First deploy problems - react project
Hi guys,
First of all - sorry… I’m really new at this.
I wanted to make my website first deploy and I’m getting this error here. First, I want to highlight some points that could help you guys with my solution.
1 - I don’t have the node_modules folder here. As I put the node_modules in gitIgnore, the file wasn’t sent here.
2 - I didn’t build my project locally. I’m doing this just here. Should I build it and send the build folder here?
This is the the log that I’m getting.
2:20:56 AM: Build ready to start
2:20:58 AM: build-image version: c23500190e408b04bdfcf9703d16c460ef03b813
2:20:58 AM: build-image tag: v3.3.15
2:20:58 AM: buildbot version: 85ab9be17c6555a1d991d1cf7b0dbb73c18d0b92
2:20:58 AM: Fetching cached dependencies
2:20:58 AM: Starting to download cache of 254.3KB
2:20:58 AM: Finished downloading cache in 79.922933ms
2:20:58 AM: Starting to extract cache
2:20:58 AM: Failed to fetch cache, continuing with build
2:20:58 AM: Starting to prepare the repo for build
2:20:58 AM: No cached dependencies found. Cloning fresh repo
2:20:58 AM: git clone https://github.com/KajiyamaVK/Kajix
2:21:00 AM: Preparing Git Reference refs/heads/master
2:21:01 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: ‘build’ versus ‘./build’ in the Netlify UI
2:21:01 AM: Starting build script
2:21:01 AM: Installing dependencies
2:21:01 AM: Python version set to 2.7
2:21:02 AM: Downloading and installing node v10.21.0…
2:21:02 AM: Downloading https://nodejs.org/dist/v10.21.0/node-v10.21.0-linux-x64.tar.xz…
2:21:03 AM: Computing checksum with sha256sum
2:21:03 AM: Checksums matched!
2:21:05 AM: Now using node v10.21.0 (npm v6.14.4)
2:21:05 AM: Started restoring cached build plugins
2:21:05 AM: Finished restoring cached build plugins
2:21:06 AM: Attempting ruby version 2.6.2, read from environment
2:21:07 AM: Using ruby version 2.6.2
2:21:07 AM: Using PHP version 5.6
2:21:07 AM: 5.2 is already installed.
2:21:07 AM: Using Swift version 5.2
2:21:07 AM: Started restoring cached node modules
2:21:07 AM: Finished restoring cached node modules
2:21:07 AM: Installing NPM modules using NPM version 6.14.4
2:21:36 AM: > node-sass@4.13.0 install /opt/build/repo/node_modules/node-sass
2:21:36 AM: > node scripts/install.js
2:21:37 AM: Downloading binary from https://github.com/sass/node-sass/releases/download/v4.13.0/linux-x64-64_binding.node
2:21:37 AM: Download complete
2:21:37 AM: Binary saved to /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
2:21:37 AM: Caching binary to /opt/buildhome/.npm/node-sass/4.13.0/linux-x64-64_binding.node
2:21:37 AM: > core-js@2.6.8 postinstall /opt/build/repo/node_modules/babel-runtime/node_modules/core-js
2:21:37 AM: > node -e “try { require(‘./scripts/postinstall’); } catch (e) { /* empty / }"
2:21:38 AM: > core-js@3.6.2 postinstall /opt/build/repo/node_modules/core-js
2:21:38 AM: > node -e “try{require(‘./postinstall’)}catch(e){}”
2:21:38 AM: > core-js-pure@3.1.2 postinstall /opt/build/repo/node_modules/core-js-pure
2:21:38 AM: > node -e "try { require(‘./scripts/postinstall’); } catch (e) { /
empty */ }”
2:21:38 AM: > node-sass@4.13.0 postinstall /opt/build/repo/node_modules/node-sass
2:21:38 AM: > node scripts/build.js
2:21:38 AM: Binary found at /opt/build/repo/node_modules/node-sass/vendor/linux-x64-64/binding.node
2:21:38 AM: Testing binary
2:21:38 AM: Binary is fine
2:21:41 AM: npm
2:21:41 AM: WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/jest-haste-map/node_modules/fsevents):
2:21:41 AM: npm
2:21:41 AM: WARN
2:21:41 AM: notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
2:21:41 AM: npm
2:21:41 AM: WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
2:21:41 AM: npm
2:21:41 AM: WARN
2:21:41 AM: notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
2:21:41 AM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/chokidar/node_modules/fsevents):
2:21:41 AM: added 1704 packages from 874 contributors and audited 1913 packages in 32.381s
2:21:42 AM: 4 packages are looking for funding
2:21:42 AM: run npm fund for details
2:21:42 AM: found 55037 vulnerabilities (38934 low, 21 moderate, 16081 high, 1 critical)
2:21:42 AM: run npm audit fix to fix them, or npm audit for details
2:21:42 AM: NPM modules installed
2:21:42 AM: Started restoring cached go cache
2:21:42 AM: Finished restoring cached go cache
2:21:42 AM: go version go1.12 linux/amd64
2:21:42 AM: Installing missing commands
2:21:42 AM: Verify run directory
2:21:44 AM: ​
2:21:44 AM: ┌─────────────────────────────┐
2:21:44 AM: │ Netlify Build │
2:21:44 AM: └─────────────────────────────┘
2:21:44 AM: ​
2:21:44 AM: ❯ Version
2:21:44 AM: @netlify/build 2.0.10
2:21:44 AM: ​
2:21:44 AM: ❯ Flags
2:21:44 AM: deployId: 5eea50f8b4be4138da718881
2:21:44 AM: mode: buildbot
2:21:44 AM: ​
2:21:44 AM: ❯ Current directory
2:21:44 AM: /opt/build/repo
2:21:44 AM: ​
2:21:44 AM: ❯ Config file
2:21:44 AM: No config file was defined: using default values.
