Deploy log shows successful build, but site stuck on 'building' and not published
silly-knuth-4897cf
I have just installed the algolia plugin and was trying it out
turns out they have an issue with canonical urls (absolute) , they are working on a fix
However they said the plugin should not effect the completion of the build process as they hook into the
onSuccess event that triggers AFTER the site is deployed??
I do know that my site was not indexed as part of their process, so I am thinking perhaps this process didn’t return ‘completed’ type response and as a result my entire deploy is in limbo??
below is the rather long deploy log, truncated (removed the middleman build process part which competed successfully)
10:37:22 PM: Build ready to start
10:37:25 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
10:37:25 PM: build-image tag: v3.4.1
10:37:25 PM: buildbot version: dad983e1697e9903da960ad66ea1950c0f15890b
10:37:26 PM: Fetching cached dependencies
10:37:26 PM: Starting to download cache of 293.8MB
10:37:28 PM: Finished downloading cache in 2.371761391s
10:37:28 PM: Starting to extract cache
10:37:37 PM: Finished extracting cache in 8.958705194s
10:37:37 PM: Finished fetching cache in 11.454712047s
10:37:37 PM: Starting to prepare the repo for build
10:37:38 PM: Preparing Git Reference refs/heads/master
10:37:40 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'build' versus 'build/' in the Netlify UI
10:37:40 PM: Starting build script
10:37:40 PM: Installing dependencies
10:37:40 PM: Python version set to 2.7
10:37:41 PM: Started restoring cached node version
10:37:45 PM: Finished restoring cached node version
10:37:46 PM: v10.22.1 is already installed.
10:37:46 PM: Now using node v10.22.1 (npm v6.14.6)
10:37:47 PM: Started restoring cached build plugins
10:37:47 PM: Finished restoring cached build plugins
10:37:47 PM: Attempting ruby version 2.6.2, read from environment
10:37:49 PM: Using ruby version 2.6.2
10:37:49 PM: Using bundler version 1.17.3 from Gemfile.lock
10:37:49 PM: Using PHP version 5.6
10:37:49 PM: Started restoring cached ruby gems
10:37:49 PM: Finished restoring cached ruby gems
10:37:50 PM: 5.2 is already installed.
10:37:50 PM: Using Swift version 5.2
10:37:50 PM: Started restoring cached go cache
10:37:52 PM: Finished restoring cached go cache
10:37:52 PM: Installing Go version 1.12
10:37:52 PM: unset GOOS;
10:37:52 PM: unset GOARCH;
10:37:52 PM: export GOROOT='/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64';
10:37:52 PM: export PATH="/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64/bin:${PATH}";
10:37:52 PM: go version >&2;
10:37:52 PM: export GIMME_ENV='/opt/buildhome/.gimme_cache/env/go1.12.linux.amd64.env';
10:37:52 PM: go version go1.12 linux/amd64
10:37:52 PM: Installing missing commands
10:37:52 PM: Verify run directory
10:37:54 PM: ​
10:37:54 PM: ┌─────────────────────────────┐
10:37:54 PM: │        Netlify Build        │
10:37:54 PM: └─────────────────────────────┘
10:37:54 PM: ​
10:37:54 PM: ❯ Version
10:37:54 PM:   @netlify/build 5.0.0
10:37:54 PM: ​
10:37:54 PM: ❯ Flags
10:37:54 PM:   deployId: 5f876f92471ffd0007f19dac
10:37:54 PM:   mode: buildbot
10:37:54 PM: ​
10:37:54 PM: ❯ Current directory
10:37:54 PM:   /opt/build/repo
10:37:54 PM: ​
10:37:54 PM: ❯ Config file
10:37:54 PM:   /opt/build/repo/netlify.toml
10:37:54 PM: ​
10:37:54 PM: ❯ Context
10:37:54 PM:   production
10:37:54 PM: ​
10:37:54 PM: ❯ Loading plugins
10:37:54 PM:    - @algolia/netlify-plugin-crawler@0.0.13 from Netlify app
10:37:54 PM: ​
10:37:54 PM: ┌───────────────────────────────────┐
10:37:54 PM: │ 1. Build command from Netlify app │
10:37:54 PM: └───────────────────────────────────┘
10:37:54 PM: ​
10:37:54 PM: $ middleman build --verbose
10:38:15 PM:       create  build/mstile-310x150.png
10:38:15 PM: Project built successfully.
10:38:15 PM: ​
10:38:15 PM: (build.command completed in 21.4s)
10:38:15 PM: ​
10:38:15 PM:       ┌───────────────────────────────────────────────────────────┐
10:38:15 PM: │ 2. onSuccess command from @algolia/netlify-plugin-crawler │
10:38:15 PM:   └───────────────────────────────────────────────────────────┘
10:38:15 PM: ​
10:38:15 PM: Algolia Netlify plugin started
10:38:15 PM: Sending request to crawl https://crawler.algolia.com/api/1/netlify/crawl
10:38:16 PM: API answered: 200
10:38:16 PM: Your crawler is running at: https://crawler.algolia.com/admin/user_configs/fba92b63-1b3e-46e2-8f4f-0ccde4d9f13d
10:38:16 PM: Done.
10:38:16 PM: ​
10:38:16 PM: (@algolia/netlify-plugin-crawler onSuccess completed in 755ms)
10:38:16 PM: ​
10:38:16 PM: ┌─────────────────────────────┐
10:38:16 PM: │   Netlify Build Complete    │
10:38:16 PM: └─────────────────────────────┘
10:38:16 PM: ​
10:38:16 PM: (Netlify Build completed in 22.6s)
10:38:16 PM: Caching artifacts
10:38:16 PM: Started saving ruby gems
10:38:16 PM: Finished saving ruby gems
10:38:16 PM: Started saving build plugins
10:38:16 PM: Finished saving build plugins
10:38:16 PM: Started saving pip cache
10:38:17 PM: Finished saving pip cache
10:38:17 PM: Started saving emacs cask dependencies
10:38:17 PM: Finished saving emacs cask dependencies
10:38:17 PM: Started saving maven dependencies
10:38:17 PM: Finished saving maven dependencies
10:38:17 PM: Started saving boot dependencies
10:38:17 PM: Finished saving boot dependencies
10:38:17 PM: Started saving go dependencies
10:38:19 PM: Finished saving go dependencies
10:38:19 PM: Build script success
10:39:06 PM: Finished processing build request in 1m40.387568556s
Hey @DaveHarrison,
Thanks for sharing this deploy log. After looking into this internally, we found that we did introduce a bug yesterday around 11am Pacific in the build hook that this plugin relies on. We rolled out a fix this morning around 7:30am Pacific, and re-deployed builds that failed because of that bug. Things should be working as expected now, but please let us know if you’re seeing something different!
all good now, thanks @jen en
