Hi. I have an issue with building adexin.com website.
Build starts falling down when we delete gatsby plugin “gatsby-plugin-offline”. I also tried to update node version, packages versions (such as gatsby and others) but it doesn’t work. When I start build localy it takes about 3 minutes to build website and all works as expected. Maybe you have any idea what’s wrong?
For now you can see lots of successful builds on adexin.com 'cause we roll-back gatsby-plugin-offline removing.
Deploy log
8:29:25 PM: Waiting for other deploys from your team to complete. Check the queue: https://app.netlify.com/teams/adexin/builds
8:29:41 PM: Build ready to start
8:29:42 PM: build-image version: 0a1758e83bfbac50808190020fce3c2db0af3b3d (focal)
8:29:42 PM: buildbot version: 9ceccb446c16d7f061dcc4b669a4f81e31ee234c
8:29:42 PM: Fetching cached dependencies
8:29:42 PM: Starting to download cache of 1.2GB
8:29:55 PM: Finished downloading cache in 12.552s
8:29:55 PM: Starting to extract cache
8:30:06 PM: Finished extracting cache in 11.723s
8:30:06 PM: Finished fetching cache in 24.363s
8:30:06 PM: Starting to prepare the repo for build
8:30:07 PM: Preparing Git Reference refs/heads/main
8:30:09 PM: Custom functions path detected. Proceeding with the specified path: "netlify/functions"
8:30:09 PM: Custom build command detected. Proceeding with the specified command: "yarn build"
8:30:10 PM: Starting to install dependencies
8:30:10 PM: Python version set to 3.8
8:30:10 PM: Attempting Ruby version 2.7.2, read from environment
8:30:11 PM: Using Ruby version 2.7.2
8:30:11 PM: Started restoring cached go cache
8:30:11 PM: Finished restoring cached go cache
8:30:11 PM: Installing Go version 1.16.5 (requested 1.16.5)
8:30:16 PM: go version go1.16.5 linux/amd64
8:30:16 PM: Using PHP version 8.0
8:30:17 PM: Started restoring cached Node.js version
8:30:18 PM: Finished restoring cached Node.js version
8:30:18 PM: Attempting Node.js version "16.18.1" from .nvmrc
8:30:19 PM: v16.18.1 is already installed.
8:30:19 PM: Now using node v16.18.1 (npm v8.19.2)
8:30:19 PM: Enabling Node.js Corepack
8:30:19 PM: Started restoring cached build plugins
8:30:19 PM: Finished restoring cached build plugins
8:30:19 PM: Started restoring cached corepack dependencies
8:30:19 PM: Finished restoring cached corepack dependencies
8:30:19 PM: Started restoring cached yarn cache
8:30:19 PM: Finished restoring cached yarn cache
8:30:19 PM: Installing Yarn version 1.22.10
8:30:19 PM: Preparing yarn@1.22.10 for immediate activation...
8:30:20 PM: No yarn workspaces detected
8:30:20 PM: Started restoring cached node modules
8:30:20 PM: Finished restoring cached node modules
8:30:20 PM: Installing npm packages using Yarn version 1.22.10
8:30:20 PM: yarn install v1.22.10
8:30:20 PM: [1/5] Validating package.json...
8:30:20 PM: [2/5] Resolving packages...
8:30:21 PM: [3/5] Fetching packages...
8:30:22 PM: info fsevents@2.3.2: The platform "linux" is incompatible with this module.
