Need help with build issue on development version of the website
Hi! We need help with building our website via Netlify. Our site’s development version “https://adexin-dev.netlify.app/” cannot finish building, but production version “https://adexin.com/” builds correctly. Also website builds locally without any issues. On development version build stops during Gatsby pages generation (after querying data), sometimes it happens during environment initialisation. The only error we get - time limit. Build stops and exceed the limit (15 mins).
Build settings
Runtime: Gatsby
Base directory: /
Package directory: Not set
Build command: cleanbuild
Publish directory: public
Functions directory: .netlify/functions
Build status: Active
Deploy log
7:33:30 PM: build-image version: 50f2c07b4ff67fac131b5b345ef7efb7e0ab9dac (focal) 7:33:30 PM: buildbot version: a81fb56146e7899d8af4a51f201d786e8b10cbf4 7:33:30 PM: Fetching cached dependencies 7:33:30 PM: Starting to download cache of 1.1GB 7:33:48 PM: Finished downloading cache in 18.418s 7:33:48 PM: Starting to extract cache 7:33:56 PM: Finished extracting cache in 7.72s 7:33:56 PM: Finished fetching cache in 26.265s 7:33:56 PM: Starting to prepare the repo for build 7:33:57 PM: Preparing Git Reference refs/heads/develop 7:33:58 PM: Custom functions path detected. Proceeding with the specified path: "netlify/functions" 7:33:58 PM: Custom build command detected. Proceeding with the specified command: "yarn cleanbuild" 7:33:59 PM: Starting to install dependencies 7:33:59 PM: Python version set to 3.8 7:33:59 PM: Attempting Ruby version 2.7.2, read from environment 7:34:00 PM: Using Ruby version 2.7.2 7:34:00 PM: Started restoring cached go cache 7:34:00 PM: Finished restoring cached go cache 7:34:00 PM: Installing Go version 1.16.5 (requested 1.16.5) 7:34:06 PM: go version go1.16.5 linux/amd64 7:34:07 PM: Using PHP version 8.0 7:34:07 PM: Started restoring cached Node.js version 7:34:08 PM: Finished restoring cached Node.js version 7:34:08 PM: Attempting Node.js version "14" from .nvmrc 7:34:09 PM: v14.21.3 is already installed. 7:34:09 PM: Now using node v14.21.3 (npm v6.14.18) 7:34:09 PM: Enabling Node.js Corepack 7:34:09 PM: Started restoring cached build plugins 7:34:09 PM: Finished restoring cached build plugins 7:34:09 PM: Started restoring cached corepack dependencies 7:34:09 PM: Finished restoring cached corepack dependencies 7:34:09 PM: Started restoring cached yarn cache 7:34:14 PM: Finished restoring cached yarn cache 7:34:15 PM: Installing Yarn version 1.22.10 7:34:15 PM: Preparing yarn@1.22.10 for immediate activation... 7:34:15 PM: No yarn workspaces detected 7:34:15 PM: Started restoring cached node modules 7:34:15 PM: Finished restoring cached node modules 7:34:15 PM: Installing npm packages using Yarn version 1.22.10 7:34:16 PM: yarn install v1.22.10 7:34:16 PM: [1/5] Validating package.json... 7:34:16 PM: [2/5] Resolving packages... 7:34:16 PM: [3/5] Fetching packages... 7:34:17 PM: info fsevents@2.3.2: The platform "linux" is incompatible with this module. 7:34:17 PM: info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-darwin-arm64@2.5.3: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-darwin-arm64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-darwin-arm64@2.5.3: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @lmdb/lmdb-darwin-x64@2.5.3: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-darwin-x64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-linux-arm@2.5.3: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-linux-arm@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-linux-arm64@2.5.3: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-linux-arm64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-win32-x64@2.5.3: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-win32-x64@2.5.3" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-darwin-arm64@2.5.2: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-darwin-arm64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-darwin-arm64@2.5.2: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @lmdb/lmdb-darwin-x64@2.5.2: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-darwin-x64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-linux-arm@2.5.2: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-linux-arm@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-linux-arm64@2.5.2: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-linux-arm64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @lmdb/lmdb-win32-x64@2.5.2: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@lmdb/lmdb-win32-x64@2.5.2" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @msgpackr-extract/msgpackr-extract-darwin-arm64@3.0.0: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@msgpackr-extract/msgpackr-extract-darwin-arm64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @msgpackr-extract/msgpackr-extract-darwin-arm64@3.0.0: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @msgpackr-extract/msgpackr-extract-darwin-x64@3.0.0: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@msgpackr-extract/msgpackr-extract-darwin-x64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @msgpackr-extract/msgpackr-extract-linux-arm@3.0.0: