This is my netlify site: riccardofava.netlify.app
I can’t connect my site to riccardofava.it, my provider is “IONOS”
The status on my domain page on Netlify is always “Awaiting External DNS”
I read this post https://answers.netlify.com/t/support-guide-can-i-host-my-site-on-netlify-but-keep-my-dns-at-my-domain-registrar/110 but anyway i can’t make it work, any solutions?
@riccardofava.it It looks like your site is now up and running! Let me know if you’re still experiencing issues on your end.
Hi @sid.mann I am having same problem. I added nameservers in IONOS to use Netlify DNS but on my domain page on Netlify it is always “Awaiting External DNS”.
My domain is heeyang-hamburg.com. I couldn’t figure out where is the problem.
Thanks in advance.
This is my Netlify site: endearing-swan-c05cda.netlify.app
I am trying to use domain: heeyang-hamburg.com it is always showing Awaiting External DNS although I added the nameservers in IONOS. Could you help me troubleshoot the issue? Thanks
You’ve added some invalid A records:
You deleted the NETLIFY records that we added for you and decided to add your own A records. Thus, the result is what you can see.
Remove those A records, remove the domain from the site and add it again.
I have removed those A records. I also removed and added the domain again. As I have already added Netlify nameservers in IONOS, this should work now? Thanks
thanks. Appreciate it.
