hello,
currently i have an issue with my wildside-prod application:
1:29:12 PM: npm ERR! code ELIFECYCLE
1:29:12 PM: npm ERR! errno 1
1:29:12 PM: npm ERR! wildside@0.1.0 build: concurrently "react-scripts build" "npm run build:lambda"
1:29:12 PM: npm ERR! Exit status 1
1:29:12 PM: npm ERR! Failed at the wildside@0.1.0 build script.
1:29:12 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
1:29:12 PM: npm ERR! A complete log of this run can be found in:
1:29:12 PM: npm ERR! /opt/buildhome/.npm/_logs/2021-03-08T18_29_12_182Z-debug.log
1:29:12 PM:
1:29:12 PM: ────────────────────────────────────────────────────────────────
1:29:12 PM: “build.command” failed
1:29:12 PM:
1:29:12 PM: Error message
1:29:12 PM: Command failed with exit code 1: npm run build
1:29:12 PM:
1:29:12 PM: Error location
1:29:12 PM: In build.command from netlify.toml:
1:29:12 PM: npm run build
1:29:12 PM:
1:29:12 PM: Resolved config
1:29:12 PM: build:
1:29:12 PM: command: npm run build
1:29:12 PM: commandOrigin: config
1:29:12 PM: environment:
1:29:12 PM: - ADMIN_EMAIL
1:29:12 PM: - EMAIL_ACCOUNT
1:29:12 PM: - EMAIL_PASSWORD
1:29:12 PM: - FIREBASE_CLIENT_EMAIL
1:29:12 PM: - FIREBASE_PRIVATE_KEY
1:29:12 PM: functions: /opt/build/repo/lambda-build
1:29:12 PM: publish: /opt/build/repo/build
1:29:12 PM: redirects:
1:29:12 PM: - from: /*
status: 200
to: /index.html
Caching artifacts
1:29:12 PM: Started saving node modules
I cant find any logs file to debug this issue.
Also i’ve checked modules version and it seems to be correct.
Could you help me please