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@msgpackr-extract/msgpackr-extract-linux-arm@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @msgpackr-extract/msgpackr-extract-linux-arm64@3.0.0: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@msgpackr-extract/msgpackr-extract-linux-arm64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @msgpackr-extract/msgpackr-extract-win32-x64@3.0.0: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@msgpackr-extract/msgpackr-extract-win32-x64@3.0.0" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-darwin-arm64@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-darwin-arm64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-darwin-arm64@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/local-functions-proxy-darwin-x64@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-darwin-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-freebsd-arm64@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-freebsd-arm64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-freebsd-arm64@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/local-functions-proxy-freebsd-x64@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-freebsd-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-linux-arm@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-linux-arm@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-linux-arm64@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-linux-arm64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-linux-ia32@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-linux-ia32@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-linux-ppc64@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-linux-ppc64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-openbsd-x64@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-openbsd-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-win32-ia32@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-win32-ia32@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/local-functions-proxy-win32-ia32@1.1.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/local-functions-proxy-win32-x64@1.1.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/local-functions-proxy-win32-x64@1.1.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/routing-local-proxy-darwin-arm64@0.34.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/routing-local-proxy-darwin-arm64@0.34.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/routing-local-proxy-darwin-arm64@0.34.1: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/routing-local-proxy-darwin-x64@0.34.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/routing-local-proxy-darwin-x64@0.34.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/routing-local-proxy-win32-x64@0.34.1: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/routing-local-proxy-win32-x64@0.34.1" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-android-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-android-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-android-arm64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-android-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-android-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-darwin-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-darwin-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-darwin-arm64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-darwin-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-darwin-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-freebsd-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-freebsd-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-freebsd-arm64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-freebsd-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-freebsd-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-linux-32@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-32@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-arm@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-arm@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-mips64le@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-mips64le@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-ppc64le@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-ppc64le@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-riscv64@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-riscv64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-s390x@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-s390x@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-netbsd-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-netbsd-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-openbsd-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-openbsd-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-sunos-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-sunos-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-32@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-windows-32@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-32@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-windows-64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-windows-64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