation of Edge Functions manifest failed
8:20:25 PM: TYPE must be string
Is the documention correct or there is a bug in the bundler? The declaration in the code seems to indicate that no array is expected (build/packages/edge-bundler/node/declaration.ts at d2276a9e29630a2c14b271cadedbb6d44151225e · netlify/build · GitHub)
