The site name is didymus7007.netlify.app
This is a react app and I am deploying with netlify for the first time ever.
npm run build works well locally because I get the compiled successfully and other information in my terminal
9:10:00 PM: Build ready to start
9:10:02 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
9:10:02 PM: build-image tag: v3.4.1
9:10:02 PM: buildbot version: 8c957a6d09a03023cea4239847cc73a9cb64eeb7
9:10:03 PM: Fetching cached dependencies
9:10:03 PM: Failed to fetch cache, continuing with build
9:10:03 PM: Starting to prepare the repo for build
9:10:03 PM: No cached dependencies found. Cloning fresh repo
9:10:03 PM: git clone GitHub - didymus707/my-portfolio: This app is a portfolio for the things you need to know about me
9:10:04 PM: Preparing Git Reference refs/heads/development
9:10:05 PM: Starting build script
9:10:05 PM: Installing dependencies
9:10:05 PM: Python version set to 2.7
9:10:06 PM: v12.18.0 is already installed.
9:10:07 PM: Now using node v12.18.0 (npm v6.14.4)
9:10:07 PM: Started restoring cached build plugins
9:10:07 PM: Finished restoring cached build plugins
9:10:07 PM: Attempting ruby version 2.7.1, read from environment
9:10:08 PM: Using ruby version 2.7.1
9:10:09 PM: Using PHP version 5.6
9:10:09 PM: 5.2 is already installed.
9:10:09 PM: Using Swift version 5.2
9:10:09 PM: Started restoring cached go cache
9:10:09 PM: Finished restoring cached go cache
9:10:09 PM: go version go1.14.4 linux/amd64
9:10:09 PM: Installing missing commands
9:10:09 PM: Verify run directory
9:10:10 PM:
9:10:10 PM: ┌─────────────────────────────┐
9:10:10 PM: │ Netlify Build │
9:10:10 PM: └─────────────────────────────┘
9:10:10 PM:
9:10:10 PM: ❯ Version
9:10:10 PM: @netlify/build 3.3.5
9:10:10 PM:
9:10:10 PM: ❯ Flags
9:10:10 PM: deployId: 5f63c298957577436afce89b
9:10:10 PM: mode: buildbot
9:10:10 PM:
9:10:10 PM: ❯ Current directory
9:10:10 PM: /opt/build/repo
9:10:10 PM:
9:10:10 PM: ❯ Config file
9:10:10 PM: No config file was defined: using default values.
9:10:10 PM:
9:10:10 PM: ❯ Context
9:10:10 PM: production
9:10:10 PM:
9:10:10 PM: ┌───────────────────────────────────┐
9:10:10 PM: │ 1. Build command from Netlify app │
9:10:10 PM: └───────────────────────────────────┘
9:10:10 PM:
9:10:10 PM: $ npm run build
9:10:10 PM: npm ERR! code ENOENT
9:10:10 PM: npm ERR! syscall open
9:10:10 PM: npm ERR! path /opt/build/repo/package.json
9:10:10 PM: npm ERR! errno -2
9:10:10 PM: npm ERR! enoent ENOENT: no such file or directory, open ‘/opt/build/repo/package.json’
9:10:10 PM: npm ERR! enoent This is related to npm not being able to find a file.
9:10:10 PM: npm ERR! A complete log of this run can be found in:
9:10:10 PM: npm ERR! /opt/buildhome/.npm/_logs/2020-09-17T20_10_10_544Z-debug.log
9:10:10 PM:
9:10:10 PM: │ “build.command” failed │
9:10:10 PM:
9:10:10 PM: Error message
9:10:10 PM: Command failed with exit code 254: npm run build
9:10:10 PM:
9:10:10 PM: Error location
9:10:10 PM: In Build command from Netlify app:
9:10:10 PM: npm run build
9:10:10 PM:
9:10:10 PM: Resolved config
9:10:10 PM: build:
9:10:10 PM: command: npm run build
9:10:10 PM: commandOrigin: ui
9:10:10 PM: publish: /opt/build/repo/build
9:10:10 PM: Caching artifacts
9:10:10 PM: Started saving build plugins
9:10:10 PM: Finished saving build plugins
9:10:10 PM: Started saving pip cache
9:10:10 PM: Finished saving pip cache
9:10:10 PM: Started saving emacs cask dependencies
9:10:10 PM: Finished saving emacs cask dependencies
9:10:10 PM: Started saving maven dependencies
9:10:10 PM: Finished saving maven dependencies
9:10:10 PM: Started saving boot dependencies
9:10:10 PM: Finished saving boot dependencies
9:10:10 PM: Started saving go dependencies
9:10:10 PM: Finished saving go dependencies
9:10:13 PM: Error running command: Build script returned non-zero exit code: 1
9:10:13 PM: Failing build: Failed to build site
9:10:13 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
9:10:13 PM: Finished processing build request in 11.182315716s
Below is my package.json file
"name": "my-portfolio",
"version": "0.1.0",
"private": true,
"dependencies": {
"@testing-library/jest-dom": "^4.2.4",
"@testing-library/react": "^9.3.2",
"@testing-library/user-event": "^7.1.2",
"react": "^16.13.1",
"react-dom": "^16.13.1",
"react-mdl": "^2.1.0",
"react-router-dom": "^5.2.0",
"react-scripts": "3.4.3"
"scripts": {
"start": "react-scripts start",
"build": "react-scripts build",
"test": "react-scripts test",
"eject": "react-scripts eject"
"eslintConfig": {
"extends": "react-app"
"browserslist": {
"production": [
">0.2%",
"not dead",
"not op_mini all"
"development": [
"last 1 chrome version",
"last 1 firefox version",
"last 1 safari version"
