Hi
I’m a newbie trying to figure out why I can’t get the build process to work unless I use “clear cache and deploy site”
this is the site and branch I’m currently trying to build:
https://lambdafunctions2--stupefied-lamarr-20c8d9.netlify.app/
(doesn’t seem like I have the option to clear the cache for a branch, so I’m being forced to figure out the issue
For various reasons I have ended up with a setup as follows
- root folder - main package.json here, with scripts to trigger, (but few dependencies)
- server folder - scripts & dependencies for building & serving lambda functions (just hello world for now)
- client folder - scripts & dependencies for building the react app, per create-react-app
from the root folder package.json the build scripts are:
“prebuild”: “npm run tailwind:css”,
“build”: “cd client && npm run build && cd …/server && npm run build:lambda”,
…and there’s also this
“postinstall”: “cd server && npm install && cd …/client && npm install”,
from the client package.json the build script is:
“build”: “react-scripts build”,
in the server pacakge.json the build script is:
“build:lambda”: “netlify-lambda build lambdaFunctions”
the error, from the log is this:
7:50:20 AM: > react-scripts build
7:50:20 AM: sh: 1: react-scripts: not found
This error occurs in the prod build also, but not if I clear the cache first. I can also run the build script locally and I don’t get that error…so I’m trying to understand what the cache is doing that might cause the client to think that react-scripts is not installed
Here’s the full build log
Build Settings are:
Repository
github.com/simonrumi/deepsheet
Base directory
Not set
Build command
npm run build
Publish directory
client/build
Builds
Active
Appreciate any help/suggestions…including if anything above is idiotic, please LMK
Thanks!
Simon
