Hello,
My Hugo site suddenly starts failing during build. The build takes very long and after processing Forms all start crashing. No changes in forms have been done.
Most concerning part
6:44:50 AM: Error: Deploy did not succeed: Failed to execute deploy: timed out while waiting to enter states [prepared, ready]
- idarek.netlify.app
- Custom domain: dariusz.wieckiewicz.org
Log:
7:00:01 AM: Waiting for other deploys from your team to complete. Check the queue: https://app.netlify.com/teams/idarek/builds
7:18:51 AM: Build ready to start
7:18:56 AM: build-image version: 122b31996ccaffd45d820a452d6227f8312110cc (focal)
7:18:56 AM: build-image tag: v4.5.3
7:18:56 AM: buildbot version: 6aae4d21fd1b7e33a10a9c03ca8e663d0c79b21d
7:18:56 AM: Fetching cached dependencies
7:18:57 AM: Starting to download cache of 1.3GB
7:19:11 AM: Finished downloading cache in 14.941078317s
7:19:11 AM: Starting to extract cache
7:19:28 AM: Finished extracting cache in 17.040043632s
7:19:28 AM: Finished fetching cache in 32.084708656s
7:19:28 AM: Starting to prepare the repo for build
7:19:29 AM: Preparing Git Reference refs/heads/master
7:19:34 AM: Parsing package.json dependencies
7:19:34 AM: Starting build script
7:19:35 AM: Installing dependencies
7:19:35 AM: Python version set to 2.7
7:19:35 AM: Started restoring cached node version
7:19:39 AM: Finished restoring cached node version
7:19:39 AM: v12.18.0 is already installed.
7:19:39 AM: Now using node v12.18.0 (npm v6.14.4)
7:19:39 AM: Started restoring cached build plugins
7:19:39 AM: Finished restoring cached build plugins
7:19:39 AM: Attempting ruby version 2.7.1, read from environment
7:19:40 AM: Started restoring cached ruby version
7:19:40 AM: Finished restoring cached ruby version
7:19:41 AM: Using ruby version 2.7.1
7:19:42 AM: Using PHP version 8.0
7:19:42 AM: Installing Hugo 0.92.2
7:19:42 AM: hugo v0.92.2-CDF6A0D6+extended linux/amd64 BuildDate=2022-02-11T14:17:39Z VendorInfo=gohugoio
7:19:42 AM: Started restoring cached go cache
7:19:43 AM: Finished restoring cached go cache
7:19:43 AM: Installing Go version 1.14.4
7:19:43 AM: unset GOOS;
7:19:43 AM: unset GOARCH;
7:19:43 AM: export GOROOT='/opt/buildhome/.gimme_cache/versions/go1.14.4.linux.amd64';
7:19:43 AM: export PATH="/opt/buildhome/.gimme_cache/versions/go1.14.4.linux.amd64/bin:${PATH}";
7:19:43 AM: go version >&2;
7:19:43 AM: export GIMME_ENV='/opt/buildhome/.gimme_cache/env/go1.14.4.linux.amd64.env';
7:19:43 AM: go version go1.14.4 linux/amd64
7:19:43 AM: Installing missing commands
7:19:43 AM: Verify run directory
7:19:44 AM: β
7:19:44 AM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
7:19:44 AM: Netlify Build
7:19:44 AM: β
7:19:44 AM: β― Version
7:19:44 AM: @netlify/build 26.3.14
7:19:44 AM: β
7:19:44 AM: β― Flags
7:19:44 AM: baseRelDir: true
7:19:44 AM: buildId: 622067714230b800075da90a
7:19:44 AM: deployId: 622067714230b800075da90c
7:19:44 AM: β
7:19:44 AM: β― Current directory
7:19:44 AM: /opt/build/repo
7:19:44 AM: β
7:19:44 AM: β― Config file
7:19:44 AM: /opt/build/repo/netlify.toml
7:19:44 AM: β
7:19:44 AM: β― Context
7:19:44 AM: production
7:19:44 AM: β
7:19:44 AM: 1. build.command from netlify.toml
7:19:44 AM: β
7:19:44 AM: $ hugo --gc --minify
7:19:44 AM: Start building sites β¦
