The Netlify Forms integration of a site I have been working on suddenly stopped working. A week ago, the images of the site were not correctly loading so I rebuild the site using edge images and that got it up and running again I think.
Anyways, after the rebuild the forms stopped working. When using a form, for example at Contact | K-Motion, I het a 405 error Method not allowed.
I read on the forum here that it might have to do with non-static site generation, but I checked this and the redirect page is build/served statically by Next.Js.
ChatGPT suggested nonsense, so I was hoping you could help me out
With ‘redirect page’ I meant the page the form points to using its action field, which is set to /contact/success.
I don’t understand the difference between Netlify powered and Next.Js powered I think. It is definitely a page I built with Next.Js, but it should be a static page according to my build log:
I eventually reverted to runtime v4 but the issue still persisted. Then, I turned off Network Edge Images (using env variable) and then everything started working again.
I see you’re using Next.js 13.5.6, in which case you’ll want to use the version 5 of the Netlify/Next.js runtime.
Along with the Netlify doc link that nathanmartin provided, there is an example on that page under Here’s a simplified example of the form component: ).
Additionally, we have a Starter Template with Netlify forms code that you can follow as well and compare your code:
