Build exceeded maximum allowed runtime please help!
I am trying to deploy a site but I keep getting a build time exceeded error and the deployment fails, I have deployed a few other sites with Netlify previously and had no issues but this is the first project I am using Tailwind CSS on so I am unsure if this is causing an issue, I am still fairly new to development and learning as I go so I am sure this is a simple fix but I am unsure how to do so.
Any help would be great.
Site I am trying to deploy is preeminent-boba-b4c3f2.netlify.app
Hey @asg-images
There are some great support guides which may help you with this issue
You’ll find even more build resources in [Support Guide] Compiled Build and Deploy Resources -- start here! too.
If you are still unable to remedy the issue, please share the build log as this will enable the community to assist you in debugging this issue.