7:19:44 AM: hugo v0.92.2-CDF6A0D6+extended linux/amd64 BuildDate=2022-02-11T14:17:39Z VendorInfo=gohugoio
7:19:59 AM: | PL | EN
7:19:59 AM: -------------------+------+------
7:19:59 AM: Pages | 3186 | 338
7:19:59 AM: Paginator pages | 236 | 17
7:19:59 AM: Non-page files | 2509 | 0
7:19:59 AM: Static files | 12 | 12
7:19:59 AM: Processed images | 0 | 0
7:19:59 AM: Aliases | 1512 | 156
7:19:59 AM: Sitemaps | 2 | 1
7:19:59 AM: Cleaned | 0 | 0
7:19:59 AM: Total in 15064 ms
7:19:59 AM: β
7:19:59 AM: (build.command completed in 15.1s)
7:19:59 AM: β
7:19:59 AM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
7:19:59 AM: 2. Deploy site
7:19:59 AM: β
7:19:59 AM: Starting to deploy site from 'public'
7:20:00 AM: Creating deploy tree asynchronously
7:20:01 AM: Creating deploy upload records
7:20:06 AM: Starting post processing
7:20:06 AM: Post processing - HTML
7:21:54 AM: Processing form - contact-en
7:21:54 AM: Detected form fields:
7:21:55 AM: - Name
7:21:55 AM: - bot-field
7:21:55 AM: - Email address
7:21:55 AM: - Your message
7:21:55 AM: - subject
7:22:07 AM: Processing form - contact-pl
7:22:07 AM: Detected form fields:
7:22:07 AM: - ImiΔ
7:22:07 AM: - bot-field
7:22:07 AM: - Adres email
7:22:07 AM: - Twoja wiadomoΕΔ
7:22:08 AM: - subject
7:25:01 AM: β
7:25:01 AM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
7:25:01 AM: Internal error during "Deploy site"
7:25:01 AM: β
7:25:01 AM: Error message
7:25:01 AM: Error: Deploy did not succeed: Failed to execute deploy: timed out while waiting to enter states [prepared, ready]
7:25:01 AM: β
7:25:01 AM: Error location
7:25:01 AM: During Deploy site
7:25:01 AM: at handleDeployError (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/plugins_core/deploy/buildbot_client.js:87:18)
7:25:01 AM: at deploySiteWithBuildbotClient (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/plugins_core/deploy/buildbot_client.js:68:12)
7:25:01 AM: at processTicksAndRejections (node:internal/process/task_queues:96:5)
7:25:01 AM: at async coreStep (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/plugins_core/deploy/index.js:45:5)
7:25:01 AM: at async fireCoreStep (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/steps/core_step.js:39:9)
7:25:01 AM: at async tFireStep (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/time/main.js:20:59)
7:25:01 AM: at async runStep (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/steps/run_step.js:88:7)
7:25:01 AM: at async pReduce.index (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/steps/run_steps.js:91:11)
7:25:01 AM: at async runSteps (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/steps/run_steps.js:51:7)
7:25:01 AM: at async runBuild (file:///opt/buildhome/node-deps/node_modules/@netlify/build/src/core/main.js:610:7)
7:25:01 AM: β
7:25:01 AM: Resolved config
7:25:01 AM: build:
7:25:01 AM: command: hugo --gc --minify
7:25:01 AM: commandOrigin: config
7:25:01 AM: environment:
7:25:01 AM: - HUGO_VERSION
7:25:01 AM: - HUGO_ENV
7:25:01 AM: - HUGO_ENABLEGITINFO
7:25:01 AM: publish: /opt/build/repo/public
7:25:01 AM: publishOrigin: config
7:25:01 AM: headers:
7:25:02 AM: - for: /*
values:
Content-Security-Policy: 'base-uri ''self'' ''unsafe-inline'' ''unsafe-eval'' https: data:'
Expect-CT: max-age=0