2:21:44 AM: ​
2:21:44 AM: ❯ Context
2:21:44 AM: production
2:21:44 AM: ​
2:21:44 AM: ┌────────────────────────────────┐
2:21:44 AM: │ 1. Build command from settings │
2:21:44 AM: └────────────────────────────────┘
2:21:44 AM: ​
2:21:44 AM: $ npm run build
2:21:44 AM: > trydo@0.1.0 build /opt/build/repo
2:21:44 AM: > node scripts/build.js
2:21:45 AM: Creating an optimized production build…
2:21:47 AM: Browserslist: caniuse-lite is outdated. Please run next command npm update
2:22:32 AM:
2:22:32 AM: Treating warnings as errors because process.env.CI = true.
2:22:32 AM: Most CI servers set it automatically.
2:22:32 AM:
2:22:32 AM: Failed to compile.
2:22:32 AM:
2:22:32 AM: ./src/dark/MainDemo.jsx
2:22:32 AM: Line 10:8: ‘Testimonial’ is defined but never used no-unused-vars
2:22:32 AM: Line 12:8: ‘Portfolio’ is defined but never used no-unused-vars
2:22:32 AM: Line 14:8: ‘BrandTwo’ is defined but never used no-unused-vars
2:22:32 AM: Line 19:9: ‘PostList’ is assigned a value but never used no-unused-vars
2:22:32 AM: ./src/home/Interior.jsx
2:22:32 AM: Line 11:10: ‘slickDot’ is defined but never used no-unused-vars
2:22:32 AM: ./src/index.js
2:22:32 AM: Line 12:8: ‘Demo’ is defined but never used no-unused-vars
2:22:32 AM: ./src/blocks/Counters.jsx
2:22:32 AM: Line 2:8: ‘TeamOne’ is defined but never used no-unused-vars
2:22:32 AM: ./src/elements/Contact.jsx
2:22:32 AM: Line 3:32: ‘FiMapPin’ is defined but never used no-unused-vars
2:22:32 AM: Line 5:8: ‘GoogleMapReact’ is defined but never used no-unused-vars
2:22:32 AM: Line 7:8: ‘BrandTwo’ is defined but never used no-unused-vars
2:22:32 AM: Line 13:7: ‘AnyReactComponent’ is assigned a value but never used no-unused-vars
2:22:32 AM: npm
2:22:32 AM: ERR!
2:22:32 AM: code ELIFECYCLE
2:22:32 AM: npm
2:22:32 AM: ERR! errno 1
2:22:32 AM: npm
2:22:32 AM: ERR!
2:22:32 AM: trydo@0.1.0 build: node scripts/build.js
2:22:32 AM: npm
2:22:32 AM: ERR! Exit status 1
2:22:32 AM: npm
2:22:32 AM: ERR!
2:22:32 AM: npm
2:22:32 AM: ERR!
2:22:32 AM: Failed at the trydo@0.1.0 build script.
2:22:32 AM: npm
2:22:32 AM: ERR! This is probably not a problem with npm. There is likely additional logging output above.
2:22:32 AM: npm
2:22:32 AM: ERR!
2:22:32 AM: A complete log of this run can be found in:
2:22:32 AM: npm
2:22:32 AM: ERR!
2:22:32 AM: /opt/buildhome/.npm/_logs/2020-06-17T17_22_32_558Z-debug.log
2:22:32 AM: ​
2:22:32 AM: ┌─────────────────────────────┐
2:22:32 AM: │ “build.command” failed │
2:22:32 AM: └─────────────────────────────┘
2:22:32 AM: ​
2:22:32 AM: Error message
2:22:32 AM: Command failed with exit code 1: npm run build
2:22:32 AM: ​
2:22:32 AM: Error location
2:22:32 AM: In Build command from settings:
2:22:32 AM: npm run build
2:22:32 AM: ​
2:22:32 AM: Resolved config
2:22:32 AM: build:
2:22:32 AM: command: npm run build
2:22:32 AM: publish: /opt/build/repo/build
2:22:32 AM: Caching artifacts
2:22:32 AM: Started saving node modules
2:22:32 AM: Finished saving node modules
2:22:32 AM: Started saving build plugins
2:22:32 AM: Finished saving build plugins
2:22:32 AM: Started saving pip cache
2:22:32 AM: Finished saving pip cache
2:22:32 AM: Started saving emacs cask dependencies
2:22:32 AM: Finished saving emacs cask dependencies
2:22:32 AM: Started saving maven dependencies
2:22:32 AM: Finished saving maven dependencies
2:22:32 AM: Started saving boot dependencies
2:22:33 AM: Finished saving boot dependencies
2:22:33 AM: Started saving go dependencies
2:22:33 AM: Finished saving go dependencies
2:22:36 AM: Error running command: Build script returned non-zero exit code: 1
2:22:36 AM: Failing build: Failed to build site
2:22:36 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
2:22:36 AM: Finished processing build request in 1m38.287256144s
What am I doing wrong?
hi there, please take a look at this post! it likely holds the answer.
It really worked. For those who are here to check about the problem - the issue was that the Warnings that I had were being considered as errors. As pointed out I could have 2 options - please check the post that I marked as a solution.
Thanks man.