8:30:22 PM: info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-darwin-arm64@2.5.3: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-darwin-arm64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-darwin-arm64@2.5.3: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @lmdb/lmdb-darwin-x64@2.5.3: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-darwin-x64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-linux-arm@2.5.3: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-linux-arm@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-linux-arm64@2.5.3: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-linux-arm64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-win32-x64@2.5.3: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-win32-x64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-darwin-arm64@2.5.2: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-darwin-arm64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-darwin-arm64@2.5.2: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @lmdb/lmdb-darwin-x64@2.5.2: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-darwin-x64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-linux-arm@2.5.2: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-linux-arm@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-linux-arm64@2.5.2: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-linux-arm64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @lmdb/lmdb-win32-x64@2.5.2: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@lmdb/lmdb-win32-x64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @msgpackr-extract/msgpackr-extract-darwin-arm64@3.0.0: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@msgpackr-extract/msgpackr-extract-darwin-arm64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @msgpackr-extract/msgpackr-extract-darwin-arm64@3.0.0: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @msgpackr-extract/msgpackr-extract-darwin-x64@3.0.0: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@msgpackr-extract/msgpackr-extract-darwin-x64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @msgpackr-extract/msgpackr-extract-linux-arm@3.0.0: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@msgpackr-extract/msgpackr-extract-linux-arm@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @msgpackr-extract/msgpackr-extract-linux-arm64@3.0.0: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@msgpackr-extract/msgpackr-extract-linux-arm64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @msgpackr-extract/msgpackr-extract-win32-x64@3.0.0: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@msgpackr-extract/msgpackr-extract-win32-x64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-darwin-arm64@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-darwin-arm64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-darwin-arm64@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/local-functions-proxy-darwin-x64@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-darwin-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-freebsd-arm64@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-freebsd-arm64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-freebsd-arm64@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/local-functions-proxy-freebsd-x64@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-freebsd-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-linux-arm@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-linux-arm@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-linux-arm64@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-linux-arm64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-linux-ia32@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-linux-ia32@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-linux-ppc64@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-linux-ppc64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-openbsd-x64@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-openbsd-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-win32-ia32@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-win32-ia32@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/local-functions-proxy-win32-ia32@1.1.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/local-functions-proxy-win32-x64@1.1.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/local-functions-proxy-win32-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/routing-local-proxy-darwin-arm64@0.34.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/routing-local-proxy-darwin-arm64@0.34.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/routing-local-proxy-darwin-arm64@0.34.1: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/routing-local-proxy-darwin-x64@0.34.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/routing-local-proxy-darwin-x64@0.34.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/routing-local-proxy-win32-x64@0.34.1: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/routing-local-proxy-win32-x64@0.34.1" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-android-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-android-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-android-arm64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-android-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-android-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-darwin-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-darwin-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-darwin-arm64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-darwin-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-darwin-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-freebsd-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-freebsd-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-freebsd-arm64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-freebsd-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-freebsd-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-linux-32@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-32@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-arm@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-arm@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-mips64le@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-mips64le@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-ppc64le@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-ppc64le@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-riscv64@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-riscv64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-s390x@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-s390x@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-netbsd-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-netbsd-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-openbsd-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-openbsd-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-sunos-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-sunos-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-32@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-windows-32@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-32@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-windows-64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-windows-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-arm64@0.14.25: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-windows-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-android-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-android-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-android-arm64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-android-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-android-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-darwin-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-darwin-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-darwin-arm64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-darwin-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-darwin-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-freebsd-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-freebsd-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-freebsd-arm64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-freebsd-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-freebsd-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-linux-32@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-32@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-arm@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-arm@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-mips64le@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-mips64le@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-ppc64le@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-ppc64le@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-riscv64@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-riscv64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-linux-s390x@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-linux-s390x@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-netbsd-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-netbsd-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-openbsd-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-openbsd-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-sunos-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-sunos-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-32@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-windows-32@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-32@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: info @netlify/esbuild-windows-64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-windows-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-arm64@0.14.39: The platform "linux" is incompatible with this module.
8:30:22 PM: info "@netlify/esbuild-windows-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation.
8:30:22 PM: info @netlify/esbuild-windows-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module.
8:30:22 PM: [4/5] Linking dependencies...
8:30:22 PM: warning " > babel-preset-gatsby@2.25.0" has unmet peer dependency "core-js@^3.0.0".
8:30:22 PM: warning "gatsby > eslint-config-react-app@6.0.0" has unmet peer dependency "babel-eslint@^10.0.0".
8:30:22 PM: warning "gatsby > react-server-dom-webpack@0.0.0-experimental-c8b778b7f-20220825" has incorrect peer dependency "react@0.0.0-experimental-c8b778b7f-20220825".
