Hey Team,
These days I noticed build is failing for VueJs projects. I tried all possible solutions as following
specifing the node version in the environment
updating the build command to “CI: npm run build” and specifying a env variable as CI to false and tried deploying
Updating netlify.toml file with the required build commands and publish directory
But none of them got worked. I tried even reaching to support team, but no reply.
Can you please suggest any solution?
SamO
May 17, 2023, 7:24pm
2
Hi, I’m happy to suggest solutions, but it would be helpful if I could locate the site that is impacted. Mind sharing a site name?
Hey Sam,
Sure here is the site name that I just tried 30mins before https://bucolic-tanuki-12fc7e.netlify.app/
Please suggest me any solution
Hey Sam,
I see this vee-validate is creating an issue, but not sure how to resolve it as I tried the solutions that I came across and am aware of. Please check the below screen
Hope this helps to find the issue, please let me if you’ve any solution
Not sure if this would fix it, but you can try changing the build command to vue-tsc --noEmit --skipLibCheck
