I’m having trouble trying to identify where the fatal error may be:
7:48:33 PM: Build ready to start
7:48:35 PM: build-image version: 9cade8af58c2cf3a17a1e9433d2e979149488837
7:48:35 PM: build-image tag: v3.3.5
7:48:35 PM: buildbot version: eb060c4dc3a8a73f9004f460f04632708166ca51
7:48:35 PM: Fetching cached dependencies
7:48:35 PM: Starting to download cache of 110.1MB
7:48:35 PM: Finished downloading cache in 683.546958ms
7:48:35 PM: Starting to extract cache
7:48:38 PM: Finished extracting cache in 3.028168619s
7:48:38 PM: Finished fetching cache in 3.808335948s
7:48:38 PM: Starting to prepare the repo for build
7:48:39 PM: Preparing Git Reference refs/heads/master
7:48:46 PM: Found Netlify configuration file. Overriding site configuration
7:48:46 PM: Starting build script
7:48:46 PM: Installing dependencies
7:48:47 PM: Started restoring cached node version
7:48:49 PM: Finished restoring cached node version
7:48:50 PM: Downloading and installing node v10.17.0…
7:48:50 PM: Computing checksum with sha256sum
7:48:51 PM: Checksums matched!
7:48:52 PM: Attempting ruby version 2.6.2, read from environment
7:48:54 PM: Using ruby version 2.6.2
7:48:54 PM: Using PHP version 5.6
7:48:54 PM: Installing Hugo 0.58.3
7:48:54 PM: Hugo Static Site Generator v0.58.3-4AAC02D4/extended linux/amd64 BuildDate: 2019-09-19T15:34:54Z
7:48:54 PM: Started restoring cached go cache
7:48:55 PM: Finished restoring cached go cache
7:48:55 PM: unset GOOS;
7:48:55 PM: unset GOARCH;
7:48:55 PM: export GOROOT=’/opt/buildhome/.gimme/versions/go1.12.linux.amd64’;
7:48:55 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
7:48:55 PM: go version >&2;
7:48:55 PM: export GIMME_ENV=’/opt/buildhome/.gimme/env/go1.12.linux.amd64.env’;
7:48:55 PM: go version go1.12 linux/amd64
7:48:55 PM: Installing missing commands
7:48:55 PM: Verify run directory
7:48:55 PM: Executing user command: hugo --gc --minify -b $URL
7:48:55 PM: Building sites …
7:48:56 PM: panic: parse /post/Icon
: net/url: invalid control character in URL
7:48:56 PM: goroutine 86 [running]:
… ### Couldn’t keep all the links of goroutine in this post.
7:48:56 PM: Skipping functions preparation step: no functions directory set
7:48:56 PM: Caching artifacts
7:48:56 PM: Started saving pip cache
7:48:56 PM: Finished saving pip cache
7:48:56 PM: Started saving emacs cask dependencies
7:48:56 PM: Finished saving emacs cask dependencies
7:48:56 PM: Started saving maven dependencies
7:48:56 PM: Finished saving maven dependencies
7:48:56 PM: Started saving boot dependencies
7:48:56 PM: Finished saving boot dependencies
7:48:56 PM: Started saving go dependencies
7:48:56 PM: Finished saving go dependencies
7:49:00 PM: Error running command: Build script returned non-zero exit code: 2
7:49:00 PM: Failing build: Failed to build site
7:49:00 PM: failed during stage ‘building site’: Build script returned non-zero exit code: 2
7:49:00 PM: Finished processing build request in 25.547765543s