8:30:22 PM: warning "gatsby > @typescript-eslint/eslint-plugin > tsutils@3.21.0" has unmet peer dependency "typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta".
8:30:22 PM: warning "gatsby > react-dev-utils > fork-ts-checker-webpack-plugin@6.5.2" has unmet peer dependency "typescript@>= 2.7".
8:30:22 PM: warning " > gatsby-source-contentful@7.23.1" has unmet peer dependency "sharp@^0.30.1".
8:30:22 PM: warning " > spinners-react@1.0.7" has unmet peer dependency "@types/react@^16.x || ^17.x || ^18.x".
8:30:22 PM: warning " > spinners-react@1.0.7" has unmet peer dependency "@types/react-dom@^16.x || ^17.x || ^18.x".
8:30:22 PM: warning " > eslint-webpack-plugin@3.2.0" has unmet peer dependency "webpack@^5.0.0".
8:30:22 PM: warning "gatsby-plugin-netlify > webpack-assets-manifest@5.1.0" has unmet peer dependency "webpack@^5.2.0".
8:30:27 PM: [5/5] Building fresh packages...
8:30:27 PM: Done in 6.31s.
8:30:27 PM: npm packages installed using Yarn
8:30:27 PM: Successfully installed dependencies
8:30:27 PM: Starting build script
8:30:28 PM: Detected 1 framework(s)
8:30:28 PM: "gatsby" at version "4.25.4"
8:30:28 PM: Section completed: initializing
8:30:29 PM:
8:30:29 PM: Netlify Build
8:30:29 PM: ────────────────────────────────────────────────────────────────
8:30:29 PM:
8:30:29 PM: ❯ Version
8:30:29 PM: @netlify/build 29.32.0
8:30:29 PM:
8:30:29 PM: ❯ Flags
8:30:29 PM: baseRelDir: true
8:30:29 PM: buildId: 65a82a95b9e72100082aeb40
8:30:29 PM: deployId: 65a82a95b9e72100082aeb42
8:30:29 PM:
8:30:29 PM: ❯ Current directory
8:30:29 PM: /opt/build/repo
8:30:29 PM:
8:30:29 PM: ❯ Config file
8:30:29 PM: /opt/build/repo/netlify.toml
8:30:29 PM:
8:30:29 PM: ❯ Context
8:30:29 PM: production
8:30:29 PM:
8:30:29 PM: ❯ Loading plugins
8:30:29 PM: - @netlify/plugin-gatsby@3.8.0 from Netlify app
8:30:31 PM:
8:30:31 PM: @netlify/plugin-gatsby (onPreBuild event)
8:30:31 PM: ────────────────────────────────────────────────────────────────
8:30:31 PM:
8:30:32 PM: Found a Gatsby cache. We’re about to go FAST. ⚡️
8:30:33 PM:
8:30:33 PM: (@netlify/plugin-gatsby onPreBuild completed in 1.8s)
8:30:33 PM:
8:30:33 PM: build.command from netlify.toml
8:30:33 PM: ────────────────────────────────────────────────────────────────
8:30:33 PM:
8:30:33 PM: $ yarn build
8:30:33 PM: yarn run v1.22.10
8:30:33 PM: $ gatsby build
8:30:35 PM: success compile gatsby files - 1.213s
8:30:35 PM: success load gatsby config - 0.024s
8:30:36 PM: success load plugins - 0.724s
8:30:36 PM: warning gatsby-plugin-react-helmet: Gatsby now has built-in support for modifying the document head. Learn more at https://gatsby.dev/gatsby-head
8:30:36 PM: success onPreInit - 0.006s
8:30:36 PM: success delete worker cache from previous builds - 0.001s
8:30:36 PM: info One or more of your plugins have changed since the last time you ran Gatsby. As
8:30:36 PM: a precaution, we"re deleting your site"s cache to ensure there"s no stale data.