-arm64@0.14.25: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-windows-arm64@0.14.25" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-arm64@0.14.25: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-android-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-android-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-android-arm64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-android-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-android-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-darwin-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-darwin-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-darwin-arm64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-darwin-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-darwin-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-freebsd-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-freebsd-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-freebsd-arm64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-freebsd-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-freebsd-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-linux-32@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-32@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-arm@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-arm@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-mips64le@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-mips64le@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-ppc64le@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-ppc64le@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-riscv64@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-riscv64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-linux-s390x@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-linux-s390x@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-netbsd-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-netbsd-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-openbsd-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-openbsd-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-sunos-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-sunos-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-32@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-windows-32@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-32@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: info @netlify/esbuild-windows-64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-windows-64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-arm64@0.14.39: The platform "linux" is incompatible with this module. 7:34:17 PM: info "@netlify/esbuild-windows-arm64@0.14.39" is an optional dependency and failed compatibility check. Excluding it from installation. 7:34:17 PM: info @netlify/esbuild-windows-arm64@0.14.39: The CPU architecture "x64" is incompatible with this module. 7:34:17 PM: [4/5] Linking dependencies... 7:34:17 PM: warning " > babel-preset-gatsby@2.25.0" has unmet peer dependency "core-js@^3.0.0". 7:34:17 PM: warning "gatsby > eslint-config-react-app@6.0.0" has unmet peer dependency "babel-eslint@^10.0.0". 7:34:17 PM: warning "gatsby > react-server-dom-webpack@0.0.0-experimental-c8b778b7f-20220825" has incorrect peer dependency "react@0.0.0-experimental-c8b778b7f-20220825". 7:34:17 PM: warning "gatsby > @typescript-eslint/eslint-plugin > tsutils@3.21.0" has unmet peer dependency "typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta". 7:34:17 PM: warning "gatsby > react-dev-utils > fork-ts-checker-webpack-plugin@6.5.2" has unmet peer dependency "typescript@>= 2.7". 7:34:17 PM: warning " > gatsby-source-contentful@7.23.1" has unmet peer dependency "sharp@^0.30.1". 7:34:17 PM: warning " > spinners-react@1.0.7" has unmet peer dependency "@types/react@^16.x || ^17.x || ^18.x". 7:34:17 PM: warning " > spinners-react@1.0.7" has unmet peer dependency "@types/react-dom@^16.x || ^17.x || ^18.x". 7:34:17 PM: warning " > eslint-webpack-plugin@3.2.0" has unmet peer dependency "webpack@^5.0.0". 7:34:17 PM: warning "gatsby-plugin-netlify > webpack-assets-manifest@5.1.0" has unmet peer dependency "webpack@^5.2.0". 7:34:21 PM: [5/5] Building fresh packages... 7:34:21 PM: success Saved lockfile. 7:34:21 PM: Done in 5.56s. 7:34:21 PM: npm packages installed using Yarn 7:34:22 PM: Install dependencies script success 7:34:22 PM: Starting build script 7:34:22 PM: Detected 1 framework(s) 7:34:22 PM: "gatsby" at version "4.25.4" 7:34:22 PM: Section completed: initializing 7:34:24 PM: ​ 7:34:24 PM: Netlify Build 7:34:24 PM: ──────────────────────────────────────────────────────────────── 7:34:24 PM: ​ 7:34:24 PM: ❯ Version 7:34:24 PM: @netlify/build 29.24.3 7:34:24 PM: ​ 7:34:24 PM: ❯ Flags 7:34:24 PM: baseRelDir: true 7:34:24 PM: buildId: 653ff6f8ee988526a6aeedbd 7:34:24 PM: deployId: 653ff6f8ee988526a6aeedbf 7:34:24 PM: ​ 7:34:24 PM: ❯ Current directory 7:34:24 PM: /opt/build/repo 7:34:24 PM: ​ 7:34:24 PM: ❯ Config file 7:34:24 PM: /opt/build/repo/netlify.toml 7:34:24 PM: ​ 7:34:24 PM: ❯ Context 7:34:24 PM: production 7:34:24 PM: ​ 7:34:24 PM: ❯ Loading plugins 7:34:24 PM: - @netlify/plugin-gatsby@3.7.2 from Netlify app 7:34:25 PM: ​ 7:34:25 PM: @netlify/plugin-gatsby (onPreBuild event) 7:34:25 PM: ──────────────────────────────────────────────────────────────── 7:34:25 PM: ​ 7:34:26 PM: Found a Gatsby cache. We’re about to go FAST. ⚡️ 7:34:26 PM: ​ 7:34:26 PM: (@netlify/plugin-gatsby onPreBuild completed in 1s) 7:34:26 PM: ​ 7:34:26 PM: build.command from netlify.toml 7:34:26 PM: ──────────────────────────────────────────────────────────────── 7:34:26 PM: ​ 7:34:26 PM: $ yarn cleanbuild 7:34:26 PM: yarn run v1.22.10 7:34:26 PM: $ gatsby clean && gatsby build 7:34:27 PM: info Deleting .cache, public, /opt/build/repo/node_modules/.cache/babel-loader, /opt/build/repo/node_modules/.cache/terser-webpack-plugin 7:34:27 PM: info Successfully deleted directories 7:34:29 PM: success compile gatsby files - 0.937s 7:34:29 PM: success load gatsby config - 0.029s 7:34:30 PM: success load plugins - 0.861s 7:34:30 PM: warning gatsby-plugin-react-helmet: Gatsby now has built-in support for modifying the document head. Learn more at https://gatsby.dev/gatsby-head 7:34:30 PM: success onPreInit - 0.006s 7:34:30 PM: success initialize cache - 0.041s 7:34:30 PM: success copy gatsby files - 0.088s 7:34:30 PM: warning Browserslist: caniuse-lite is outdated. Please run: 7:34:30 PM: npx update-browserslist-db@latest 7:34:30 PM: Why you should do it regularly: https://github.com/browserslist/update-db#readme 7:34:31 PM: success Compiling Gatsby Functions - 0.707s 7:34:31 PM: success onPreBootstrap - 0.716s 7:34:31 PM: success createSchemaCustomization - 0.072s 7:34:32 PM: success Contentful: Sync all items - 0.318s - 2007/2007 6319.62/s 7:34:32 PM: success Contentful: Fetch data - 0.411s 7:34:32 PM: info Contentful: 334 new entries 7:34:32 PM: info Contentful: 1412 updated entries 7:34:32 PM: info Contentful: 0 deleted entries 7:34:32 PM: info Contentful: 0 cached entries 7:34:32 PM: info Contentful: 90 new assets 7:34:32 PM: info Contentful: 171 updated assets 7:34:32 PM: info Contentful: 0 cached assets 7:34:32 PM: info Contentful: 0 deleted assets 7:34:32 PM: info Creating 106 Contentful model SEO nodes 7:34:32 PM: info Creating 50 Contentful model Page nodes 7:34:32 PM: info Creating 1 Contentful section HEADER nodes 7:34:32 PM: info Creating 1 Contentful section FOOTER nodes 7:34:32 PM: info Creating 5 Contentful model Office nodes 7:34:32 PM: info Creating 41 Contentful section CASE nodes 7:34:32 PM: info Creating 11 Contentful model CASE nodes 7:34:32 PM: info Creating 22 Contentful model Testimonial nodes 7:34:32 PM: info Creating 19 Contentful section TESTIMONIAL nodes 7:34:32 PM: info Creating 2 Contentful section CTA_2 nodes 7:34:32 PM: info Creating 11 Contentful section CTA_1 nodes 7:34:32 PM: info Creating 86 Contentful model Technology nodes 7:34:32 PM: info Creating 7 Contentful model Technology Category nodes 7:34:32 PM: info Creating 55 Contentful section HERO nodes 7:34:32 PM: info Creating 292 Contentful model Link Item nodes 7:34:32 PM: info Creating 687 Contentful model LIST Item nodes 7:34:32 PM: info Creating 148 Contentful section LIST nodes 7:34:32 PM: info Creating 34 Contentful section TECH nodes 7:34:32 PM: info Creating 55 Contentful section TEXT nodes 7:34:32 PM: info Creating 31 Contentful model POST nodes 7:34:32 PM: info Creating 5 Contentful section POSTS_EVENTS nodes 7:34:32 PM: info Creating 7 Contentful model EVENT nodes 7:34:32 PM: info Creating 15 Contentful model BLOG CATEGORY or TAG nodes 7:34:32 PM: info Creating 1 Contentful section COOKIES nodes 7:34:32 PM: info Creating 1 Contentful section 404 nodes 7:34:32 PM: info Creating 4 Contentful section BlogArticleTwoImages nodes 7:34:32 PM: info Creating 27 Contentful model Redirect nodes 7:34:32 PM: info Creating 3 Contentful model Author nodes 7:34:32 PM: info Creating 1 Contentful section Who is Adexin nodes 7:34:32 PM: info Creating 2 Contentful model Video nodes 7:34:32 PM: info Creating 3 Contentful model Video Iframe nodes 7:34:32 PM: info Creating 9 Contentful section CERTIFICATION nodes 7:34:32 PM: info Creating 4 Contentful model Certification nodes 7:34:32 PM: info Creating 261 Contentful asset nodes 7:34:33 PM: success Contentful: Create nodes - 1.334s 7:34:33 PM: success Contentful: Process data - 1.356s 7:34:33 PM: success Checking for changed pages - 0.000s 7:34:33 PM: success source and transform nodes - 1.860s 7:34:34 PM: info Writing GraphQL type definitions to /opt/build/repo/.cache/schema.gql 7:34:37 PM: success building schema - 3.615s 7:52:32 PM: Failed during stage "building site": Command did not finish within the time limit 7:52:32 PM: Execution timed out after 18m10.001280998s 7:52:32 PM: Error running command: Command did not finish within the time limit 7:52:32 PM: Failing build: Failed to build site 7:52:32 PM: Finished processing build request in 19m2.127s
Hi @filimonov-adexin,
Thanks for reaching out!
I’ve increased the build time limit to 45 minutes. Could you try deploying again and let us know if you continue to have issues?
Hi, Melvin! Thanks for your help, but we still have the same issue. Sometimes we have successfull builds (1 from 7-8), but time of this build is about 4 minutes. Maybe you can propose anothe way to fix it?
@filimonov-adexin, I’m seeing a lot of successful builds for adexin-dev. Is this resolved?
