hi there, we were unable to complete building your site as there is some kind of configuration error, most likely:
8:15:49 AM: $ npm run build
8:15:49 AM: > react@0.0.0 build /opt/build/repo
8:15:49 AM: > react-scripts build
8:15:50 AM: Could not find a required file.
8:15:50 AM: Name: index.html
8:15:50 AM: Searched in: /opt/build/repo/public
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: code
8:15:50 AM: ELIFECYCLE
8:15:50 AM: npm
8:15:50 AM: ERR! errno
8:15:50 AM: 1
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: react@0.0.0 build: `react-scripts build`
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: Exit status 1
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: Failed at the react@0.0.0 build script.
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: This is probably not a problem with npm. There is likely additional logging output above.
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: A complete log of this run can be found in:
8:15:50 AM: npm
8:15:50 AM: ERR!
8:15:50 AM: /opt/buildhome/.npm/_logs/2020-06-07T15_15_50_845Z-debug.log
8:15:50 AM:
8:15:50 AM: ┌─────────────────────────────┐
8:15:50 AM: │ "build.command" failed │
8:15:50 AM: └─────────────────────────────┘
8:15:50 AM:
8:15:50 AM: Error message
8:15:50 AM: Command failed with exit code 1: npm run build
8:15:50 AM:
8:15:50 AM: Error location
8:15:50 AM: In Build command from settings:
8:15:50 AM: npm run build
8:15:50 AM:
8:15:50 AM: Resolved config
8:15:50 AM: build:
8:15:50 AM: command: npm run build
8:15:50 AM: publish: /opt/build/repo/build
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem ![]()
If you are still having problems, please provide as much information as you can on what you have already tried, what your build settings are, your package.json, etc. Thanks!