success initialize cache - 0.070s
8:30:36 PM: success copy gatsby files - 0.082s
8:30:37 PM: warning Browserslist: caniuse-lite is outdated. Please run:
8:30:37 PM: npx update-browserslist-db@latest
8:30:37 PM: Why you should do it regularly: https://github.com/browserslist/update-db#readme
8:30:37 PM: success Compiling Gatsby Functions - 1.137s
8:30:37 PM: success onPreBootstrap - 1.148s
8:30:38 PM: success createSchemaCustomization - 0.077s
8:30:38 PM: success Contentful: Sync all items - 0.330s - 2423/2423 7331.35/s
8:30:38 PM: success Contentful: Fetch data - 0.422s
8:30:38 PM: info Contentful: 610 new entries
8:30:38 PM: info Contentful: 1512 updated entries
8:30:38 PM: info Contentful: 0 deleted entries
8:30:38 PM: info Contentful: 0 cached entries
8:30:38 PM: info Contentful: 120 new assets
8:30:38 PM: info Contentful: 181 updated assets
8:30:38 PM: info Contentful: 0 cached assets
8:30:38 PM: info Contentful: 0 deleted assets
8:30:38 PM: info Creating 136 Contentful model SEO nodes
8:30:38 PM: info Creating 53 Contentful model Page nodes
8:30:38 PM: info Creating 1 Contentful section HEADER nodes
8:30:38 PM: info Creating 1 Contentful section FOOTER nodes
8:30:38 PM: info Creating 5 Contentful model Office nodes
8:30:38 PM: info Creating 43 Contentful section CASE nodes
8:30:38 PM: info Creating 11 Contentful model CASE nodes
8:30:38 PM: info Creating 22 Contentful model Testimonial nodes
8:30:38 PM: info Creating 19 Contentful section TESTIMONIAL nodes
8:30:38 PM: info Creating 2 Contentful section CTA_2 nodes
8:30:38 PM: info Creating 11 Contentful section CTA_1 nodes
8:30:38 PM: info Creating 86 Contentful model Technology nodes
8:30:38 PM: info Creating 7 Contentful model Technology Category nodes
8:30:38 PM: info Creating 58 Contentful section HERO nodes
8:30:38 PM: info Creating 326 Contentful model Link Item nodes
8:30:38 PM: info Creating 924 Contentful model LIST Item nodes
8:30:39 PM: info Creating 191 Contentful section LIST nodes
8:30:39 PM: info Creating 35 Contentful section TECH nodes
8:30:39 PM: info Creating 57 Contentful section TEXT nodes
8:30:39 PM: info Creating 58 Contentful model POST nodes
8:30:39 PM: info Creating 7 Contentful section POSTS_EVENTS nodes
8:30:39 PM: info Creating 7 Contentful model EVENT nodes
8:30:39 PM: info Creating 6 Contentful model BLOG CATEGORY or TAG nodes
8:30:39 PM: info Creating 1 Contentful section COOKIES nodes
8:30:39 PM: info Creating 1 Contentful section 404 nodes
8:30:39 PM: info Creating 4 Contentful section BlogArticleTwoImages nodes
8:30:39 PM: info Creating 28 Contentful model Redirect nodes
8:30:39 PM: info Creating 3 Contentful model Author nodes
8:30:39 PM: info Creating 1 Contentful section Who is Adexin nodes
8:30:39 PM: info Creating 2 Contentful model Video nodes
8:30:39 PM: info Creating 3 Contentful model Video Iframe nodes
8:30:39 PM: info Creating 9 Contentful section CERTIFICATION nodes
8:30:39 PM: info Creating 4 Contentful model Certification nodes
8:30:39 PM: info Creating 301 Contentful asset nodes
8:30:40 PM: success Contentful: Create nodes - 1.713s
8:30:40 PM: success Contentful: Process data - 1.738s
8:30:40 PM: success Checking for changed pages - 0.000s
8:30:40 PM: success source and transform nodes - 2.253s
8:30:40 PM: info Writing GraphQL type definitions to /opt/build/repo/.cache/schema.gql
8:30:43 PM: success building schema - 3.176s
8:48:27 PM: Failed during stage "building site": Command did not finish within the time limit
8:48:27 PM: Execution timed out after 18m0.070692281s
8:48:27 PM: Failing build: Failed to build site
8:48:28 PM: Finished processing build request in 18m45.85s
p.s. On the pinned image you can see our website’s build settings.