Permissions-Policy: accelerometer=(), camera=(), geolocation=(), gyroscope=(), magnetometer=(), microphone=(), payment=(), usb=()
Referrer-Policy: strict-origin-when-cross-origin
Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
Vary: Accept-Encoding
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
- for: /*.ico
values:
Cache-Control: public, max-age=31536000, immutable
- for: /*.js
values:
- for: /pobierz/*
values:
- for: /*.pdf
values:
- for: /*.7z
values:
- for: /*.zip
values:
- for: /*.css
values:
- for: /*.woff
values:
- for: /*.woff2
values:
- for: /images/*
values:
- for: /*.jpg
values:
- for: /*.jpeg
values:
- for: /*.gif
values:
- for: /*.png
values:
- for: /*.webp
values:
Cache-Control: public, max-age=31536000, immutable`
- for: /*.svg
values:
- for: /*.html
values:
Cache-Control: public, max-age=0, must-revalidate
redirects:
- force: true
status: 301
to: https://dariusz.wieckiewicz.org
- force: true
status: 301
to: https://dariusz.wieckiewicz.org/:splat
- force: true
status: 200
to: https://dariusz.wieckiewicz.org/ads.txt
- force: true
status: 301
- force: true
status: 301
status: 200
to: https://www.google-analytics.com/collect
to: /
to: /index.xml
to: /index.xml
to: /index.xml
to: /index.xml
to: /index.xml
to: /index.xml
to: /en/index.xml
to: /en/index.xml
to: /en/index.xml
to: /en/index.xml
to: /en/index.xml
to: /en/index.xml
to: /
to: /sitemap.xml
to: /sitemap.xml
to: /sitemap.xml
to: /kategoria/apple
to: /images/:splat
to: /images/:splat
to: https://www.youtube.com/user/ITDarek/
to: /kategoria/android
to: /kategoria/artykuΕy
to: /kategoria/blog
to: /kategoria/dydaktyka
to: /kategoria/finanse
to: /kategoria/firma
to: /kategoria/gry
to: /kategoria/internet
to: /kategoria/komputery
to: /kategoria/kulinaria
to: /kategoria/linux
to: /kategoria/na-luzie
to: /kategoria/oprogramowanie
to: /kategoria/sprzet
to: /kategoria/wiersze
to: /kategoria/windows
to: /kategoria/wordpress
to: /strona/:splat
to: /tag/:splat
to: /:splat
to: /:splat
to: /:splat
to: /:splat
to: /:splat
to: /:splat
to: /:splat
to: /:splat
to: /:splat
to: /tag/przesyΕki-priorytetowe-krajowe
to: /tag/pΕynny-karmel
to: /tag/sΕawomir-wΕodkowski
Caching artifacts
7:25:02 AM: Started saving build plugins
7:25:02 AM: Finished saving build plugins
7:25:02 AM: Started saving pip cache
7:25:02 AM: Finished saving pip cache
7:25:02 AM: Started saving emacs cask dependencies
7:25:02 AM: Finished saving emacs cask dependencies
7:25:02 AM: Started saving maven dependencies
7:25:02 AM: Finished saving maven dependencies
7:25:02 AM: Started saving boot dependencies
7:25:03 AM: Creating deploy upload records
7:25:02 AM: Finished saving boot dependencies
7:25:02 AM: Started saving rust rustup cache
7:25:02 AM: Finished saving rust rustup cache
7:25:02 AM: Started saving go dependencies
7:25:03 AM: Finished saving go dependencies
7:25:03 AM: Build failed due to an internal system error: Build script returned non-zero exit code: 4
7:25:04 AM: Failing build: Failed to build site
7:25:04 AM: Failed during stage 'building site': Build script returned non-zero exit code: 4
7:25:04 AM: Finished processing build request in 6m8.418316525s
Build command: hugo --gc --minify
I made some changes which I revert to the build that was working, but its failing still.
